wangine
Joined: 07 Jul 2009 Posts: 98 Location: Curtea de Arges, Romania
constrain.h library |
Posted: Wed Aug 10, 2011 1:46 pm |
Again a problem with structures.
The truth is that I'm not good at very little structure.
I wanted to use the library for constrain.h limits but without success.
I also found in the CCS or C30 depending only on Arduino.
I do not know how to do work in CCS.
I prefer to work and loan features that not only has to give the compiler.
Is there any way it could use in CCS?
Code: | constrain(K*(pTerm + iTerm + dTerm), -255, 255); |
Code: | /*
|| @file Constrain.h
|| @version 1.2
|| @author Alexander Brevig
|| @contact alexanderbrevig@gmail.com
|| @description
|| | Provide an easy way of making constrained variables
#ifndef CONSTRAIN_H
#define CONSTRAIN_H
//#include "WProgram.h"
template< typename T >
struct Constrained {
Constrained( T v , T mn , T mx ) : value(v),minimum(mn),maximum(mx) {}
T value; //hold the current value of the constrained variable
T minimum; //minimum value for this variable
T maximum; //maximum value for this variable
T &operator=(T set){
if (set<minimum){
value = minimum;
}else if (set>maximum){
value = maximum;
}else if (set<=maximum && set>=minimum){
value = set;
return value;
void operator=( Constrained& right ){
value = right.value;
minimum = right.minimum;
maximum = right.maximum;
Constrained &operator++(){
if (value+1<=maximum){ value++; }
return *this;
Constrained operator++( int ){
Constrained &operator--(){
if (value-1>=minimum){ value--; }
return *this;
Constrained operator--( int ){
const Constrained &operator+=( T val){
value += val;
value = constrain( value, minimum, maximum );
return *this;
const Constrained &operator-=( T val){
value -= val;
return *this;
bool operator<( const T i ) const{
return value < i;
bool operator<=( const T i ) const{
return !(value > i);
bool operator>( const T i ) const{
return value > i;
bool operator>=( const T i ) const{
return !(value < i);
bool operator==( const T i ) const{
return value == i;
operator T() { return value; }
operator int() { return value; }
operator byte() { return value; }
operator char() { return value; }
operator long() { return value; }
}; //end Constrained
#endif
|| @changelog
|| | 1.2 2009-05-01 - Alexander Brevig : Added boolean comarison operators
|| | 1.1 2009-05-01 - Alexander Brevig : Added conversion operators
|| | 1.0 2009-04-21 - Alexander Brevig : Initial Release
Thank you very much |
RF_Developer
Posted: Thu Aug 11, 2011 3:11 am |
This is a C++ header. It uses templates and operator overloading which are not in C. There is no way to do this in CCS which is a C compiler, not a C++ compiler.
Sorry
RF_Developer |
wangine
Posted: Thu Aug 11, 2011 10:40 am |
wow
And do not think is any way to convert this function in C?
I do not know C++ and are a little on the outside.
Thanks |
RF_Developer
Posted: Fri Aug 12, 2011 2:01 am |
"Provide an easy way of making constrained variables "
It is possible to get similar results, but it wouldn't be anywhere as "easy".
Templates are a powerful C++ feature and allow generic code to be defined that works on any compatible type and in this instance with any parameters (the constraint limits). The C++ compiler sorts out all the code you need. In C you have to write all the variations of the generic code yourself.
In C, you would have to use ordinary variables of the types you need and a set of functions to replace the operators. You couldn't just write c = a + b;, instead you'd have to do something like c = Constrained_Add(a, b) and have different versions of Constrained_Add for every combination of variable types and constraints you wanted to use. Though CCS does have overloaded functions that make that simpler, and deal with the alternative types more easily. That wouldn't take care of the different contraints however. Overloads are not C, they are "borrowed" from C++.
Anyway, its possible, but a lot of work, and no longer "easy"
The alternative is to think about why this template is needed, and how its used in the application, and write alternative code to perform the specific functionality you actually need.
RF_Developer |
wangine
Posted: Fri Aug 12, 2011 10:00 am |
Thanks for the answer first.
I think I made below is more or less enough for what I need me.
I still want to know if indeed those who did well and returns like the other.
We put extra "step" considering that me and you reach the maximum decrement variable.
I want an opinion from you.
float constrain(float val, float min, float max, float step)
if (val<min){
val = min;
}else if (val > max){
val = max;
}else if (val <= max && val >= min){
// val = con.value;
if (val+1 <=max ){ val += step; }
if (val-1 >=min ){ val -= step; }
return val;
x = constrain(value, -2080, 2080, 1.5f);
And I have a question
example means that the operations of these variables are the maximum of three decimal places?
were wrong?
Thanks again |
