Pwm duty cycle strange behaviour!
acm45
PostPosted: Fri Sep 09, 2011 1:34 pm     Reply with quote
Hi there!
I'm doing a small motor control with the classic H bridge controlled by a 18F4550 pic (with 20MHz and HSPLL active).
It works really well but, I noticed a strange behaviour, here's the code!
setup_timer_0(RTCC_INTERNAL|RTCC_DIV_256|RTCC_16_BIT);
   setup_timer_2(T2_DIV_BY_1,0xff,1);      //25.0 us overflow, 25.0 us interrupt per generare la portante PWM 46kHz
   setup_ccp1(CCP_PWM);   // Configure CCP1 as a PWM
   setup_ccp1(CCP_PWM_FULL_BRIDGE | CCP_PWM_H_H |CCP_SHUTDOWN_ON_INT0|CCP_SHUTDOWN_AC_L|CCP_SHUTDOWN_BD_L);
   set_tris_d(0x1F);
   set_tris_d(0x02);
   set_pwm1_duty((int16)0x000F);
The last instruction gives me a duty cycle of 0%!!!
If I write values from 0x000C to 0x000F I obtain the same wrong duty cycle!!! Moreover if the last 4bits have a value between 0xC and 0xF, the duty cycle is always 0%!
Writing 0x000A I obtain a duty cycle of 0.9% as expected!
I see the pwm registers and seem all ok with the right value as described in the datasheet.
Thank you in advance for your help!
PostPosted: Fri Sep 09, 2011 1:45 pm     Reply with quote
What's your compiler version ?
acm45
PostPosted: Fri Sep 09, 2011 1:51 pm     Reply with quote
The compiler version is: 4.114
PostPosted: Fri Sep 09, 2011 2:21 pm     Reply with quote
I put this code in a standard small template with #include, #fuses, #use
delay, and main(), and it doesn't compile with vs. 4.114. The last
parameter is not in the 18F4550.h file. Therefore this is not real code.
Please post real tested code, with the #include, #fuses, #use delay(),
and main().
Edit: Corrected a typo. I meant to say "not real code".
acm45
SOLVED
PostPosted: Sun Sep 11, 2011 2:39 am     Reply with quote
sorry for the parameter RTCC_16_BIT, I defined it into my 18F4550.h file as a 0x00. Anyway, I find the problem in my own code, setting the pwm duty cycle I was setting also the reverse bridge control.
Thank you for your help!
