Driving Nokia3310 Lcd
M.Yasser
PostPosted: Fri Aug 05, 2011 4:08 pm     Reply with quote
I’m trying to write a string on Nokia3310 Lcd with no success.
I’m using CCS C under MPLAB v8.73. The microcontroller I’m using is 16f877A.
As you can see in the figure I’m using proteus to simulate the circuit. The driving code for the lcd is by Michel Bavin.
The Lcd library is :
Graphic LCD Nokia 3310 (LPH7779) routines v3
CCS compiler
by Michel Bavin 2004 --- bavin@skynet.be --- http://users.skynet.be/bk317494/ ---
august 29, 2004
//driver library name:nokia_3310.c
// ex:
// nokia_init();
// nokia_gotoxy(0,0);
// printf(nokia_printchar,"test???");
#define nok_sclk  PIN_D4
#define nok_sda   PIN_D3
#define nok_dc    PIN_D2
#define nok_cs    PIN_D1
#define nok_res   PIN_D0
char char_row,charsel,charpos,chardata;       // for nokia_3310 lcd
int16 ddram;
char plot_value;
int32 plot_value32;
int32 plot_umsb,plot_lmsb,plot_ulsb,plot_llsb;
BYTE const TABLE5[240]=            {0x00,0x00,0x00,0x00,0x00,   // 20 space          ASCII table for NOKIA LCD: 96 rows * 5 bytes= 480 bytes
  0x00,0x00,0x5f,0x00,0x00,   // 21 !
  0x00,0x07,0x00,0x07,0x00,   // 22 "
  0x14,0x7f,0x14,0x7f,0x14,   // 23 #
  0x24,0x2a,0x7f,0x2a,0x12,   // 24 $
  0x23,0x13,0x08,0x64,0x62,   // 25 %
  0x36,0x49,0x55,0x22,0x50,   // 26 &
  0x00,0x05,0x03,0x00,0x00,   // 27 '
  0x00,0x1c,0x22,0x41,0x00,   // 28 (
  0x00,0x41,0x22,0x1c,0x00,   // 29 )
  0x14,0x08,0x3e,0x08,0x14,   // 2a *
  0x08,0x08,0x3e,0x08,0x08,   // 2b +
  0x00,0x50,0x30,0x00,0x00,   // 2c ,
  0x08,0x08,0x08,0x08,0x08,   // 2d -
  0x00,0x60,0x60,0x00,0x00,   // 2e .
  0x20,0x10,0x08,0x04,0x02,   // 2f /
  0x3e,0x51,0x49,0x45,0x3e,   // 30 0
  0x00,0x42,0x7f,0x40,0x00,   // 31 1
  0x42,0x61,0x51,0x49,0x46,   // 32 2
  0x21,0x41,0x45,0x4b,0x31,   // 33 3
  0x18,0x14,0x12,0x7f,0x10,   // 34 4
  0x27,0x45,0x45,0x45,0x39,   // 35 5
  0x3c,0x4a,0x49,0x49,0x30,   // 36 6
  0x01,0x71,0x09,0x05,0x03,   // 37 7
  0x36,0x49,0x49,0x49,0x36,   // 38 8
  0x06,0x49,0x49,0x29,0x1e,   // 39 9
  0x00,0x36,0x36,0x00,0x00,   // 3a :
  0x00,0x56,0x36,0x00,0x00,   // 3b ;
  0x08,0x14,0x22,0x41,0x00,   // 3c <
  0x14,0x14,0x14,0x14,0x14,   // 3d =
  0x00,0x41,0x22,0x14,0x08,   // 3e >
  0x02,0x01,0x51,0x09,0x06,   // 3f ?
