Accelerometer calibrate problem
Classic
PostPosted: Tue Sep 13, 2011 12:12 pm     Reply with quote
Hi, I have a problem about accelerometer MMA7455L and PIC18F2620 with SPI 4 wire in measurement mode. When I showed in LCD at ground plane the results are "XYZ:255 243 78" what's happen?
What do you think? Thank you.
http://www.ccsinfo.com/forum/viewtopic.php?t=37562
http://cache.freescale.com/files/sensors/doc/app_note/AN3745.pdf
http://www.freescale.com/files/sensors/doc/app_note/AN3468.pdf
#include <18F2620.h>
#fuses HS,NOPROTECT,NOWDT,NOLVP
#define use_portb_lcd
#include <lcd.c>
#define XOUT8  0x06
#define YOUT8  0x07
#define ZOUT8  0x08
#define STATUS 0x09
#define I2CAD  0x0D
#define MCTL   0x16
#define XOFFL  0x10     //16  Offset drift X value (LSB) (Read/Write)
#define XOFFH  0x11     //17  Offset drift X value (MSB) (Read/Write)
#define YOFFL  0x12     //18  Offset drift Y value (LSB) (Read/Write)
#define YOFFH  0x13     //19  Offset drift Y value (MSB) (Read/Write)
#define ZOFFL  0x14     //20  Offset drift Z value (LSB) (Read/Write)
#define ZOFFH  0x15     //21  Offset drift Z value (MSB) (Read/Write)
#define Acc_CS   PIN_C2
#define DRDY PIN_C0
#define SPI_MODE_0  (SPI_L_TO_H | SPI_XMIT_L_TO_H)
#define SPI_MODE_1  (SPI_L_TO_H)
#define SPI_MODE_2  (SPI_H_TO_L)
#define SPI_MODE_3  (SPI_H_TO_L | SPI_XMIT_L_TO_H)
void Acc_init(void);
void Acc_wr(char reg, char dat);
signed char Acc_rd(char reg);
void Calibrate(char Gselect);
void Data_Ready();
void Calibrate(char G_Select)
   signed int offs_calib[3]  ;     //keep Value offset X,Y,Z for Calibrate reg.XOFFL-H,YOFFL-H,ZOFFL-H
   signed int offs_ave[3]    ;      //keep Value offset X,Y,Z for Average
   signed char offs_meas[3]  ;       //keep Value offset X,Y,Z for Measurment currunt
   char cnt_run=0,res=0,m,n  ;
   for(m=0;m<3;m++)
     offs_calib[m]=0         ;     //Clear
    Acc_wr(0x16,0x01|(G_Select<<2))  ; //Set up MMa7455L Mode:Measurement
   while((cnt_run++ < 55)&& (res==0))                     //Loop Calibrate Offset 55 time
     for(m=0;m<3;m++)
        offs_ave[m]=0                         ;  //Clear
     for(m=0;m<4;m++)                            //Loop Filter Read data 4 time
        Data_Ready()                          ;  //Check INT1 Conver data Ready ?
