PIC24HJ (12GP202) and I2C
korghs
PostPosted: Fri Aug 26, 2011 11:45 am     Reply with quote
Hi there,
I'm quite new to this Compiler and the PIC24HJ12GP202 and I'm actually stuck at the most stupid point, right at the beginning!
The aim is to simply communicate by I²C
#include <24HJ12GP202.h>
#use i2c(i2c1,Master,Slow,force_hw)
    output_high(pin_b15);
while (1)
    output_high(pin_b14);
    i2c_start();
    delay_ms(50);
    i2c_write(0xAA);
    delay_ms(50);
    i2c_stop();
    output_low(pin_b14);
Watching each pin used, with an oscilloscope, b15 sticks to high, b14 jumps as wanted, but I've got absolutely no signal on b9(18/SDA1) or b8(17/SCL1).
Have I missed anything in the datasheet/ccs c docs?
Thanks!
P.S.
I'm currently running the limited eval of 4.122d.
korghs
PostPosted: Fri Aug 26, 2011 2:21 pm     Reply with quote
#use i2c(master, sda=pin_b9, scl=pin_b8)
seems to be the easiest way to solve my problem.
Also played around with the pull-ups on sda and scl, got both down to 1.8k.
PostPosted: Fri Aug 26, 2011 2:47 pm     Reply with quote
It's entirely possible that 'i2c1' and/or 'force_hw' uses the wrong pins or
the wrong registers in your version of the compiler. Using software i2c, as
you found, has a much better chance to work.
korghs
PostPosted: Sat Aug 27, 2011 3:43 am     Reply with quote
Interesting,
got down to
#use i2c(master, sda=pin_b9, scl=pin_b8, slow, force_hw)
Seems to work, too
