Problem with dimmer DMX and PIC18F26K22
stefanomalizia
PostPosted: Fri Sep 30, 2011 5:15 pm     Reply with quote
Hi guys, I'm a new user on this forum and I apologize for my bad English.
I explain my problem
my code works fine but sometimes I have errors in reception, occasionally I get the next channel of the channel set.
for example:
The board address is 120, sometimes I get the value of address 121.
Why????
I use Mark code receiver routine copied from this forum and pic work at 16MHz ( Cristal)
this is the full code:
//Compilatore PCWHD 4.122
*                       DEFINIZIONE I/O                                 *
#define b0  PIN_A0      //PIN address
#define b1  PIN_B1
#define b2  PIN_B2
#define b3  PIN_B3
#define b4  PIN_B4      //PIN address
#define b5  PIN_B5
#define b6  PIN_B6
#define b7  PIN_B7
#define b8  PIN_A1
#define config  PIN_A2
#define dim_1           PIN_C0
#define data_led       PIN_A5
*                       DEFINIZIONE REGISTRI                            *
#byte SPBRGH1 = 0xFB0
#byte SPBRG1  = 0xFAF
#byte TXSTA1 = 0xFAC
#bit SYNC = TXSTA1.4
#bit BRGH = TXSTA1.2
#byte TRISC = 0xF94
#bit TRISC7 = TRISC.7
#bit TRISC6 = TRISC.6
#byte RCSTA1 = 0xFAB
#bit SPEN = RCSTA1.7
#bit RX9  = RCSTA1.6
#bit CREN = RCSTA1.4
#bit ADDEN = RCSTA1.3
#bit FERR = RCSTA1.2
#bit OERR = RCSTA1.1
#bit RX9D = RCSTA1.0
#byte RCREG1 = 0xFAE
#byte BAUDCON1 = 0xFB8
#bit DTRXP = BAUDCON1.5
#bit BRG16 = BAUDCON1.3
#byte INTCON = 0xFF2
#bit GIE = INTCON.3      // GIE/GIEH
#bit PEIE = INTCON.6     // PEIE/GIEL
#byte PIE1 = 0xF9D
#bit RC1IE = PIE1.5
#byte PIR1 = 0xF9E
#bit RC1IF = PIR1.5
*                   DEFINIZIONE VARIABILI GLOBALI                       *
//#define DMX_512_Offset   12    //Indirizzo Principale dispositivo DMX
int16 DMX_512_Offset=1;
#define MAX_BUFFER 1 //antes 24
int8 Rx_Buffer[MAX_BUFFER];
int8 Val_1 = 0;
*                       INIZIALIZZAZIONE RS485                          *
void rs485_init(void)
   TRISC6=1;
   TRISC7=1;
   SPBRGH1=0;  //Baud Rate Generator
   SPBRG1=3;   //Baud Rate Generator
   BRGH=1;     // High Baud Rate Select bit
   BRG16=0;    // 16-bit Baud Rate Generator bi
   SYNC=0;     // EUSART Mode Select bit
   SPEN=1;     // Serial Port Enable bit
   RC1IE=1;
   GIE=1;
   PEIE=1;
   RX9=1;      //9-bit Receive Enable bit
   ADDEN=0;    // Enables address detection, enable interrupt and load the receive buffer when RSR<8> is set
   //DTRXP=0;    // Data/Receive Polarity Select bit
   CREN=1;     //Continuous Receive Enable bit
   return;
*                            Dimming MAP                                *
const int16 Map[256] = {   27536,   27536,   27536,   27536,   27536,   27536,   27691,   27846,   28001,   28156,
                           28311,   28467,   28622,   28777,   28932,   29087,   29242,   29397,   29552,   29707,
                           29862,   30018,   30173,   30328,   30483,   30638,   30793,   30948,   31103,   31258,
                           31413,   31569,   31724,   31879,   32034,   32189,   32344,   32499,   32654,   32809,
                           32964,   33120,   33275,   33430,   33585,   33740,   33895,   34050,   34205,   34360,
                           34515,   34671,   34826,   34981,   35136,   35291,   35446,   35601,   35756,   35911,
                           36066,   36221,   36377,   36532,   36687,   36842,   36997,   37152,   37307,   37462,
                           37617,   37772,   37928,   38083,   38238,   38393,   38548,   38703,   38858,   39013,
                           39168,   39323,   39479,   39634,   39789,   39944,   40099,   40254,   40409,   40564,
