GLCD Working Except Problem On Proteus
haronraziq
PostPosted: Thu Aug 25, 2011 4:45 pm     Reply with quote
I have some code that I am using (mainly glcd library stuff) but whenever I run this code on proteus, it gives me logic contention error. The pins seems to be random and change whenever I open and close proteus.
Does anyone know what is going on???
Here is my code:
////                           HDM64GS12.c                           ////
#ifndef HDM64GS12
#define HDM64GS12
#ifndef GLCD_WIDTH
#define GLCD_WIDTH   128
#ifndef GLCD_CS1
#define GLCD_CS1     PIN_A1   // Chip Selection 1
#ifndef GLCD_CS2
#define GLCD_CS2     PIN_A0   // Chip Selection 2
#ifndef GLCD_DI
#define GLCD_DI      PIN_A2   // Data or Instruction input
#ifndef GLCD_RW
#define GLCD_RW      PIN_A3   // Read/Write
#ifndef GLCD_E
#define GLCD_E       PIN_A4   // Enable
#ifndef GLCD_RST
#define GLCD_RST     PIN_A5   // Reset
#define GLCD_LEFT    0
#define GLCD_RIGHT   1
#ifndef ON
#define ON           1
#ifndef OFF
#define OFF          0
#include <16f877.h>
#FUSES NOWDT                    //No Watch Dog Timer
#FUSES HS                       //Crystal osc <= 4mhz for PCM/PCH , 3mhz to 10 mhz for PCD
void glcd_init(int1 mode)
   // Initialze some pins
   output_high(GLCD_RST);
   output_low(GLCD_E);
   output_low(GLCD_CS1);
   output_low(GLCD_CS2);
   output_low(GLCD_DI);                 // Set for instruction
Another graphics file
////                          graphics.c                             ////
CCS Driver files mostly deleted.
Reason: Forum rule #10
10. Don't post the CCS example code or drivers, or ask for such code and drivers.
Forum rules:
http://www.ccsinfo.com/forum/viewtopic.php?t=26245
-- Forum Moderator
dyeatman
PostPosted: Thu Aug 25, 2011 5:08 pm     Reply with quote
Sounds like yet ANOTHER Proteus problem! I recommend you go to the
Proteus site and ask them since it is likely NOT a CCS problem.
Google and Forum Search are some of your best tools!!!!
haronraziq
PostPosted: Thu Aug 25, 2011 5:31 pm     Reply with quote
Interesting development, if I switch the LCD port to PORTB it works like a charm. Why is this?
The problem is, then I will not be able to freely program the microcontroller. Does anyone know if Pickit programmers, in particular the canakit programmer supports high voltage programming?
dyeatman
PostPosted: Thu Aug 25, 2011 5:36 pm     Reply with quote
Yes they are "high voltage" programmers.
As for Port B, did you add a pullup to A4 and turn off the ADCs?
haronraziq
PostPosted: Thu Aug 25, 2011 5:40 pm     Reply with quote
Yeah I added the pullup on A4 but I am actually trying to move those ports to something else because I want to use the analog ports for another part of my circuit.