  0x32,0x49,0x79,0x41,0x3e,   // 40 @
  0x7e,0x11,0x11,0x11,0x7e,   // 41 A
  0x7f,0x49,0x49,0x49,0x36,   // 42 B
  0x3e,0x41,0x41,0x41,0x22,   // 43 C
  0x7f,0x41,0x41,0x22,0x1c,   // 44 D
  0x7f,0x49,0x49,0x49,0x41,   // 45 E
  0x7f,0x09,0x09,0x09,0x01,   // 46 F
  0x3e,0x41,0x49,0x49,0x7a,   // 47 G
  0x7f,0x08,0x08,0x08,0x7f,   // 48 H
  0x00,0x41,0x7f,0x41,0x00,   // 49 I
  0x20,0x40,0x41,0x3f,0x01,   // 4a J
  0x7f,0x08,0x14,0x22,0x41,   // 4b K
  0x7f,0x40,0x40,0x40,0x40,   // 4c L
  0x7f,0x02,0x0c,0x02,0x7f,   // 4d M
  0x7f,0x04,0x08,0x10,0x7f,   // 4e N
  0x3e,0x41,0x41,0x41,0x3e    // 4f O
BYTE const TABLE6[240]=            {0x7f,0x09,0x09,0x09,0x06,   // 50 P
  0x3e,0x41,0x51,0x21,0x5e,   // 51 Q
  0x7f,0x09,0x19,0x29,0x46,   // 52 R
  0x46,0x49,0x49,0x49,0x31,   // 53 S
  0x01,0x01,0x7f,0x01,0x01,   // 54 T
  0x3f,0x40,0x40,0x40,0x3f,   // 55 U
  0x1f,0x20,0x40,0x20,0x1f,   // 56 V
  0x3f,0x40,0x38,0x40,0x3f,   // 57 W
  0x63,0x14,0x08,0x14,0x63,   // 58 X
  0x07,0x08,0x70,0x08,0x07,   // 59 Y
  0x61,0x51,0x49,0x45,0x43,   // 5a Z
  0x00,0x7f,0x41,0x41,0x00,   // 5b [
  0x02,0x04,0x08,0x10,0x20,   // 5c
  0x00,0x41,0x41,0x7f,0x00,   // 5d
  0x04,0x02,0x01,0x02,0x04,   // 5e
  0x40,0x40,0x40,0x40,0x40,   // 5f
  0x00,0x01,0x02,0x04,0x00,   // 60
  0x20,0x54,0x54,0x54,0x78,   // 61 a
  0x7f,0x48,0x44,0x44,0x38,   // 62 b
  0x38,0x44,0x44,0x44,0x20,   // 63 c
  0x38,0x44,0x44,0x48,0x7f,   // 64 d
  0x38,0x54,0x54,0x54,0x18,   // 65 e
  0x08,0x7e,0x09,0x01,0x02,   // 66 f
  0x0c,0x52,0x52,0x52,0x3e,   // 67 g
  0x7f,0x08,0x04,0x04,0x78,   // 68 h
  0x00,0x44,0x7d,0x40,0x00,   // 69 i
  0x20,0x40,0x44,0x3d,0x00,   // 6a j
  0x7f,0x10,0x28,0x44,0x00,   // 6b k
  0x00,0x41,0x7f,0x40,0x00,   // 6c l
  0x7c,0x04,0x18,0x04,0x78,   // 6d m
  0x7c,0x08,0x04,0x04,0x78,   // 6e n
  0x38,0x44,0x44,0x44,0x38,   // 6f o
  0x7c,0x14,0x14,0x14,0x08,   // 70 p
  0x08,0x14,0x14,0x18,0x7c,   // 71 q
  0x7c,0x08,0x04,0x04,0x08,   // 72 r
  0x48,0x54,0x54,0x54,0x20,   // 73 s
  0x04,0x3f,0x44,0x40,0x20,   // 74 t
  0x3c,0x40,0x40,0x20,0x7c,   // 75 u
  0x1c,0x20,0x40,0x20,0x1c,   // 76 v
  0x3c,0x40,0x30,0x40,0x3c,   // 77 w
  0x44,0x28,0x10,0x28,0x44,   // 78 x
  0x0c,0x50,0x50,0x50,0x3c,   // 79 y
  0x44,0x64,0x54,0x4c,0x44,   // 7a z
  0x00,0x08,0x36,0x41,0x00,   // 7b
  0x00,0x00,0x7f,0x00,0x00,   // 7c
  0x00,0x41,0x36,0x08,0x00,   // 7d
  0x10,0x08,0x08,0x10,0x08,   // 7e
  0x78,0x46,0x41,0x46,0x78    // 7f
void    nokia_init(void);
void    nokia_write_command(char bytefornokia_command);
void    nokia_write_data(char bytefornokia_data);
void    nokia_write_dorc(char bytefornokia);
void    nokia_gotoxy(int8 xnokia, int8 ynokia);
void    nokia_erase_y(int8 ynokia);
void    nokia_erase_x(int8 xnokia);
void    nokia_printchar(int8 cvar);
void    nokia_clean_ddram(void);
void    table_to_nokialcd(void);
void    nokia_plot(int8 xnokia,int8 plot_value8);
void    nokia_write_data_inv(char bytefornokia_data_inv);
void    nokia_clear_screen(void);
void    nokia_clear_xy(int8 xnokia, int8 ynokia);
void    nokia_print_uparrow(void);
void    nokia_print_downarrow(void);
void    nokia_print_leftarrow(void);
void    nokia_print_rightarrow(void);
void    nokia_print_degree(void);
void    nokia_print_lowbatdegree(void);
  output_high(nok_dc);            // bytes are stored in the display data ram, address counter, incremented automatically
  output_high(nok_cs);            // chip disabled
  output_low(nok_res);            // reset chip during 250ms
  delay_ms(10);         // works with less.....