                           40719,   40874,   41030,   41185,   41340,   41495,   41650,   41805,   41960,   42115,
                           42270,   42425,   42581,   42736,   42891,   43046,   43201,   43356,   43511,   43666,
                           43821,   43976,   44131,   44287,   44442,   44597,   44752,   44907,   45062,   45217,
                           45372,   45527,   45682,   45838,   45993,   46148,   46303,   46458,   46613,   46768,
                           46923,   47078,   47233,   47389,   47544,   47699,   47854,   48009,   48164,   48319,
                           48474,   48629,   48784,   48940,   49095,   49250,   49405,   49560,   49715,   49870,
                           50025,   50180,   50335,   50490,   50646,   50801,   50956,   51111,   51266,   51421,
                           51576,   51731,   51886,   52041,   52197,   52352,   52507,   52662,   52817,   52972,
                           53127,   53282,   53437,   53592,   53748,   53903,   54058,   54213,   54368,   54523,
                           54678,   54833,   54988,   55143,   55299,   55454,   55609,   55764,   55919,   56074,
                           56229,   56384,   56539,   56694,   56850,   57005,   57160,   57315,   57470,   57625,
                           57780,   57935,   58090,   58245,   58400,   58556,   58711,   58866,   59021,   59176,
                           59331,   59486,   59641,   59796,   59951,   60107,   60262,   60417,   60572,   60727,
                           60882,   61037,   61192,   61347,   61502,   61658,   61813,   61968,   62123,   62278,
                           62433,   62588,   62743,   62898,   63053,   63209,   63364,   63519,   63674,   63829,
                           63984,   64139,   64294,   64449,   64604,   64760,   64915,   65070,   65225,   65380,
                           65535,   65535,   65535,   65535,   65535,   65535 };
*                           Pulse                                       *
void trig(void)
   output_high(dim_1);
   delay_us(100);
   output_low(dim_1);
   return;
*                                        RS485                          *
#INT_RDA
void DMX_Rx_isr()
  #define WAIT_FOR_NEXT_BYTE 0
  #define WAIT_FOR_BREAK     1
  #define WAIT_FOR_START     2
  #define WAIT_FOR_DATA      3
  #define RECEIVE_DATA       4
  char data;
  static char Rx_State = WAIT_FOR_BREAK;
  union {
    unsigned char fullbyte;
    struct {
        unsigned char RX9D:1;
        unsigned char OERR:1;
        unsigned char FERR:1;
        unsigned char ADDEN:1;
        unsigned char CREN:1;
        unsigned char SREN:1;
        unsigned char RX9:1;
        unsigned char SPEN:1;
    } bits ;
  }rcsta;
  static unsigned int16 DMX_512_Count=0;
  static char Rx_Index = 0;
  while (RC1IF)
    output_high(data_led);
    rcsta.fullbyte = RCSTA1;
    data = RCREG1;
    if (rcsta.bits.OERR)
      CREN=0;
      CREN=1;
      Rx_State = WAIT_FOR_NEXT_BYTE;
      return;
    switch (Rx_State)
      case WAIT_FOR_NEXT_BYTE:
        if (!rcsta.bits.FERR)
      case WAIT_FOR_BREAK:
        /* Check for a framing error */
        if (rcsta.bits.FERR)
          if (!data)
            Rx_State = WAIT_FOR_START;
      case WAIT_FOR_START:
          if (!data)
            Rx_Index = 0;
            if (DMX_512_Offset == 1)
              Rx_State = RECEIVE_DATA;
              Rx_State = WAIT_FOR_DATA;
              DMX_512_Count = 1;
      case WAIT_FOR_DATA:
          if (!data)
          DMX_512_Count++;
          if (DMX_512_Count == DMX_512_Offset)
      case RECEIVE_DATA:
          if (!data)
          /* Store the data received in the Rx buffer */
          //if (Rx_Buffer[Rx_Index] != data)
