floats and printf()
Pere Riu
floats and printf()
PostPosted: Wed Oct 30, 2002 7:52 am     Reply with quote
HI,
I am using printf so display floating point numbers in a LCD:
printf(lcd_putc,"\%05.2f",myfloat);
but I never get leading "0" or leading white spaces to fill up the requested 5 characters. i.e. if the number is 5.32 I get
"5.32" instead of "005.32" or " 5.32".
Any ideas ?.
Pere
___________________________
Original Post ID: 8292
nilsener
Re: floats and printf()
PostPosted: Wed Oct 30, 2002 12:01 pm     Reply with quote
Dear,
suggestion:
1. convert the float to a string
sprintf(string, "\%5.2f", myfloat); //convert float to string
// string should be '5.32'
2. find the position of '.' in the string
ptr = &string[0]; //set pointer to beginning of string
ptr1 = strchr(string,'.'); //find '.' in string
k = ptr1 - ptr; //calculate absolute position of '.'
// k should be 1 in this case;
3. build a second string with the leading zeros
if (k == 1) strcpy(string2,"0000");
if (k == 2) strcpy(string2,"000");
if (k == 3) strcpy(string2,"00");
3. concatenate string ('5.32') onto string2 ('0000')
strcat (string2, string);
now string2 should contain '00005.32'
printf(lcd_putc,string2);
Maybe it works ?
regards nilsener
:=HI,
:=I am using printf so display floating point numbers in a LCD:
:=printf(lcd_putc,"\%05.2f",myfloat);
:=but I never get leading "0" or leading white spaces to fill up the requested 5 characters. i.e. if the number is 5.32 I get
:="5.32" instead of "005.32" or " 5.32".
:=Any ideas ?.
:=Pere
Original Post ID: 8305
pere riu
PostPosted: Wed Oct 30, 2002 3:47 pm     Reply with quote
Thanks ! That's what I am doing right now. Simply I was expecting something more clever from the compiler side.
Pere
:=Dear,
:=suggestion:
:=1. convert the float to a string
:=sprintf(string, "\%5.2f", myfloat); //convert float to string
:= // string should be '5.32'
:=2. find the position of '.' in the string
:=ptr = &string[0]; //set pointer to beginning of string
:=ptr1 = strchr(string,'.'); //find '.' in string
:=k = ptr1 - ptr; //calculate absolute position of '.'
:= // k should be 1 in this case;
:=3. build a second string with the leading zeros
:=if (k == 1) strcpy(string2,"0000");
:=if (k == 2) strcpy(string2,"000");
:=if (k == 3) strcpy(string2,"00");
:=3. concatenate string ('5.32') onto string2 ('0000')
:=strcat (string2, string);
:=now string2 should contain '00005.32'
:=printf(lcd_putc,string2);
:=Maybe it works ?
:=regards nilsener
:=:=HI,
:=:=I am using printf so display floating point numbers in a LCD:
:=:=printf(lcd_putc,"\%05.2f",myfloat);
:=:=but I never get leading "0" or leading white spaces to fill up the requested 5 characters. i.e. if the number is 5.32 I get
:=:="5.32" instead of "005.32" or " 5.32".
:=:=Any ideas ?.
:=:=Pere
Original Post ID: 8316
PaulF
PostPosted: Sat May 23, 2009 6:19 am     Reply with quote
Pere Riu wrote:
I am using printf so display floating point numbers but I never get leading "0"
printf("%5.2f",myfloat);
I have the same problem, my workaround is
printf("%05s", sprintf("%.2f",myfloat));
PostPosted: Sun May 24, 2009 2:34 am     Reply with quote
The 'reason', is that the field length being specified is too short for the required leading zeros to be displayed.
In C, the field length (the bit on the left of the decimal), is for the _entire_ output field. This includes the decimal point, the trailing digits, and the leading location for the sign. To display three digits in front of the decimal, with two digits after, you would need to use a field specifier of %07.2f.
