#PIN_SELECT changed in V4.125
bilko
PostPosted: Sat Oct 08, 2011 1:36 am     Reply with quote
I used to be able to use #defines in #PIN_SELECT:
ie:
#define P_ChargePWM PIN_G6
#PIN_SELECT OC1=P_ChargePWM
but now in V4.125 I have to say:
#PIN_SELECT OC1=PIN_G6
This is PCD, I have not yet tried the other compilers.
This seems to be a backward step
Bill
orangeshasta
PostPosted: Sun Oct 23, 2011 12:12 pm     Reply with quote
Hi there,
Late response I know, but I just saw your post. I was having the same problem, and got in touch with CCS support. What they said:
Make sure there is not a tab on the #define line. 4.125 seems to have a problem with tabs in the #pin_select. This will be fixed in the next release.
That seemed to work for me. I needed to remove ALL TABS from all lines of code which had a #define statement to rename a pin, and from all of my #pin_select lines. This INCLUDES tabs after the command - i.e., between your #define and a comment on the same line.
Hope that helps, I'm looking forward to a compiler update. There seem to be a couple problems with 4.125.
-Bob
bkamen
PostPosted: Sun Oct 23, 2011 1:47 pm     Reply with quote
orangeshasta wrote:
Hi there,
Ooo, this is an old bug that seems to have crept back in.
For Shame.
-Ben
miketwo
PostPosted: Mon Nov 07, 2011 4:18 pm     Reply with quote
Thank you, I was about to pull my hair out.
Now I'm just cursing as I remove all tabs everywhere... it's slightly less stressful.
bkamen
PostPosted: Mon Nov 07, 2011 4:25 pm     Reply with quote
And I'm not a fan of spaces -- I like tabs.. but I can see their downfall.
Yay Python. (grrrr)
-Ben
miketwo
PostPosted: Mon Nov 07, 2011 5:16 pm     Reply with quote
I take it back. I am pulling my hair out.
Even with the spaces change, there seems to be something wrong with the PIN_SELECTs. I reverted to an older PCD version, and my I/O works -- with the newest compiler (4.125), it doesn't.
Does anyone have a link to version 4.124? Unfortunately, the last one I saved off was 4.112...
dyeatman
PostPosted: Mon Nov 07, 2011 5:20 pm     Reply with quote
If you are registered user of 4.125 report the problem to CCS and they will likely send you the previous version.
Google and Forum Search are some of your best tools!!!!
bkamen
PostPosted: Mon Nov 07, 2011 5:54 pm     Reply with quote
And probably the next... They usually send you a free update when you report a bug like this..
-Ben
miketwo
PostPosted: Mon Nov 07, 2011 7:49 pm     Reply with quote
I wanna know who you guys are talking to, cause I've never received good customer service from them, and I've been a licensed customer (reporting a multitude of bugs) for years.
I actually keep a separate project on MPLAB with a bunch of regression tests to try against each new upgrade... and I have yet to see any of the bugs I've reported be fixed. :-/
PostPosted: Tue Nov 08, 2011 5:49 am     Reply with quote
I always reported my bugs to the support email at the top of this page, never by phone. Often I got a response that the bug would be fixed in the next release and as mentioned by others, sometimes got a free update for the next release.
Some of the lesser important bugs were not fixed, too bad, but I do understand that a commercial company has to make choices.
