PIC18F25K20 ADC problem
subi
PostPosted: Fri Sep 30, 2011 3:12 pm     Reply with quote
Hi Everybody,
I would like to ask a little help. So I am a beginner and I would like to use the PIC18F25K20 for measure voltage with FVR - 1,2 V reference voltage in it. I can not found a CCS soft ver, how I have to use it. But I have ADC in the other PIC but that code does not work with PIC18F25K20.
Please give me some advices and send a program if it is possible.
Thank you for your help and kindness.
Subi (sorry for my English)
n-squared
PostPosted: Fri Sep 30, 2011 4:06 pm     Reply with quote
FVR is read on channel 15 of the ADC.
use set_adc_channel(15) to read FVR.
The FVR has to be enabled by setting FVREN bit in CVRCON2.
#byte CVRCON2 = 0xFB4
#bit FVREN = CVRCON2.7
#bit FVRST = CVRCON2.6
void enable_fvr(void)
  FVREN = 1;
  while (!FVRST); // wait for FVR to stabilize
int8 get_fvr(void)
  set_adc_channel(15);
  delay_us(10);
  return read_adc();
  enable_fvr();
  printf("FVR = %u\r\n", get_fvr());
Hope this helps
BR
n-squared
Every solution has a problem.
subi
PostPosted: Sat Oct 01, 2011 11:59 am     Reply with quote
Dear n-squared,
Thank you for your answer. I have tried your code and I have measured 0V. As I wrote I am a beginner so pehaps I have not set well the port.
I set the PORTA:
 setup_adc_ports(sAN0|sAN3|VREF_FVR);
 setup_adc(ADC_CLOCK_DIV_16|ADC_TAD_MUL_8);
Further I don't know whis is the 15 channel.
So please write more about it. If you give complete setup it will be very good.
Thank you for your help.
Subi
n-squared
PostPosted: Sat Oct 01, 2011 3:30 pm     Reply with quote
#include <18F25K20.h>
#device adc=10
#FUSES NOWDT                    //No Watch Dog Timer
#FUSES INTRC_IO                 //Internal RC Osc, no CLKOUT
#FUSES NOLVP                    //No low voltage prgming
#FUSES NOXINST                  //Extended set extension and Indexed Addressing mode disabled (Legacy mode)
#use delay(int=8000000,RESTART_WDT)
  FVREN = 1;
int8 get_fvr(void)
  int16 ret;
  set_adc_channel(15);  // channel 15 IS FVR
  delay_us(20);
  ret = read_adc();
  return ret;
  int16 ret, x;
  setup_adc_ports(sAN0|sAN1|VSS_VDD);
  setup_adc(ADC_CLOCK_DIV_32|ADC_TAD_MUL_16);
  enable_fvr();
  ret = get_fvr();
  x++;
  x++;
put a breakpoint on first x++; following a call to get_fvr();
BR
n-squared
subi
PostPosted: Sun Oct 02, 2011 6:13 am     Reply with quote
Dear n-squared,
Thank you for your code. My PIC 18F25K20 perhaps is not good, because the measured voltage is zero. I have to order some new pieces. But my PIC18f45K25 is going with your program code. But I have a little mistake. The measured voltage is not stable. I don't understand it.
So I would like to thank you again for your helping.
Subi
subi
PostPosted: Wed Oct 05, 2011 12:43 pm     Reply with quote
Dear n-squared,
I have used your sent code. The program is running well but I have a little mistake. The FVR voltage is not stable. If I put on the voltage the measured FVR is less. If I put down the voltage the measured FVR is more. Why do I experience it? Do you have any idea?
Subi
n-squared
PostPosted: Wed Oct 05, 2011 2:31 pm     Reply with quote
Check your Vdd. If it is not stable, the FVR readings will not be stable ether.
subi
PostPosted: Thu Oct 06, 2011 7:35 am     Reply with quote
Dear n-squared,
Thanks, it is a good advice. So perhaps I understand what is the problem because I would like to measure the battery voltage changing. But the PIC have got the energia form the battery. So if the battery voltage put down the FVR is not stable.
Do you suggest a outer voltage refernce for the PIC to measure the battery voltage?
Subi
PostPosted: Thu Oct 06, 2011 9:22 am     Reply with quote
The FVR, is relatively stable.
It is your reading of it that isn't, and this can be used to tell you the supply voltage.
Imagine, you have the ADC setup to use Vss-Vdd as it's reference.
You read the voltage on the FVR source, and get a reading of 285. You can then say that the Vdd, is approximately (1.2/284)*1023 = 4.31v. However the accuracy of this is fairly poor. The actual voltage could be anything from just under 4.14v to nearly 4.5v. Even more if you are using the full temperature range of the chip. So if +/-just under 5% is acceptable for your readings, then this allows you to estimate the battery supply voltage. If not, then a higher accuracy source is needed, and the same trick can be used.
subi
PostPosted: Thu Oct 06, 2011 11:12 am     Reply with quote
Dera Ttelmah,
Thank you for your exposition about FVR measuring. It is very deep. So I will look over my circuit about my circuit mistake.
Best wishes,
Subi
tinley
PostPosted: Fri Oct 07, 2011 4:17 am     Reply with quote
In the example code posted by n-squared the ADC has been set up outside the recommended oscillator range which will cause the unstable non linear results that you have suggested.
From the datasheet for an 8MHz oscillator use the following:
setup_adc(ADC_CLOCK_DIV_8)
Although the variations in voltage regulators is a factor when using VSS_VDD as reference, it can mostly be calibrated out in code.
subi
PostPosted: Sat Oct 08, 2011 11:08 am     Reply with quote
Dear tinley,
Thank you for your helping too. I could not use well the FVR to measure the battery when give energy the PIC. But I solved the problem used the PORT AN3 and a diode for reference voltage.
It is the conventional result but it is good.
Subi
