Loop problem
assimhussain
Loop problem
PostPosted: Fri Aug 12, 2011 2:40 am     Reply with quote
I have a strange problem with loop..
for the code below the program does not pick the while loop.. I tried to run in debug mode with animation n the arrow stops at step
}while(1);
it keeps on executing at while(1); but doesnt go into the loop..
it was working perfect untill today... I cant figure it out what happend.. could any1 help pls..
#include <16F917.h>
#device ADC=8
//#use delay(clock=4000000)
unsigned int vin0;
int x=0;
setup_adc_ports(ALL_ANALOG);
set_adc_channel(0);
 //delay_ms(500);
 vin0=read_adc();
 Output_B(0xFF);
 setup_ccp2(ccp_pwm);
 set_pwm2_duty(vin0);
 setup_timer_2(T2_DIV_BY_16,255,1);
}while(1);
PostPosted: Fri Aug 12, 2011 3:32 am     Reply with quote
The simple reason, is that the syntax is wrong.....
executes the ';' while the value in the brackets is true. You have created a 'while' loop containing nothing.
You want to create a loop containing your code. so either:
while(1) {
   code
which executes the section in brackets 'while' the condition is true, or
do {
   code
} while(1);
Key thing missing, is the 'do' without this, the bracketed section is evaluated once, then the while loop at the end, is executed for ever.
It _is_ executing the loop. It is just that the loop contains nothing...
RF_Developer
Re: Loop problem
PostPosted: Fri Aug 12, 2011 3:33 am     Reply with quote
 //delay_ms(500);
 vin0=read_adc();
 Output_B(0xFF);
}while(1);
Because you've missed out the "do" at the beginning of the loop block. it should look like:
do {
 // loop code...
}while(1);
What you created was a block that executed once followed by a while loop with no code that never terminated.
RF_Developer
assimhussain
PostPosted: Fri Aug 12, 2011 4:27 am     Reply with quote
Thankx Smile
I didn't notice it. I was trying to use other loops and end up in some other problem, and came to conclusion that 'there is some problem with my loops'.
Huh.. hw stupid .. Surprised
Thank you very much for the help.
