RTOS for multiplexing
neomus
PostPosted: Fri Oct 07, 2011 6:38 am     Reply with quote
Hi
I am trying to multiplex a 7 segment led display(2 digit) using RTOS.
MCU - PIC16f628a
A2 and A3 are driving the common cathode of the display. A0 is connected to a button which output the variable "count" to portb when pressed.
portb is connected to segments
Problem is when i power up the circuit sometime A2 and A3 blinks together
sometime A2-ON, A3-OFF (A2-OFF, A3-ON) which is okay for the application. Please someone advise me.
#include <16f628a.h>
#use delay (int=4000000)
#use rtos(timer=0, minor_cycle=1ms)
int count;
unsigned int var1=0;
#task(rate=200ms, max=1ms)
void live1()
output_toggle(PIN_A2); // Toggle RA2
void live2()
output_toggle(PIN_A3); // Toggle RA3
// Declare TASK "Display" - called every 10ms
#task(rate=10ms, max=1ms,queue=1)
void Display()
if(rtos_msg_poll() > 0) // Is there a message ?
output_b(rtos_msg_read()); // Send to PORTB
// Declare TASK "Generator" - called every millisecond
#task(rate=1ms, max=1ms)
void Generator()
count++; // Increment count
if ((input(PIN_A0) == 1)&& (var1 ==0)) // Switch pressed ?
var1 =1;                                            //switch debounce
rtos_msg_send(Display,count); // send a message
else if ((input(PIN_A0)==0) && (var1 ==1))
var1 = 0;
set_tris_a(0x03); // A0 and A1 input
set_tris_b(0x00);    /portb is output
output_b(0x00);    //clear portb
output_a(0x04);    //to make sure A2 and A3 are not blink together
rtos_run();
asmboy
PostPosted: Fri Oct 07, 2011 8:26 am     Reply with quote
you should start by reading about the set_tris() function.
Since you did not declare any FAST_IO in your setup - this is
potentially one of your issues
Then - the button press detector makes no sense in the time domain , since just for starters - how do you know that the button press is 'clean' ??
** why is count a signed integer ??
** don't you believe in setting fuses??
** is this ACTUAL HARDWARE or a simulation ??
** why cant var1 be an int1 ??
** not knowing what actual display circuit you have ( schematic please??)
there is no way to predict what is going on with your
"" 7 segment led display(2 digit) ""
if you are switching commons on TWO LED 7 segments at 200 ms ( guessing here) - WHERE are you selecting the proper port_B() data to SHOW??
the LOGIC of what you are doing escapes me as you would ONLY send a single BYTE to port b of a SIGNED integer COUNT - IF the button press -
code actually worked.
you are in trouble conceptually and logically here.
lastly-
when the button IS pressed - how long will it take for count to increment by 1000?? ( with 'count' able to represent +/-127 ??? )
you are not thinking clearly in the time domain either !!!
RTOS won't fix that ;-))
