Joined: 01 Jul 2010 Posts: 9226 Location: Greensville,Ontario
Posted: Sat Sep 24, 2011 6:33 am |
Sounds like school's in and here's another homework assignment.
You could start by looking at the fine example that CCS kindly supplies in their examples folder....
Also use Google to search for you.I got over 75,000 'hits',lots of code 'on the web'.
But really you should cut your own code to truly understand HOW the PIC and other chips work.
For additioanl help here, you'll need to supply the PIC used, compiler version,real hardware construction NOT simulator(NONE work correctly), and of course your code. |