          //  levels[Rx_Index] |= 0x80;
          Rx_Buffer[Rx_Index] = data;
          /* Point to the next byte */
          ++Rx_Index;
          /* Check to see if we have received all of our data */
          if (Rx_Index >= MAX_BUFFER)
//      default:
      /* Unknown start code */
  output_low(data_led);
  return;
*               ZERO CROSSING AND DIMMING INTERRUPT                     *
#int_EXT
void EXT_isr(void)
   clear_interrupt(int_timer1);
   clear_interrupt(int_timer3);
   if(Val_1 < 5 )           //Lampada OFF
      output_low(dim_1);
   }else if(Val_1 > 250)          //Lampada ON
      output_high(dim_1);
   }else
      set_timer1(Map[Val_1]);
      set_timer3(27000);
      enable_interrupts(INT_TIMER3);
   return;
#INT_TIMER1
void TIMER1_isr(void)
   trig();
   disable_interrupts(INT_TIMER1);
   return;
#INT_TIMER3
void TIMER3_isr(void)
   disable_interrupts(INT_TIMER3);
   return;
*                       GET ADDRESS                                     *
int16 get_address(void)
   int16 address=0;
   if(!input(b0))
      address += 1;
   if(!input(b1))
      address += 2;
   if(!input(b2))
      address += 4;
   if(!input(b3))
      address += 8;
   if(!input(b4))
      address += 16;
   if(!input(b5))
      address += 32;
   if(!input(b6))
      address += 64;
   if(!input(b7))
      address += 128;
   if(!input(b8))
      address += 256;
   return address;
*                    Programma Principale                               *
   setup_timer_3(T3_INTERNAL|T3_DIV_BY_1);
   //pulisco le uscite
   output_low(dim_1);
   Rx_Buffer[0]=0;      // Inizializzo buffer
   port_b_pullups(TRUE);
   //INIZIO ROUTINE DMX512
   DMX_512_Offset = get_address();  //Acquisizione indirizzo scheda
   ext_int_edge( H_TO_L );          //Interrupt sul fronte di discesa
   enable_interrupts(INT_RDA);     //abilito interrupt porta seriale
   enable_interrupts(GLOBAL);      //Abilito interrupt globali
   rs485_init();                   //Inizializzo comunicazione seriale rs485
   if(input(config))               //Controllo Modalita DipSW-10
      enable_interrupts(INT_EXT);
      while(true)
            Val_1 = Rx_Buffer[0];
            if((Rx_Buffer[0] < 5) && (Rx_Buffer[0]> 250))
            }else
               if(Val_1 < Rx_Buffer[0])
                  Val_1++;
               if(Val_1 > Rx_Buffer[0])
                  Val_1--;
   } else                                    //Modalità ON/OFF
      disable_interrupts(INT_EXT);     //Disabilito lo zero crossing
      while(true)    //ON/OFF routine
         if(Rx_Buffer[0]>128)    // 0-128 --> OFF / 129-255 --> ON
            output_high(dim_1);
         }else
            output_low(dim_1);
I hope in your help to solve this little problem... Laughing
thank you
PostPosted: Fri Sep 30, 2011 6:38 pm     Reply with quote
Without cut/paste/compiling your copied code I'd say that the difference in the addresses may be due to a timing problem(slewing or stretching). DMX512 is 250KHz I believe and is doable with a 16MHz xtal.
I used PicBaud.exe to figure out your setup may not be right, though PicBaud gives 2 perfect answers, the 3rd, like your program gives an error.
Any error in timing will cause problems,especially if using long lines, unshielded wire, EMI, etc.
freesat
PostPosted: Wed Oct 05, 2011 2:11 am     Reply with quote
I have done some dmx devices using long lines, poor cables and works fine! 100% success, but!!! I have problem like your only using AC Dimmer, in this case, delay routines caused the problem.
Now I'm trying dimmer based only in timer0, without delay_?s().
Check if your code have free cycles to handle dmx at 16Mhz.
