Defined ROM location for built in macros
LFern
PostPosted: Mon Sep 05, 2011 12:54 am     Reply with quote
Hi Everyone,
I am trying to use delay_ms() built in macro function in defined ROM addresses.
The requirement is to put the complete program in between a defined rom area. All the other functions are custom and I can use #org for main().
Any idea?
PostPosted: Mon Sep 05, 2011 1:52 am     Reply with quote
If you specify an #org for your code, including a default, and a clock statement, then the delay code will be put inside the area specified by the org, with your other code. Then when you have completed your section, have another #org, and another clock statement, and future delays will be located in the new range. This is how a bootloader has a delay if used, that is inside the bootloader range, rather than with the other code.
LFern
PostPosted: Tue Sep 06, 2011 7:10 pm     Reply with quote
Thanks Ttelmah, I got it worked!
