Real basic DEBUG question
JerryEF
PostPosted: Fri Sep 23, 2011 5:53 pm     Reply with quote
Newbe here. Long time C programmer. On again, off again CCS programmer. Been off for awhile. Been having no problems until trying to use the DEBUG printf facilities: Can't get DEBUG to printf properly to debug monitor window.
Most recent compiler update. PIC18F4620-I/P running on CCS Prototyping board Rev 6. Using ICD-U64 with most current firmware. The test program below was fully built using the CCS new project wizard.
The debugger has the parameter for Userstream Enabled set to TRUE. I have included the core of a program that illustrates my problem:
-> not including the .h files for the processor or project
#fuses DEBUG
#use RS232(DEBUGGER)
   setup_psp(PSP_DISABLED);
   setup_spi(SPI_SS_DISABLED);
   setup_wdt(WDT_OFF);
   setup_timer_0(RTCC_INTERNAL);
   setup_timer_1(T1_DISABLED);
   setup_vref(FALSE);
   printf("This should appear in debug window");
When I run this, I get garbage in the debug Monitor window when the printf executes.
Thanks in advance for any pointers.
PostPosted: Fri Sep 23, 2011 8:27 pm     Reply with quote
Are there any interrupt routines in your program ? Are the interrupts
occurring when the printf to the Debug monitor is executing ?
Also, in this file,
c:\program files\picc\drivers\sim.c
CCS shows an alternate method:
#use rs232(DEBUGGER, stream=DEBUG)
fprintf(DEBUG, "\r\nSending SEQ\r\n");
PostPosted: Sun Sep 25, 2011 1:37 pm     Reply with quote
Maybe not related to your problem, but an invalid setup anyway is the line:
change to:
   setup_spi(FALSE);
Douglas Kennedy
PostPosted: Sun Sep 25, 2011 2:08 pm     Reply with quote
userstream enable is needed but so is a # use delay statement to set the clock frequency
JerryEF
PostPosted: Sun Sep 25, 2011 4:58 pm     Reply with quote
It turned out that I had an inconsistent CLOCK fuse set. Fixed that and everything works fine now. Thanks for the input.
