How can I set a number for comparing with timer0???
setup_ccp1(CCP_COMPARE_RESET_TIMER); - this should set ccp1 to compare mode and when the numbers match to reset the timer.
setup_timer_0 (RTCC_DIV_8|RTCC_8_BIT); - this should set timer 0 to work with the oscillator divided by 8 and in 8 bit mode.
I suppose after that the timer should start counting, but how to set a value to cpp1 for comparison???
Can you give me a example???
Thanks!!
Posted: Thu Aug 11, 2011 1:03 pm
What PIC are you using ? All the PICs I know of, use Timer1 with the
CCP, not Timer0.
