do can change code as clock ?
jackhammer
PostPosted: Sat Sep 24, 2011 9:33 am     Reply with quote
this code normal will count 1- 9999 but me wanna change as clock
#include <16F877A.h>
unsigned char DisBuff[5];
unsigned char Scan_Column[]={0xfe,0xfd,0xfb,0xf7,0xff};
unsigned char SegMent_Code[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f};
void Decimal_To_7_SegMent(unsigned int16 Num);
void Scan_Display(void);
unsigned int16 Number=0000;
set_tris_b(0x00);
set_tris_d(0x00);
while(true)
Decimal_To_7_SegMent(Number);
Scan_Display();
Number++;
  unsigned int16 temp;
  DisBuff[0]=SegMent_Code[Num/1000];
  temp=Num%1000;
  DisBuff[1]=SegMent_Code[temp/100];
  temp=Num%100;
  DisBuff[2]=SegMent_Code[temp/10];
  temp=Num%10;
  DisBuff[3]=SegMent_Code[temp];
  int i,j;
  for(i=0;i<5;i++)
  for(j=0;j<4;j++)
   output_b(DisBuff[j]);
   output_d(Scan_Column[j]);
   delay_us(1000);
    output_b(DisBuff[4]);
   output_d(Scan_Column[4]);
   delay_us(1000);
PostPosted: Sat Sep 24, 2011 10:32 am     Reply with quote
What type of 'clock' ?
That doesn't tell anyone what you want to do.
You could 'clock' pulses,'real time',speed of passing cars,etc.
You'll need to define the parameters of your 'clock'.
The better the description of what you want, the better the responses you'll get from this forum.
Also be aware that Proteus/ISIS is FULL of bugs, errors, and invalid DRCs so if and that's a BIG if, code 'works' in simulation there is a HUGE chance it'll never work in the real world.I strongly suggest you get real parts and get some true hands on experience.
