Mystical long long datatype behaviour
DeniTCH
PostPosted: Tue Aug 09, 2011 5:55 am     Reply with quote
Hi, I am currently experiencing quite strange behavior when using variables of the long long type.
My compiler version is: 4.104, I am using PIC18F6680 with the following configuration:
// Configuration bits
#pragma fuses HS         // Use external crystal as clock source
#pragma fuses NOWDT         // Disable watchdog timer
#pragma fuses NOPROTECT      // Don't read/write protect program memory
// Compiler magic
#pragma use rs232(BAUD=19200, BITS=8, STOP=1, PARITY=N, XMIT=PIN_TX, RCV=PIN_RX)
#pragma use spi(BITS=8)
The problem is summarized in the following code:
#include "system.h"
typedef unsigned long long DPULONG;
DPULONG testfunc()
   DPULONG ret = 0x69736544;
   printf("\r\nret=0x%LX",ret);
   return ret;
   DPULONG i,j;
   unsigned long long cnt;
   init();
   setup_spi(SPI_MASTER | SPI_H_TO_L | SPI_XMIT_L_TO_H | SPI_CLK_DIV_4 );
   printf("%c[2J",0x1B);
   printf("DTUsat-PPL Test\r\n");
   i = testfunc();
   j = 0 | testfunc();
   printf("\r\ni=0x%LX,j=0x%LX,direct=0x%LX",i,j,testfunc());
The terminal output of this code is:
DTUsat-PPL Test
ret=0x69736544
ret=0x69736544
ret=0x69736544
i=0x34343434,j=0x69736544,direct=0x69730000
I am expecting i,j and the direct function result to print the same number, however it does not. Is there anything I am misunderstanding regarding the long long datatype? I am looking forward to any responses to this issue! Smile
Best regards
Denis
PostPosted: Tue Aug 09, 2011 8:19 pm     Reply with quote
You didn't post a compilable test program, so I added or commented out
whatever was required to make it compile. I installed vs. 4.104 and ran
it in MPLAB simulator. It works. This is the result in the Output window:
ret=0x69736544
ret=0x69736544
ret=0x69736544
i=0x69736544,j=0x69736544,direct=0x69736544
Here is part of the build results and .LST file:
Executing: "C:\Program Files\PICC\Ccsc.exe" "PCH_Test.c" +FH +DF +LY -T -A +M -Z +Y=9 +EA -EW
      Memory usage:   ROM=1%      RAM=1% - 1%
      0 Errors,  0 Warnings.
Loaded C:\Program Files\PICC\Projects\PCH_Test\PCH_Test.cof.
BUILD SUCCEEDED: Tue Aug 09 19:16:23 2011
CCS PCH C Compiler, Version 4.104, xxxxx     09-Aug-11 19:16
               Filename: C:\Program Files\PICC\Projects\PCH_Test\PCH_Test.lst
               ROM used: 600 bytes (1%)
                         Largest free fragment is 64936
               RAM used: 20 (1%) at main() level
                         23 (1%) worst case
               Stack:    2 locations
This is the test program:
#include <18F6680.h>
#use delay(clock=20M)
// Compiler magic
#pragma use rs232(BAUD=19200, BITS=8, STOP=1, PARITY=N, XMIT=PIN_C6, RCV=PIN_C7)
//#include "system.h"
DPULONG testfunc()
   return ret;
   DPULONG i,j;
//   init();
   i = testfunc();
   j = 0 | testfunc();
DeniTCH
PostPosted: Wed Aug 24, 2011 6:57 am     Reply with quote
I have found the error, which of course was on my side. Embarassed The length of the "long" datatype was redefined higher in the build system, which we are using. As it was not written by me I had no idea. I am sorry for the inconvenience.
PostPosted: Wed Aug 24, 2011 9:19 am     Reply with quote
This is one reason I prefer to be 'explicit' with data type sizes. The forms, int8, int16, and int32, are self documenting, and avoid using constructs like 'long long', which may have different meanings in other compilers, and can give problems if re-defined.....
Glad you have found it.
DeniTCH
PostPosted: Fri Aug 26, 2011 1:26 am     Reply with quote
I have also decided to use the 'explicit' datatypes now, for exactly that reason. Trust no one, except yourself Wink
