farouk_baya
problem with 18f26j50 |
Posted: Sun Aug 07, 2011 7:18 am |
Hello, it is the first time that I use 18f26j50. I used before 18f4550, it
wasn't so complicated.
#include "18f26j50.h"
#fuses HSPLL,NOWDT,NOCPUDIV,PLL5
#use delay(clock=48M)
SETUP_ADC(ADC_OFF);
SETUP_ADC_PORTS(NO_ANALOGS);
output_b(0x00);
set_tris_b(0x00);
output_b(0x00);
output_b(0b00111111);
I have problems to make choice for the fuses because I don't know enough about them.
In the data sheet I took a look in the oscillator diagram they mentioned. As I understand: I have to fix the PLLDIV, CPDIV, the use of external or internal oscillator.
I have to fix this problem.
Thanks for everybody.
Posted: Sun Aug 07, 2011 12:42 pm |
What's your CCS compiler version ?
What is the frequency of your external crystal ? |
farouk_baya
Posted: Sun Aug 07, 2011 5:12 pm |
hello,
20 MHz external crystal
ccs c 4.110 |
Posted: Sun Aug 07, 2011 9:08 pm |
I think this setup will work with your version:
#include <18F26J50.h>
#fuses HSPLL, NOWDT, PLL5
setup_oscillator(OSC_PLL_ON);
farouk_baya
Posted: Mon Aug 08, 2011 4:28 am |
Thanks for you help.
It works very fine. |
