Data Compression
Gabriel
Data Compression
PostPosted: Fri Oct 07, 2011 3:10 pm     Reply with quote
Hi all,
I'm looking for suggestions...
I have a datalogger I've built and coded,
16F876A, 25AA256 eeprom, DS1305.
It takes a single 10bit reading at programmable intervals, takes a time stamp.
It saves data as follows:
Day, Month, Year, Hour, Minutes, Data Hi-byte, Data Low-Byte.
Code works, everything is nice and great, BUT ;)
I'm spending more memory on time stamp info than data.
I'm sure alot of you have gone through this before... so I'm looking for maybe some simple way to compress the time stamp info.
My idea so far is as follows, worst case Scenario:
Time: 31/12/99 - 23:59
Bytes   1       2       3        4       5
data    31      12      99       23      59
binary  11111   1100    1100011  10111   1011001
Bytes   1         2         3         4
Result  11111110  01100011  10111101  1001(0000) <- padded
Thus resulting in a one byte saving.... seems like alot of bit shifting for just one byte....
I can save 2 bytes if I include the 2 data bytes in the compression "algorithm" described above.
The idea is to be able to quickly and on the fly compres/decompress data for saving and for printing to screen.
Any thoughts?
CCS PCM 5.078 & CCS PCH 5.093
PostPosted: Fri Oct 07, 2011 4:21 pm     Reply with quote
Some ideas....
Using 1-365 for the day of the year takes 2 bytes...
Don't save the year byte...have the filename encoded with that.
Same could be used for the month...ie:filename 1102data.txt means data collected in Feb of 2011.So only 1 byte for day of month....
Depending on how often the data is recorded, if you only sample every 15 minutes, the time can be represented in one byte(24 * 4=96) or if you sample every 6 minutes you'll get maximum samples/day(24hr*60min=1440 minutes/256=5.625).
gpsmikey
PostPosted: Fri Oct 07, 2011 6:29 pm     Reply with quote
Another option (sort of a spin on the way windows/unix etc store time) is to have some arbitrary start time that you could store, then each time stamp is stored as an offset in seconds or minutes or whatever incremental resolution you need. If you used minutes, 16 bits would give you 45 days worth of "time stamps".
mikey
mikey
PostPosted: Sat Oct 08, 2011 2:20 am     Reply with quote
Yes.
Remember the time.h library, has a mktime function, which returns a time converted to a 32bit count of seconds from a start point (based exactly on the Unix version). Use this on a start date/time to give you a 'beginning of time' marker, and subtract this from the values converted the same way from you sample times. Divide by 60, so you are working in minutes, rather than seconds, and store the low 3 bytes of the int32, and you can handle just under 32 years in 3 bytes.....
Gabriel
PostPosted: Sat Oct 08, 2011 6:46 am     Reply with quote
Hey Guys,
Thanks for your suggestions, i had not thought of storing dates as a day out of 365... nice!
i had however thought of using the latter suggested Win/Unix method... but thought it would be alot of coding... and testing....
but i had no idea there was a time.h library! (never needed it)
ill check that out! Thanks!
i was even thinking of Huffman at some point.... i dont suppose there is a Huffman-Compression.h file laying arround? jejejeje...
Thank you for your suggestions!
G.
PostPosted: Sun Oct 09, 2011 2:26 am     Reply with quote
I doubt if Huffman coding would help.
It is normally optimal, where you have a stream of symbols with a probability 'tree' on their occurrence, and some having higher probabilities than others. If you use a pure clock counter, probabilities should be equal for all entries. Result, no saving...
