help setting pwm4 to PIC16F1939
lboghy
PostPosted: Wed Aug 24, 2011 10:32 am     Reply with quote
Hello
Can anyone help me with setting the pwm4 at pic16f1939. I done as at others micros but is doing only the envelope - during the pwm on it goes to high and if I disable the pwm output goes to low.
   #use delay(int=16000000)
   setup_timer_2(T2_DIV_BY_1,104,1);      //26.2 us overflow
   CCPTMRS0 = 0X00;  //set timer 2 for pwm4
   setup_ccp4(CCP_PWM);
   set_pwm4_duty(210);  //for 50%
   //setup_ccp4(CCP_OFF);
Thank you.
PostPosted: Wed Aug 24, 2011 11:11 am     Reply with quote
During the pwm on it goes to high and if I disable the pwm output goes to low.
Read the links in the thread below about the difference between 8-bit and
10-bit PWM modes, and how to tell the compiler which mode to use:
http://www.ccsinfo.com/forum/viewtopic.php?t=45968
lboghy
SOLVED
PostPosted: Wed Aug 24, 2011 3:40 pm     Reply with quote
I just added an "L"...
Thank you very much for you prompt support. Best wishes!
