import Microchip C18 to CCS C
pic_micro
PostPosted: Mon Sep 26, 2011 2:10 pm     Reply with quote
The following is a Microchip C18, What is the equivalent
in CCS C
      PORTBbits.RB1 = ~uchrBitArray[ uchrBitCounter ];
I have tried
PIN_B1 = ~uchrBitArray[ uchrBitCounter ];
But I got an error Expecting LVALUE such as a variable name or * expression
asmboy
PostPosted: Mon Sep 26, 2011 2:21 pm     Reply with quote
The implication seems to be:
output_bit(PIN_B1,~uchrBitArray[ uchrBitCounter ]);
is just ONE of several ways in CCS parlance to convert this.
PostPosted: Mon Sep 26, 2011 5:49 pm     Reply with quote
The easiest way to figure it out is to compile the C18 code, dump the listing and see what the code is. Then cut a CCS C program, compile, dump the listing and compare. Once the listings agree, you'll have the exact CCS equal to C18.
Should take 1/2 hr, maybe 1 hr. max.
bkamen
PostPosted: Mon Sep 26, 2011 8:08 pm     Reply with quote
Actually, if you import the structure and assign it with #byte, then the original C18 syntax continues to work.
I've done that in the past and it's a lot easier since changing the header files to work allows all the .C files to fall in line.
-Ben
