RS232 timeout error with fgetc() function
monkeyman
PostPosted: Fri Sep 23, 2011 8:11 am     Reply with quote
i have 2 Rs232 on my project, one harware and one software.
#use rs232(baud="baud rate", xmit=PIN_"w", rcv=PIN_"x" , stream=hard)
#use rs232(baud="baud rate", xmit=PIN_"y", rcv=PIN_"z" , timeout=1000, stream=soft)
I want to know on RS232 stream=soft if i can check timeout error with fgetc(soft) function :
answer=fgetc(soft);
if(answer==0)
"error timeout treatment"
thanks
PostPosted: Fri Sep 23, 2011 8:20 am     Reply with quote
try the
kbhit() built in function - it works with streams as an option too
poll kbbit() UNTIL till true - then ONLY do a single getc() WHILE (true==kbhit())
no time wasted - no hanging of your program on a dead serial channel
if you define an edge interruptible portB RX pin - you can do a very nice job of making your own bkbhit function too - based on interrupt captured chars from YOUR RX buffer - i will post a program that demos a software based
rs232 hack i did some time ago that implements this next
read all about it in the RS232 overview section of the CCS manual
PostPosted: Fri Sep 23, 2011 8:34 am     Reply with quote
//     using 4.9152mhz clock for zero err baud division
//     max safe baud rate 9600
//     with 9.83 mhz 19200  MY CTL PACKET IS ONLY 12 CHARS LONG
//     SO USING BUFFER OF 16 in this example
//     timer0 used to be sure incoming packets are complete
//     before attempting reply - to avoid char distortion and loss
//     due to interrupt  - T
#include <16f818.h>
#include <stdlib.h>
#Fuses HS,NOWDT,PUT, MCLR,BROWNOUT,NOLVP,NOCPD,WRT,NODEBUG,CCPB3,NOPROTECT
#use delay( clock=4915200)
#use rs232(baud=9600 , xmit=PIN_B1, rcv=PIN_B0, sample_early)
#use fast_io(A)
#use fast_io(B)
#bit  T0IF    = 0x0B.2  // flag in INTCON reg
#define BUFFER_SIZE 16
BYTE RISR_out;      // global background newchar from ISR BACKGND buffer
BYTE buffer[BUFFER_SIZE];
BYTE next_in = 0;
BYTE next_out = 0;
#define bkbhit (next_in!=next_out)
void bgetc(void) {
   RISR_out=buffer[next_out];    // NOTE : using GLObal return char variable
  ++next_out;
  if (BUFFER_SIZE==next_out) next_out=0;
void SIsr_INIT(void){
    clear_interrupt( int_ext );
    EXT_INT_EDGE(H_TO_L);
    enable_interrupts(int_ext);
    enable_interrupts(global);
#int_ext
   void serial_isr() {
   int t;
   buffer[next_in]=getc(); t=next_in;
   ++next_in
   if (BUFFER_SIZE==next_in) next_in=0;
   if(next_in==next_out)  next_in=t;           // Buffer full !!
void InitHDW ( void ) {
     setup_oscillator ( 4915200 ); //
     output_a (0); output_b (0);  set_tris_a (0xFF);  //  - all INPUT
     setup_timer_0( RTCC_DIV_64);  // set for rollovers ~12 ms holdoff later
      set_tris_b (0b00000001);  output_b (0);
    char v;  char t;  unsigned int8 a;   unsigned int8 b;
    InitHDW();
    SIsr_INIT();
    printf ("*Hello*\r");  // just check output
    delay_ms(12000);  // delay to let me send a packet in
    while (1) {           // now get AND send at same time
      a=next_in;          // get mark of buffer position
      T0IF = 0;
       b=3;      // clear t0if and do 3x12 MS  +/-
      while(b){           // TIMER0 just rolls over endlessly
             if (  T0IF  )  {   // not using INTS - just watching timer
                --b;  T0IF=0;
                if (!b && a==next_in ){ // unload IF no NU chars R caught
                   //              your (safer) xmit routine here
                   while (bkbhit){ bgetc(); putc(RISR_out);}  //simple test
                }  // Implied ELSE - keep waiting
             } // END : IF t0if
       } //       END : WHILE B
    }  //         END : while  1
