Pulse counter affected by delay in LCD write
nickomalley
PostPosted: Tue Aug 16, 2011 3:44 pm     Reply with quote
Would it be possible to have a look at the following code, I have this working fine counting pulses without a problem.
With the LCD running and no delay after the printf the fastest pulse it can count is approx 120Hz, if I comment out the printf it can count a significantly faster pulse (low kHz), if I put in the recommended 200ms delay after the printf it struggles to read pulses faster than 10hz.
Is there a more efficient way to write this to the LCD?
thanks for any help
Nick
#include <16f877.h>
#device *=16
#fuses   HS,NOPROTECT,PUT,BROWNOUT,NOLVP,NOWDT
#use delay (clock=20000000) //Set clock rate of 10Mhx - needed for rs232 commands
#include <lcd.c>
#include <ds1621.c>
/* Use #byte to assign variables to a RAM locations */
#byte   PORT_B=6          //this is the port the motors are on
unsigned int16 counter;         // count variable for pulse counter
unsigned int occurrence;         //count how many time 0 was recorded, only want to count if equal to 1
enum pin0_portb {pin1=PIN_B1};
#define OFF  0 //IR receiver connected to ground
#define ON  1 //IR receiver connected to ground
void clear_some_pins () {
//Resets state variables allowing a new message to be received.
void testlcd()
printf(LCD_PUTC, "\fHarry is COOL");
printf(LCD_PUTC, "\nCheese is nice 2");
delay_ms(3000);
///////////////////////// Main ////////////////////////
  void main ()
  lcd_init();
  delay_ms(6);
  printf(LCD_PUTC, "\f");    //clear the lcd
  testlcd();
 //port_b_pullups(TRUE);
    occurrence=0;
    counter = 0;   //reset the counter variable on program start
    set_tris_b(0b00000000); // define B as all inputs except int port
   while (true)
  if(input_state(pin_A4)==OFF) //check if the pin is held high eg 5volts internal pullups
   occurrence=0;             //if it is, reset the occurence to 0
    bit_clear(PORT_B,1);      // Turn LED off
   if  (input_state(pin_A4)== ON)
          if (occurrence ==255)  // this is necessary as it will overflow to 0 and pass the test below, which doesn't help
               occurrence = 2;
              occurrence++;
              if (occurrence<=1)
                counter++;
                   bit_set(PORT_B,1);  //Turn LED connected to this pin ON to show count happened
printf(lcd_putc,"\fWinding counter:  F\nTurns\1 %6lu",counter);
//delay_ms(200);
PostPosted: Tue Aug 16, 2011 3:53 pm     Reply with quote
The majority of your LCD text doesn't have to be written every time.
Just write it once before the loop starts. Then at the end of the loop,
use lcd_gotoxy() to put the lcd cursor in the correct position to display
your number. Then just update the number on the lcd.
The comment doesn't match the parameter.
Wilksey
PostPosted: Tue Aug 16, 2011 5:08 pm     Reply with quote
The clock doesn't match the comment either.
nickomalley
PostPosted: Wed Aug 17, 2011 3:34 am     Reply with quote
Thanks for this i'll give it a go.
re printf(lcd_putc,"\fWinding counter: F\nTurns\1 %6lu",counter);
is there a more efficient way of sending this to the lcd, i read somewhere that printf is very processor time hungry
Re the errors in the clock and tris I apologise, Embarassed its my sloppy commenting.
I tend to copy code from other programs and tweak as necessary but sometimes forget to update the comments
Wilksey
PostPosted: Wed Aug 17, 2011 12:50 pm     Reply with quote
You can do as PCM suggested.
you can use fputc on individual characters, not sure how much you will save with that, or you can write / read the registers directly.
All about trying what is the best solution for your setup.
nickomalley
PostPosted: Wed Aug 17, 2011 3:23 pm     Reply with quote
Thanks I'll give it a go and post outcome to the forum
regards
Nick
