Geps
Blank FPrintF Changes Configuration? |
Posted: Tue Aug 09, 2011 3:47 pm |
I'm writing a program for an 18f4520 using compiler version 4.087 and after commenting our various fprintf() (I have 2 s/w implemented uarts) that I used for debugging I noticed my program wasn't working.
Going through the program I've managed to narrow the problem down to an fprintf statement.
With the following statement:
the code works - despite it not actually printing anything. With it commented out the program hangs.
Looking through the listings, a side by side comparison reveals the following differences when the uart is getting configured:
Commented Out:
Code: | .................... // -------------------------------------------------------------------------- //
.................... #use RS232 (stream = TC, baud=9600, xmit=PIN_C6, rcv=PIN_C7, FORCE_SW, ERRORS)
0112: BSF F94.7
0114: BTFSC F82.7
0116: BRA 0114
0118: MOVLW 08
011A: MOVWF 00
011C: CLRF xCA
011E: BSF 00.7
0120: BRA 013E
0122: BCF 00.7
0124: BRA 013E
0126: BCF FD8.0
0128: BTFSC F82.7
012A: BSF FD8.0
012C: RRCF xCA,F
012E: BSF 00.6
0130: BRA 013E
0132: BCF 00.6
0134: DECFSZ 00,F
0136: BRA 0126
0138: MOVFF CA,01
013C: BRA 0168
013E: MOVLW 01
0140: MOVWF FE9
0142: MOVLW 00
0144: BTFSC 00.7
0146: MOVLW 55
0148: MOVWF 01
014A: DECFSZ 01,F
014C: BRA 014A
014E: DECFSZ FE9,F
0150: BRA 0142
0152: MOVLW 0D
0154: BTFSC 00.7
0156: MOVLW 03
0158: MOVWF 01
015A: DECFSZ 01,F
015C: BRA 015A
015E: BTFSC 00.7
0160: BRA 0122
0162: BTFSC 00.6
0164: BRA 0132
0166: BRA 0126
0168: GOTO 019A (RETURN)
.................... #use rs232(stream=TMS,baud=15625, xmit=PIN_C5, rcv=PIN_B0, INVERT, ERRORS)
01FA: BCF F94.5
01FC: BSF F8B.5
01FE: MOVLW 08
0200: MOVWF 01
0202: BRA 0204
0204: NOP
0206: BSF 01.7
0208: BRA 0226
020A: BCF 01.7
020C: RRCF xCF,F
020E: BTFSC FD8.0
0210: BCF F8B.5
0212: BTFSS FD8.0
0214: BSF F8B.5
0216: BSF 01.6
0218: BRA 0226
021A: BCF 01.6
021C: DECFSZ 01,F
021E: BRA 020C
0220: BRA 0222
0222: NOP
0224: BCF F8B.5
0226: MOVLW A4
0228: MOVWF FE9
022A: DECFSZ FE9,F
022C: BRA 022A
022E: BRA 0230
0230: BTFSC 01.7
0232: BRA 020A
0234: BTFSC 01.6
0236: BRA 021A
0238: RETLW 00
0332: BSF F93.0
0334: BTFSS F81.0
0336: BRA 0334
0338: MOVLW 08
033A: MOVWF 00
033C: CLRF xCF
033E: BSF 00.7
0340: BRA 035E
0342: BCF 00.7
0344: BRA 035E
0346: BCF FD8.0
0348: BTFSS F81.0
034A: BSF FD8.0
034C: RRCF xCF,F
034E: BSF 00.6
0350: BRA 035E
0352: BCF 00.6
0354: DECFSZ 00,F
0356: BRA 0346
0358: MOVFF CF,01
035C: BRA 0376
035E: MOVLW A4
0360: BTFSC 00.7
0362: MOVLW 2C
0364: MOVWF 01
0366: DECFSZ 01,F
0368: BRA 0366
036A: NOP
036C: BTFSC 00.7
036E: BRA 0342
0370: BTFSC 00.6
0372: BRA 0352
0374: BRA 0346
0376: GOTO 03A6 (RETURN)
Without it commented out:
0112: BSF F94.7
0114: BTFSC F82.7
0116: BRA 0114
0118: MOVLW 08
011A: MOVWF 00
011C: CLRF xCA
011E: BSF 00.7
0120: BRA 013E
0122: BCF 00.7
0124: BRA 013E
0126: BCF FD8.0
0128: BTFSC F82.7