       offs_meas[0] = Acc_rd(0x06);                    //Read data Output 8 bit GX
       offs_meas[1] = Acc_rd(0x07);                    //Read data Output 8 bit GY
       offs_meas[2] = Acc_rd(0x08);                    //Read data Output 8 bit GZ
       for(n=0;n<3;n++)
         offs_ave[n] += offs_meas[n]         ;  //Total value GX,GY,GZ from reading 4 time
     for(m=0;m<3;m++)
       offs_ave[m] /= 4                       ;  //Calculate Average for GX,GY,GZ
     if(G_Select == g_2)                       //---- If Select Calibrate Mode 2G (8bit) ----
        offs_ave[2]  -= 0x3F                  ;  //sub value GZ by 63(0x3F) when Z-Axist =1G=63
     if(G_Select == g_4)                       //---- If Select Calibrate Mode 4G (8bit)----
        offs_ave[2]  -= 0x1F                  ;  //sub value GZ by 31(0x1F) when Z-Axist =1G=31
     if(G_Select == g_8)                      //---- If Select Calibrate Mode 8G (8bit)----
        offs_ave[2]  -= 0x0F                  ;  //sub value GZ by 15(0x0F) when Z-Axist =1G=15
     for(m=0;m<3;m++)
        if(offs_ave[m]==0)                    //Check Value Average GX,GY,GZ =0
          res++                              ;
     if(res >= 3)                            //if Average GX and GY and GZ =0 Give res=1 Exit Loop While
       res=1 ;
       for(n=0;n<3;n++)
          offs_ave[n] += 1                   ;
       res =0                                 ; //if Average GX and GY and GZ != 0 Give res=0 Return Read GX,GY,GZ
    for(m=0;m<3;m++)
       offs_calib[m] -= offs_ave[m]           ;
    Acc_wr(0x10,offs_cal[0]/256);                  //Write value Calibrate offset byte Low to Reg. XOFFL
    Acc_wr(0x11,offs_cal[0]%256);                  //Write value Calibrate offset byte HGigh to Reg. XOFFH
    Acc_wr(0x12,offs_cal[1]/256);                  //Write value Calibrate offset byte Low to Reg. YOFFL
    Acc_wr(0x13,offs_cal[1]%256);                  //Write value Calibrate offset byte HGigh to Reg. YOFFH
    Acc_wr(0x14,offs_cal[2]/256);                  //Write value Calibrate offset byte Low to Reg. ZOFFL
    Acc_wr(0x15,offs_cal[2]%256);                  //Write value Calibrate offset byte HGigh to Reg. ZOFFH
   output_low(Acc_CS);
   spi_write(((reg & 0x3F) << 1) | 0x80);
   spi_write(dat);
   output_high(Acc_CS);
   signed char dat;
   output_low(ACC_CS);
   spi_write((reg & 0x3F) << 1);
   dat = spi_read(0);
   output_high(ACC_CS);
return(dat);
void Data_Ready()
  while((input(DRDY)& 0x01) != 0x01){;}
//*************************main********************
main(void)
   int Xdata,Ydata,Zdata;
   set_tris_b(0x00);
   set_tris_c(0x11);
   setup_spi(SPI_MASTER|SPI_MODE_0|SPI_CLK_DIV_16);
   Calibrate(0x02);//01,02,00
   Acc_wr(0x16,0x05); //05,09,01
   lcd_send_byte(0,0x01);
   lcd_gotoxy(2,1);
   lcd_putc("Measurement 2G");
      Data_Ready();
      Xdata = Acc_rd(0x06);
      Ydata = Acc_rd(0x07);
      Zdata = Acc_rd(0x08);
      lcd_gotoxy(2,2);
      printf(lcd_putc,"XYZ:%u %u %u ",Xdata,Ydata,Zdata);
PostPosted: Tue Sep 13, 2011 4:20 pm     Reply with quote
Your calibration routine is complex. Do you know for sure that it works ?
Why don't you try it without calling the calibration routine, and see what
kind of values you get. Comment it out:
// Calibrate(0x02); //01,02,00
In the MMA7455L data sheet, in Table 13, it says these are the expected
output values for a given acceleration. Note that the values are signed.
2g Mode
      Hex     Decimal
Acc.  Output  Output
-2g   $80     -128
-1g   $C1      -63
 0g   $00        0
+1g   $3F       63
+2g   $7F      127
In the code below, you have declared the X, Y, Z data variables as 'int',
which is an unsigned 8-bit integer in CCS. But it's supposed to
be signed. Change the declaration to 'signed int8'.
Then in the code below, you are displaying the results as unsigned
decimal values. So if the result was say, -1, which is a very small
acceleration, your code would display it as 255, and you would wonder
what is happening. You need to change the format to "%d".
Also, the size of the displayed number can vary from 1 to 3 characters,
and it could have a minus sign. Because you don't clear the screen
each time, you could have residual characters on the right side of the
lcd after each update. This would cause confusion about the true value
of the Z acceleration. You can fix this by putting \f in front of the XYZ
in the format string. This will clear the lcd screen each pass.
Data_Ready();
lcd_gotoxy(2,2);
