Arbitrary working Timer
mehmetem
PostPosted: Mon Aug 08, 2011 1:33 am     Reply with quote
Hi Everyody,
Timer2 is set as
setup_timer2(TMR_INTERNAL |TMR_DIV_BY_1, 255);
in my code for dsPic33fj32mc204.
The last command "output_toggle(Q3);" is executed all times.
But conditional commands are not executed in Power On reset but executed manual reset. I also tried various timer periods. If anybody can explain I will be glad.
#int_TIMER2
void  TIMER2_isr(void)
   count=qei_get_count();
  if ((count>EnjStartArray[0])&(count<EnjStopArray[0]))
  {output_high(Q6);}
   {output_low(Q6);}
  if ((count>EnjStartArray[1])&(count<EnjStopArray[1]))
  {output_high(Q5);}
   {output_low(Q5);}
  if ((count>EnjStartArray[2])&(count<EnjStopArray[2]))
  {output_high(Q1);}
   {output_low(Q1);}
  if ((count>EnjStartArray[3])&(count<EnjStopArray[3]))
  {output_high(Q2);}
   {output_low(Q2);}
output_toggle(Q3);
Question
trainee
PostPosted: Mon Aug 08, 2011 1:57 am     Reply with quote
Post your setup_qei line, and clock rates/fuses, and what is connected to the QEI pins.
Also compiler version.
Is this 'for real', or with a debugger?. If so, what one?.
How are you generating the 'manual reset'?.
Obvious difference is initialisation states of the registers, depending on how you are generating the 'manual reset'.
mehmetem
PostPosted: Mon Aug 08, 2011 3:55 am     Reply with quote
My setup qei;
setup_qei(QEI_MODE_X4|QEI_RESET_WHEN_IDX_PULSE,QEI_FILTER_DIV_1|QEI_IDX_WHEN_A0_B0,1439);
#FUSES NOBSS //No boot segment
#FUSES PROTECTS //Standard Code protection
#FUSES PR_PLL //Primary Oscillator with PLL
#FUSES NOCKSFSM //Clock Switching is disabled, fail Safe clock monitor is disabled
#FUSES NOOSCIO //OSC2 is general purpose output
#FUSES WINDIS //Watch Dog Timer in non-Window mode
#FUSES WPRES128 //Watch Dog Timer PreScalar 1:128
#FUSES WPOSTS16 //Watch Dog Timer PostScalar 1:32768
#FUSES PUT128 //Power On Reset Timer value 128ms
#FUSES NOALTI2C //I2C mapped to alternate pins
#FUSES IOL1WAY //Allows only one reconfiguration of peripheral pins
#FUSES NOCOE //Device will reset into operational mode
#FUSES NOJTAG //JTAG disabled
#FUSES ICS0 //ICD communication channel 0
#FUSES NOPWMPIN //PWM outputs drive active state upon Reset
#FUSES HPOL_HIGH //High-Side Transistors Polarity is Active-High (PWM 1,3,5 and 7)
#FUSES LPOL_HIGH //Low-Side Transistors Polarity is Active-High (PWM 0,2,4 and 6)
#use delay(clock=40000000)
My Oscillator config;
#word OSCCON = 0X0742 //OSCILLATOR CONTROL REGISTER
#word CLKDIV = 0X0744 //CLOCK DIVISOR REGISTER
#word PLLFBD = 0X0746//PLL FEEDBACK DIVISOR REGISTER
#bit CLKDIV0=CLKDIV.0//‘N1’, PLL prescaler ->N1=2
#bit CLKDIV1=CLKDIV.1
#bit CLKDIV2=CLKDIV.2
#bit CLKDIV3=CLKDIV.3
#bit CLKDIV4=CLKDIV.4
#bit CLKDIV6=CLKDIV.6//‘N2’, PLL prescaler ->N2=2
#bit CLKDIV7=CLKDIV.7
#bit CLKDIV11=CLKDIV.11//DOZE Mode Enable bit
#bit CLKDIV12=CLKDIV.12//Processor Clock Reduction Select bits->1:1
#bit CLKDIV13=CLKDIV.13
#bit CLKDIV14=CLKDIV.14
#bit CLKDIV15=CLKDIV.15
#bit OSCCON8=OSCCON.8
#bit OSCCON9=OSCCON.9
#bit OSCCON10=OSCCON.10
in main() function:
CLKDIV0=1;//‘N1’, PLL prescaler ->N1=5
CLKDIV1=1;
CLKDIV2=0;
CLKDIV3=0;
CLKDIV4=0;
CLKDIV6=0;//‘N2’, PLL prescaler ->N2=2
CLKDIV7=0;
CLKDIV11=0;//DOZE Mode Enable bit
CLKDIV12=0;//Processor Clock Reduction Select bits->1:1
CLKDIV13=0;
CLKDIV14=0;
CLKDIV15=0;
OSCCON8=1;//Primary oscillator (XT, HS, EC) with PLL
OSCCON9=1;
OSCCON10=0;
PLLFBD=0b000010011;//‘M’, PLL multiplier->M=20
//My crystal 40 Mhz, with PLL fosc=40MHz/5*20/2=80 MHz
My qei pins are connected a quadratura encoder as
#word RPINR14 = 0x069C //QEI remap reg
#word RPINR15 = 0x069E //QEI remap reg
#word QEI1CON = 0x01E0 //qei control register
#word DFLT1CON = 0x01E2 //qei dflt control register
in main(function)
RPINR14=0x1514; //qeb,qea remap
RPINR15=0x0013; //ind remap
QEI1CON=((QEI1CON&0xF8FB)|0x0604); //qei 4x mode, index pulse reset
DFLT1CON=((DFLT1CON&0xFEFF)|0x0100); // count error detect disabled
My compiler version is PCD V4.084, This is not a debugger, it is for real,
I'am generating manual reset with a push buton between MCLR and GND
By the way Quadrature Encoder is already running and its position can saw from LCD
I realized that conditional functions sometimes works partly
(I'm sorry for my broken English )
Thank you very much
trainee
mehmetem
I'm asking I'm answering
PostPosted: Wed Aug 10, 2011 2:52 am     Reply with quote
I solved.
volatile unsigned int16 count=0;
Smile
trainee
