delay_us(1200000); 7 segment do not run
jackhammer
PostPosted: Mon Sep 26, 2011 7:03 am     Reply with quote
I use 7 segment 4 base create colck digital do not have second base
24:00
I want delay 7 segment 4 base at minute help me
at first
delay_us(200);
normal number very quickly
delay_us(20000);
for a second 7segment have symptoms flashing
delay_us(1200000);
for a minute 7 segment do not run
Sad
PostPosted: Mon Sep 26, 2011 7:19 am     Reply with quote
Try reading the manual....
What does it say for 'parameters:' for the delay_us function?.
jackhammer
PostPosted: Mon Sep 26, 2011 7:29 am     Reply with quote
thank you
what have function delay
delay_?? for a minute
FvM
PostPosted: Mon Sep 26, 2011 7:58 am     Reply with quote
Consider delay_ms().
PostPosted: Mon Sep 26, 2011 8:06 am     Reply with quote
Seriously though, this is not the way to create a digital clock.
Problem is, that the other code to actually display the data, takes _time_. The accuracy of a clock done like this will be appalling.
You need to be using the hardware to actually generate the time. A timer interrupt, or an RTC, so the time carries on counting, even if you are doing other things.
uN_Eof
Location: I live in Spain, with the toros, paella and tortilla
PostPosted: Thu Sep 29, 2011 8:22 am     Reply with quote
Try using a DS1307.
It's great, it has a pin that changes its state each second, connect that one to an INT_EXT pin, and you're good to go. Also you can get full date and time info by I2C.
http://www.maxim-ic.com/datasheet/index.mvp/id/2688
bkamen
PostPosted: Fri Sep 30, 2011 2:08 am     Reply with quote
or use a PIC with a built-in RTC like the PIC18 J-series.
I don't know if ALL of them have RTC's, but a lot do. I like the J11's.
-Ben
