help me
shooshe
help me
PostPosted: Fri Aug 05, 2011 3:03 am     Reply with quote
Hi
Good Time
What is TRIS ? Where used?
THANKFUL
PostPosted: Fri Aug 05, 2011 5:20 am     Reply with quote
Chip data sheet.....
TRIS is the tri-state control register. Changes whether pins are configured as inputs or outputs.
Every I/O pin, has an associated TRIS bit.
Where used. Generally, don't!.....
Thing here is that if you were writing in assembler, you would have to control TRIS for every pin. Not only getting it right for input/output, but also for things like peripherals, where there are usually specific settings needed to allow the peripheral to control the pin. So programmers who are used to doing this, keep on doing this. _But_ for 99.9% of code, it is more reliable, to never touch TRIS. Instead let the compiler handle it for you.
So, generally, don't touch the TRIS registers. If (for instance), you perform:
output_high(PIN_A1);
The compiler knows that you want to output a value on pin A1, and will automatically adjust the TRIS to suit.
So, don't touch TRIS.
bkamen
PostPosted: Sat Aug 06, 2011 9:39 am     Reply with quote
If you're asking what TRIS is, then I would agree with everything TTelmah has told you so far...
With one caveat:
When you have advanced enough, you will know where and when to touch the TRIS registers yourself as there ARE some good examples of when it's a good idea to turn off the compiler's automatic setting of the TRIS bits when output or input functions are used.
Until then, follow TTelmah's advice knowing some day you will graduate past it.
-Ben
shooshe
PostPosted: Sat Aug 06, 2011 5:45 pm     Reply with quote
Thank you for replied this post. I have another question.
What is the address of this ?
Again, thank you.
shooshe
PostPosted: Sat Aug 06, 2011 6:02 pm     Reply with quote
TRIS addresses tend to be 80x above the port addresses.
IE : If PORTA is at 5x, TRISA will be 85x.
BUT read the datasheet, EVERY address is listed for that PIC's RAM, ROM, SFRs,peripherals, etc.
shooshe
PostPosted: Sat Aug 06, 2011 7:01 pm     Reply with quote
Hi every one...
I know these questions are elementary, Im so sorry but i have,
can u explain a little about the bit_test? What does it do?
thank u
shooshe
bkamen
PostPosted: Sat Aug 06, 2011 7:26 pm     Reply with quote
shooshe wrote:
Hi every one...
thank u
In terms of the C function or the PIC ASM instruction?
If you look at the datasheet for PIC16/18's (and the rest really) there's a chapter on the instruction set.
Just do a PDF for BIT TEST.
Essentially, both function test the bit of some variable and then return true or false based on 1 or 0 at the bit's location.
BIT tests in the smaller PIC's are very fast, a single instruction.
Testing a variable that's 0 or 1 usually requires more machine instructions to execute.
-Ben
shooshe
PostPosted: Sat Aug 06, 2011 8:04 pm     Reply with quote
Dear Ben
Thank you for your attention.
I understand your comment.
It is possible? For this example, I use your guidance?
SHIFTER_DIN = bit_test(Shiftreg, i-1);
Course. This parameter is defined.
Thanks again.
bkamen
PostPosted: Sun Aug 07, 2011 12:00 am     Reply with quote
This is well defined in the manual for CCS PIC-C.
bit_test returns a value of 0 or 1 based on the test performed.
Cheers,
-Ben
shooshe
PostPosted: Wed Aug 10, 2011 3:01 pm     Reply with quote
Hi every body...
May explain about the setup_adc_ports()?
Of course, I read ccs's help...but i didnt understand very good....
thanks for your attention....
shooshe
PostPosted: Wed Aug 10, 2011 3:15 pm     Reply with quote
Here is a Microchip tutorial on the PIC ADC:
http://ww1.microchip.com/downloads/en/devicedoc/adc.pdf
ADC setup tutorial for CCS:
http://seng.ulster.ac.uk/eme/sidk/eee305/Miniproject/ADC%20port%20CCS%20compiler.pdf
