rate of task
ROBOTICAR
rate of task
PostPosted: Sun Aug 28, 2011 1:10 pm     Reply with quote
hi
I just begin using RTOS in my programs. I need to change the rate of my task. How can I do it? Is there any way or the rate of task is a constant and I can't change it?
PostPosted: Sun Aug 28, 2011 1:39 pm     Reply with quote
Download the CCS manual and put it on your desktop:
http://www.ccsinfo.com/downloads/ccs_c_manual.pdf
Look in the section on #task. It lists the parameters you need.
ROBOTICAR
PostPosted: Sun Aug 28, 2011 2:17 pm     Reply with quote
I have memorized it ! But I want change the rate of task after starting program. For example I want read an integer from rs232 and put it as rate of my task. Is there any way ?