  output_high(nok_res);
  nokia_write_command(0x21);   // set extins extended instruction set
  nokia_write_command(0xc2);   // Vop  v1: 0xc8 (for 3V)// v2: 0xa0 (for 3V) // v3: 0xc2 (2v6-5v)   ********************************************************************************************************************
  nokia_write_command(0x13);   // bias
  nokia_write_command(0x20);   // horizontal mode from left to right, X axe are incremented automatically , 0x22 for vertical addressing ,back on normal instruction set too
  nokia_write_command(0x09);   // all on
  nokia_clean_ddram();      // reset DDRAM, otherwise the lcd is blurred with random pixels
  nokia_write_command(0x08);   // mod control blank change (all off)
  nokia_write_command(0x0c);   // mod control normal change
  nokia_gotoxy(0,0);         // 84*6=504      clear LCD
  for (ddram=504;ddram>0;ddram--){nokia_write_data(0x00);}
  output_low(nok_dc);   // byte is a command it is read with the eight SCLK pulse
  output_low(nok_cs);   // chip enabled
  nokia_write_dorc(bytefornokia_command);
  nokia_write_dorc(bytefornokia_data);
void nokia_write_dorc(char bytefornokia)         // serial write data or command subroutine
  char caa;
  for (caa=8;caa>0;caa--) {
    output_low(nok_sclk);
    // delay_us(2);
    if ((bytefornokia&0x80)==0){output_low(nok_sda);}
    else {output_high(nok_sda);}
    output_high(nok_sclk);
    bytefornokia=bytefornokia<<1;
void nokia_gotoxy(int8 xnokia, int8 ynokia)      // Nokia LCD 3310 Position cursor
  nokia_write_command(0x40|(ynokia&0x07));   // Y axe initialisation: 0100 0yyy
  nokia_write_command(0x80|(xnokia&0x7f));   // X axe initialisation: 1xxx xxxx
  nokia_gotoxy(0,ynokia);
  printf(nokia_printchar,"              ");
  char column;
  for (column=0;column!=6;column++){
    nokia_gotoxy(xnokia,column);
void nokia_printchar(int8 cvar)               // Write 1 character to LCD
  charsel=cvar;
  table_to_nokialcd();
void table_to_nokialcd(void)   // extract ascii from tables & write to LCD
  if (charsel<0x20)return;
  if (charsel>0x7f)return;
  for (char_row=0;char_row<5;char_row++) {      // 5 bytes
    if (charsel<0x50){charpos=(((charsel&0xff)-0x20)*5);chardata=TABLE5[(charpos+char_row)];}            // use TABLE5
    else if (charsel>0x4f){charpos=(((charsel&0xff)-0x50)*5);chardata=TABLE6[(charpos+char_row)];}            // use TABLE6
    nokia_write_data(chardata);      // send data to nokia
  nokia_write_data(0x00);      //    1 byte (always blank)
  char i;
  plot_value32=0;
  // plot_value32|=1;         // unremark this if you want dotgraph instead of bargraph
  for (i=0;i!=plot_value8;i++){
    plot_value32|=1;         // remark this if you want dotgraph instead of bargraph
    plot_value32<<=1;
  plot_value32|=2;            // bottom line is always filled
  plot_llsb=(plot_value32&0xff);
  plot_ulsb=((plot_value32>>8)&0xff);
  plot_lmsb=((plot_value32>>16)&0xff);
  plot_umsb=((plot_value32>>24)&0xff);
  nokia_gotoxy(xnokia,1);
  nokia_write_data_inv(plot_umsb);
  nokia_gotoxy(xnokia,2);
  nokia_write_data_inv(plot_lmsb);
  nokia_gotoxy(xnokia,3);
  nokia_write_data_inv(plot_ulsb);
  nokia_gotoxy(xnokia,4);
  nokia_write_data_inv(plot_llsb);
  char caa;
    delay_us(2);
    if ((bytefornokia_data_inv&0x01)==0){output_low(nok_sda);}
    bytefornokia_data_inv=bytefornokia_data_inv>>1;
  nokia_erase_y(0);
  nokia_erase_y(1);
  nokia_erase_y(2);
  nokia_erase_y(3);
  nokia_erase_y(4);
  nokia_erase_y(5);
  nokia_gotoxy(xnokia,ynokia);
  nokia_printchar(" ");
  nokia_write_data(0x04);
  nokia_write_data(0x02);
  nokia_write_data(0x7f);
  nokia_write_data(0x10);
  nokia_write_data(0x20);
  nokia_write_data(0x08);
  nokia_write_data(0x1c);
  nokia_write_data(0x2a);
  nokia_write_data(0xf8);
