freesat
Need help with AC 60Hz Dimmer ( timer0 interrupt ) |
Posted: Wed Sep 21, 2011 4:20 pm |
Hi guys...
I want some help with ac 60hz dimmer, my goal is to build a custom dmx smoke machine with temperature control (also I will build incandescent lamp dimmer array too ), is almost done! but i have trouble with ac dimmer.
steps...
Processor:
PIC12F628 running at 4Mhz internal, using zero cross detector on ext_int pin.
dmx512:
Done (works fine without use delay on ext_int! Especial thanks to "Mark" for sample receive routine).
Temperature control: Done (works and need improve delays with scope, but delay freezes rda interrupt causing data lost).
Wind control:
Done (Works fine! dc pwm with mosfet)
Motor control:
Done (works fine! solid state relay with mosfet)
I think the problem is delay to fire triac on ext_int is too high and no left cycles to process rda_int, and if i right, use a timer0 and wait right moment to fire triac.
Any suggestions? I will appreciate any help.
best regards
Sebastiao Rocha
my sample code...
#define triac PIN_B3
#define channel_temperature 0
#define channel_fan 1
#define channel_motor 2
int8 dmx_channel[3]; /* Smooke machine with 3 channels ( temperature, fan, motor ) */
#int_EXT
void EXT_isr(void) {
int16 wait_dutty_time;
output_low( triac );
/* Calculated delay time ( us / max_dutty * dutty ) */
wait_dutty_time = (int16) (16575/255) * ( dmx_channel[channel_temperature] ^ 255 );
delay_us( wait_dutty_time );
/* dont fire triac if dutty is zero, remember... dutty is inverted "xor with 255" */
if ( wait_dutty_time < 16510 ) { output_high( triac ); }
void main( void ) {
dmx_channel[channel_temperature] = 127 /* set dutty to 50%, for test only */
enable_interrupts( INT_EXT );
ext_int_edge( H_TO_L );
while ( 1 ) {}
I think code using timer0 like this will work... this im need help.
setup_timer_0(RTCC_INTERNAL | RTCC_DIV_1 | RTCC_8_BIT );
set_timer0(?);
int16 wait_dutty_time = 16510;
#int_EXT
#int_TIMER0
void TIMER0_isr(void) {
if ( wait_dutty_time >0 ) { wait_dutty_time--; }
/* time to fire triac */
if ( wait_dutty_time == 0 ) { output_high( triac ); }
/* time to disable triac */
if ( wait_dutty_time == 16510 ) { output_low( triac ); }
freesat
change the code... now its works better, but need adjusts. |
Posted: Thu Sep 22, 2011 1:59 am |
I rebuild the code and it is more stable, but have some noise and is not 100% adjusted with waveform, need more adjusts, any help will be appreciated.
Note: I changed to 12F675 only for tests with ac.
#include <12F675.h>
#fuses INTRC, NOMCLR
#use delay(clock=4M, oscilator=4M, int=4M )
#zero_ram
int8 triac_dutty = 0;
#int_EXT
void EXT_isr( void ) {
set_timer0( triac_dutty );
if ( triac_dutty < 255 ) { output_low( PIN_A5 ); }
#int_TIMER0
void TIMER0_isr( void ) {
set_timer0( 0 );
delay_us(100);
if ( triac_dutty >0 ) { output_high( PIN_A5 ); }
void main( void ) {
setup_timer_0( T0_INTERNAL| T0_DIV_64 | T0_8_BIT );
ext_int_edge(H_TO_L);
set_timer0( 0 );
enable_interrupts( INT_TIMER0 );
enable_interrupts( GLOBAL );
while ( 1 ) {
set_adc_channel(2);
delay_us(10);
triac_dutty = read_adc();
Posted: Thu Sep 22, 2011 1:44 pm |
This is not real code. It doesn't compile. The compiler gives these errors:
Quote: |
*** Error 100 "pcm_test.c" Line 4(5,45): USE parameter value is out of range Unknown option: OSCILATOR
*** Error 12 "pcm_test.c" Line 19(11,12): Undefined identifier -- delay_us
*** Error 12 "pcm_test.c" Line 37(13,14): Undefined identifier -- delay_us |
You have misspelled "oscillator" (for CCS), which makes the compiler
not accept the #use delay() statement, so it won't allow delay_us().
You don't need to have all 3 parameters in the #use delay() statement.
Since you have INTRC, that tells the compiler you want the internal
oscillator. In this case, you only need to put in a "clock=4M" parameter.
Also, if you want to use the oscillator pins for i/o, you should specify
the INTRC_IO fuse. Example:
#include <12F675.h>
#fuses INTRC_IO, NOMCLR
#use delay(clock=4M )
Also you never call the setup_adc_ports() function. You're trying to use
AN2 as an analog pin, but it's still in digital mode. That's not correct.
Add this line near the start of main():
setup_adc_ports(sAN2);
freesat
Only triac fire on incorrect time on waveform |
Posted: Thu Sep 22, 2011 5:29 pm |
Hi PCM Programer, thanks for reply...
in fact i dont put full code, but it compile and run ok, all interrupts are working as spected and also adc read too, triac fire on incorrect time on waveform, i dont have a scope to check this.
i put this line Code: | #use delay(clock=4M, oscilator=4M, int=4M ) | because i have some calculations like this and only putting int=4M doenst work. is not misspell and with me works fine ( i build on old version, 4.114, but i will downlaod and install an update )
Code: | SPBRG=(((getenv("CLOCK")/250000)/16)-1); |
will be nice, if getenv can get values from ( oscilator and int ) too. i use getenv a lot, because code is more smart and i can switch PIC Model at any time without modify code.
this is all code im trying now. ( note: Serial routines removed, because this PIC doenst have USART )
#include <12F675.h>
#device adc=8;
#fuses INTRC_IO, NOMCLR, NOPROTECT, BROWNOUT, NOPUT
#use delay( clock=4M, oscilator=4M, int=4M )
#use fast_io(A)
#zero_ram
#define PORT_zero PIN_A2
#define PORT_adc PIN_A4
#define PORT_triac PIN_A5
#int_EXT
if ( triac_dutty < 255 ) { output_low( PORT_triac ); }
#int_TIMER0
set_timer0( 0 );
delay_us(600);
if ( triac_dutty >0 ) { output_high( PORT_triac ); }
void main( void ) {
int8 tmp;
set_tris_a( 0b011111 );
setup_adc_ports(sAN3);
setup_adc(ADC_CLOCK_INTERNAL );
set_timer0( 0 );
while ( 1 ) {
set_adc_channel(3);
delay_us(15);
tmp = read_adc();
if ( tmp != triac_dutty ) { triac_dutty = tmp; }
edit: correcting type error. |
