help me ERROR"Expecting a close paren"
jackhammer
PostPosted: Sat Sep 24, 2011 4:50 am     Reply with quote
#include <16F877A.h>
unsigned char DisBuff[5];
unsigned char Scan_Column[]={0xfe,0xfd,0xfb,0xf7,0xff};
unsigned char SegMent_Code[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f};
void Decimal_To_7_SegMent(unsigned int16 Num);
void Scan_Display(void);
 unsigned int16 Number=0000;
 set_tris_b(0x00);
 set_tris_d(0x00);
 while(true)
  Decimal_To_7_SegMent(Number);
  Scan_Display();
  Number++;
  unsigned int16 temp;
  DisBuff[0]=SegMent_Code[Num/200];
  temp=Num%200;
  DisBuff[1]=SegMent_Code[temp/40];
  temp=Num%40;
  DisBuff[2]=SegMent_Code[temp/6];
  temp=Num%40;
  DisBuff[3]=SegMent_Code[temp];
  int i,j;
  for(i=0;i<5;i++)
  for(j=0;j<4;j++)
   output_b(DisBuff[j]);
   output_d(Scan_Column[j];
   delay_us(200);
    output_b(DisBuff[4]);
   output_d(Scan_Column[4];
   delay_us(200);
Sad Sad Sad
PostPosted: Sat Sep 24, 2011 5:31 am     Reply with quote
output_d(Scan_Column[j]; <== Missing )
delay_us(200);
output_d(Scan_Column[4]; <== Missing )
delay_us(200);
PostPosted: Sat Sep 24, 2011 6:38 am     Reply with quote
also maybe ...
set_tris_b(0x00);
set_tris_d(0x00);
while(true)
Scan_Display();
Number++;
} !!! this could be seen as the end of MAIN ???
Also good idea to put a blank line between functions or blocks of code,easier to read.
And...MPLABv8.66+ has a great feature to highlight the pairs of bracket! Sure makes troubleshooting code easier.
jackhammer
PostPosted: Sat Sep 24, 2011 6:45 am     Reply with quote
Thank you very much for all comments Very Happy
jackhammer
PostPosted: Sat Sep 24, 2011 9:21 am     Reply with quote
What do you can change code as clock ?
