PIC18F13K22 #fuses problem
cesarsarria
PostPosted: Wed Oct 05, 2011 11:46 pm     Reply with quote
Hi, i am having problems activating the PLL. I am using the code below, but the frequency still been 16M. The problem I am seeing is the #fuses at the code don't agree with the compiler fuses on the bit configuration. Do you have any idea or a simple code I can test?
#fuses HS,PLLEN,NOWDT,NOBROWNOUT,NOPROTECT,NOLVP
#use delay(clock=16M)
PostPosted: Thu Oct 06, 2011 1:51 am     Reply with quote
#use delay(crystal=16M,clock=64M)