012A: BSF FD8.0
012C: RRCF xCA,F
012E: BSF 00.6
0130: BRA 013E
0132: BCF 00.6
0134: DECFSZ 00,F
0136: BRA 0126
0138: MOVFF CA,01
013C: BRA 0168
013E: MOVLW 01
0140: MOVWF FE9
0142: MOVLW 00
0144: BTFSC 00.7
0146: MOVLW 55
0148: MOVWF 01
014A: DECFSZ 01,F
014C: BRA 014A
014E: DECFSZ FE9,F
0150: BRA 0142
0152: MOVLW 0D
0154: BTFSC 00.7
0156: MOVLW 03
0158: MOVWF 01
015A: DECFSZ 01,F
015C: BRA 015A
015E: BTFSC 00.7
0160: BRA 0122
0162: BTFSC 00.6
0164: BRA 0132
0166: BRA 0126
01FA: BCF F94.6
01FC: BCF F8B.6
01FE: MOVLW 08
0200: MOVWF 01
0202: BRA 0204
0204: NOP
0206: BSF 01.7
0208: BRA 0226
020A: BCF 01.7
020C: RRCF xCF,F
020E: BTFSC FD8.0
0210: BSF F8B.6
0212: BTFSS FD8.0
0214: BCF F8B.6
0216: BSF 01.6
0218: BRA 0226
021A: BCF 01.6
021C: DECFSZ 01,F
021E: BRA 020C
0220: BRA 0222
0222: NOP
0224: BSF F8B.6
0226: MOVLW 01
0228: MOVWF 00
022A: CLRF FE9
022C: DECFSZ FE9,F
022E: BRA 022C
0230: DECFSZ 00,F
0232: BRA 022A
0234: MOVLW 0E
0236: MOVWF FE9
0238: DECFSZ FE9,F
023A: BRA 0238
023C: NOP
023E: BTFSC 01.7
0240: BRA 020A
0242: BTFSC 01.6
0244: BRA 021A
0246: RETLW 00
0340: BSF F93.0
0342: BTFSS F81.0
0344: BRA 0342
0346: MOVLW 08
0348: MOVWF 00
034A: CLRF xCF
034C: BSF 00.7
034E: BRA 036C
0350: BCF 00.7
0352: BRA 036C
0354: BCF FD8.0
0356: BTFSS F81.0
0358: BSF FD8.0
035A: RRCF xCF,F
035C: BSF 00.6
035E: BRA 036C
0360: BCF 00.6
0362: DECFSZ 00,F
0364: BRA 0354
0366: MOVFF CF,01
036A: BRA 0384
036C: MOVLW A4
036E: BTFSC 00.7
0370: MOVLW 2C
0372: MOVWF 01
0374: DECFSZ 01,F
0376: BRA 0374
0378: NOP
037A: BTFSC 00.7
037C: BRA 0350
037E: BTFSC 00.6
0380: BRA 0360
0382: BRA 0354
0384: GOTO 03B4 (RETURN) |
I can get round this problem by just using a blank fprintf but I'd like to know whether it's a compiler fault or something else I'm not aware of.
Cheers, |
asmboy
Posted: Tue Aug 09, 2011 4:39 pm |
you are not showing the code actually generated by your problem fprintf
are you ??
i assume it all works with fprintf(TC,"\r\n");
so what is the programmatic purpose of printing a null without printing
an actual asciiz ??? |
Geps
Posted: Wed Aug 10, 2011 4:24 am |
No, I looked through the code and quoted those from the top of the file. When the line is commented out the compiler does skip through it and there is no assembly listed.
I can test that code in a couple of hours and let you know.
At the moment it's to stop it hanging - originally the program worked when there was text in there to print, I commented it out and it hung so I kept removing letters and found out that even though nothing gets printed it gets around this hanging problem. |
jeremiah
Posted: Wed Aug 10, 2011 9:00 am |
Perhaps you have a non null terminated string somewhere?
Mind you, this is just a guess since you aren't providing a small program that shows the problem.
Could you post a small completely compilable program that duplicates the problem? It would help those here with debugging the issue. |
