Hi PCM and All developers!
Can be make PCM Flexible LCD driver to controlling more than one LCD display using one data bus (4-bit),RS, RW->GND and dynamically change LCD_E (enable) pin for select desire LCD or send data to all?
That sounds like a nice project ! Fairly simple as you've already got the basic driver code.Be sure to read the LCD datasheet for the 'specs' and send us your code, put it in the code library when 100% working.
Posted: Fri Oct 07, 2011 1:41 pm
In answer to your PM, this can probably be done but I don't want to write
the code for you.
