Nisar
16x2 LCD 8 Data bit ready code for every one |
Posted: Sat Mar 28, 2009 3:02 am |
8-BIT LCD DRIVER FOR PIC16F877A CCSC
// CCS C Compiler
// LCD 16x2
// by Nisar Ahmed
// 2009/03/27
#include <16F877.h> // PIC16F877 header file
#use delay(clock=4000000) // for 4Mhz crystal
#fuses XT, NOWDT, NOPROTECT, NOLVP // for debug mode
#define PORT_A 0 // define for function output()
#define PORT_B 1
#define PORT_C 2
#define PORT_D 3
#define PORT_E 4
#define NCHAR_PER_LINE 16 // max char numbers per line
#define LCD_RS PIN_A1
#define LCD_RW PIN_A2
#define LCD_E PIN_A3
#define LCD_DAT PORT_D
///////////////////////////////////////////////// output()
//lcd data bus output
void output(int8 port, int8 dat)
switch(port)
case PORT_A: output_a(dat); break;
case PORT_B: output_b(dat); break;
case PORT_C: output_c(dat); break;
case PORT_D: output_d(dat); break;
case PORT_E: output_e(dat); break;
default : //??? port maybe error!
}//end output()
//////////////////////////////////////////////// lcd_write_cmd()
void lcd_write_cmd(int8 cmd)
delay_us(400);
output_low(LCD_RS);
output_low(LCD_RW);
output(LCD_DAT, cmd);
output_high(LCD_E);
delay_us(400);
output_low(LCD_E);
}//end lcd_write_cmd()
/////////////////////////////////////////////// lcd_write_dat()
void lcd_write_dat(int8 dat)
delay_us(400);
output_high(LCD_RS);
output_low(LCD_RW);
output(LCD_DAT, dat);
output_high(LCD_E);
delay_us(400);
output_low(LCD_E);
}//end lcd_write_dat()
//////////////////////////////////////////// lcd_init()
void lcd_init(void)
output_low(LCD_E); // Let LCD E line low
lcd_write_cmd(0x38); // LCD 16x2, 5x7, 8bits data
delay_ms(15);
lcd_write_cmd(0x01); // Clear LCD display
delay_ms(10);
lcd_write_cmd(0x0f); // Open display & current
delay_ms(10);
lcd_write_cmd(0x06); // Window fixed
delay_ms(10);
}//end lcd_init()
///////////////////////////////////////// lcd_display_char()
void lcd_display_char(int8 line, int8 pos, int8 ch)
int8 tmp;
line = (line==0) ? 0 : 1;
pos = (pos >NCHAR_PER_LINE) ? NCHAR_PER_LINE : pos;
tmp = 0x80 + 0x40*line + pos;
lcd_write_cmd(tmp);
lcd_write_dat(ch);
}//end lcd_display_char()
/////////////////////////////////////////// lcd_display_str()
void lcd_display_str(int8 line, char str[])
int8 i;
for(i=0; i<NCHAR_PER_LINE; i++)
lcd_display_char(line, i, ' ');
if(str[i] == '\0') break;
lcd_display_char(line, i, str[i]);
}//end lcd_display_str()
char LINE2[] = { "PIC16F877 CCSC " };
int8 i;
lcd_display_char(0, i, '0'+i);
//lcd_display_str(1, "PIC16F877A CCSC ") //CCSC can't compile
lcd_display_str(1, LINE2);
}//end main()
Regards
Nisar ahmed |
