Accelerometer + 18F46J50 not work
Classic
PostPosted: Tue Aug 23, 2011 1:09 pm     Reply with quote
I'm newbie for CCS. This code compile pass but not output in oscilloscope. Code what's wrong. Can you help me?
#include <18F46J50.h>
#fuses HS,NOPROTECT,NOWDT,NOLVP
//************************************************************MMA7455 reg define
#define XOUT8         0x06
#define YOUT8         0x07
#define ZOUT8         0x08
#define MCTL          0x16     //4g, measurement mode,SPI 4wire  =0x09
//***********************************MMA7455_SPI PIN define
#define MMA7455_CS   PIN_A5   //0
#define MMA7455_CLK  PIN_B4   //0
#define MMA7455_SDI  PIN_B5   //0
#define MMA7455_SDO  PIN_C7   //1
#define MMA7455_INT1 PIN_B0   //1 DRDY
//**************************SPI_write data to MMA7455
void spi_write(char addr)
char a;
  for(a=0;a<8;a++)                  // loop 8 bit
   if((addr & 0x80)== 0x80)         //check data bit 8 w=1 r=0
      output_high(MMA7455_SDO);    //Sent 1 to SDO
      output_low(MMA7455_SDO);     //Sent 0 to SDO
      output_high(MMA7455_CLK);
      output_low(MMA7455_CLK);
      addr<<=1;                     //Shift data Next Bit
//******************************write_Acc value for set up MMA7455
void write_Acc(char reg,char dat)   //reg(reg for write),dat(set up Acc)
   output_low(MMA7455_CS);         //from timing
   spi_write(((reg&0x3F)<<1)|0x80); //write address data for write to SPI(th guide)
   spi_write(dat);                  //Write data to SPI
   output_high(MMA7455_CS);
//********************************************SPI_read
char spi_read(char reg)
  char a,result=0;
  for(a=0;a<8;a++)                 //write reg for read(SDO)
   if((reg & 0x80)== 0x80)         //check data bit 8 w=1 r=0
      reg <<= 1;
  for(a=0;a<8;a++)        //read data(SDI)
    result <<= 1;
    if((MMA7455_SDI && 0x08)== 0x08)    //If SDI = "1"
      result |= 0x01;                   //Keep Result of data-Read
return(result);                  //Return data
//******************************read_Acc data
signed char read_Acc(char reg)
   signed char dat;
   dat=spi_read(((reg&0x3F)<<1));      //Write address command for read to SPI Accelerate
   return(dat);
//************************************Check status ready
void data_ready()
  while((MMA7455_INT1&&0x01) != 0x01){;}  //Check Data Ready exit loop
void Acc_init(void)
   set_tris_b(0xFF);
   set_tris_c(0x20);
   setup_spi(SPI_MASTER|SPI_H_TO_L|SPI_XMIT_L_TO_H|SPI_CLK_DIV_16);
   write_Acc(MCTL,0x09);         //4g,meas,4wire
//*************************main********************
   int Xdata,Ydata,Zdata;
   Acc_init();
   data_ready();
   Xdata = read_Acc(XOUT8);
   Ydata = read_Acc(YOUT8);
   Zdata = read_Acc(ZOUT8);
PostPosted: Tue Aug 23, 2011 1:28 pm     Reply with quote
Look at the .LST file. The compiler is ignoring your spi_write() and
spi_read() functions because you gave them the same names as the
built-in CCS functions. If you want it to use your functions, change
the names slightly. You could call it my_spi_write(), or spi_wrt() and
spi_rd().
Also, if you want to use your own software spi functions, then don't
call the setup_spi() function.
Also, you don't need to set the TRIS. The compiler will do it for you.