  nokia_write_data(0x06);
  nokia_write_data(0x09);
  // nokia_printchar("  ");
  nokia_write_data(0x0f);
The test prog i'm writing is:
#include "16F877A.h"
#use delay(clock=8000000)
#include "nokia_3310.c"
   NOKIA_INIT();
   NOKIA_GOTOXY(1,1);
   printf(nokia_printchar,"M.Yasser");
   NOKIA_GOTOXY(20,10);
   PRINTF(NOKIA_PRINTCHAR,"A Test!!");
   printF(nokia_printchar,"NOKIA 3310 LCD");
The Lcd display's nothing (blank).
Can anybody tell me what is wrong please?
Regards.
PostPosted: Fri Aug 05, 2011 6:26 pm     Reply with quote
Well the biggest error is in using Proteus ! Simulation is NOT the real world. I may sound like an old record but Proteus is FULL of bugs, errors, faulty drcs...
Unless you can Debug Proteus (the actual code NOT what is generated)you best get some real chips,a breadboard and learn by doing.
If you do that, then you'll very,very quickly learn that the 'schematic' that Proteus allows will NEVER work in the real world.
'Little' details like power supply issues, floating pins,no crystal, no bypass caps....ALL add up to hardware that can never function.
As to the 'driver' code...who says it actually works with your LCD AND your PIC ? Again, several lines come to mind, far too many to list here...
But to start off, you don't have a 'fuses' line after the processor include.
M.Yasser
PostPosted: Fri Aug 05, 2011 8:19 pm     Reply with quote
Hi temtronic,
Thank you for your fast reply. As far as I know fuses should be set in the part when it is programmed and it does not affect the compilation. However the project wizard takes care of the fuses, I think. See the figure below.
...then you'll very,very quickly learn that the 'schematic' that Proteus allows will NEVER work in the real world.
yes, I’m aware of that.
I reviewed the code, and it seems that it’s ok, I hope.
I’m learning please try to.
Regards.
PostPosted: Sat Aug 06, 2011 5:07 am     Reply with quote
Really, fuses should be in your program after the # device. While you can set them with the programmer interface,if written into the PIC program it would be very clear(to others) that you have LowVoltage Programming fuse set.
Having LVP set can cause you a LOT of problems when the PIC is actually programmed and in use.Unless you really have a low voltage programmer(99% aren't) then you should set the option to NOLVP.
I would suggest cutting code for the 'Hello World' test and be sure the PIC and a texttype LCD work fine.That simple program will check out 99% of the hardware,programmer,etc.
Be aware that the 877 is a 5 volt device, the Nokia a 3.3 device so you WILL require logic level translation between the two.proteus , of course, won't tell you this , and if you wire it up according to Proteus you'll destroy the LCD....
M.Yasser
PostPosted: Sat Aug 06, 2011 12:38 pm     Reply with quote
Hi temtronic,
Your comment was very helpful;
I managed to get it work; I only removed the 3.3v and replaced it with VDD. Since it’s only a simulation the LCD will not be fried. In real circuit I will use 3.3v; the purpose from using simulation for me is to check the correctness of the code.
Warm regards. Smile
PostPosted: Sat Aug 06, 2011 12:45 pm     Reply with quote
I'm glad you got it to work, at least as a simulation. As you are now aware Proteus did not allow the LCD Vdd to be 3.3V, so really Proteus fried your simulated LCD !!
Had it been the real world, you would have fried it ($$$$).
The point I'm making is that you cannot trust Proteus to be 100% correct. There are other errors in the schematic that Proteus allows in the simulation that would have stopped the hardware from running properly, so remember just because it 'worked' on the screen doesn't mean it will with real chips !!
sresam89
PostPosted: Sun Mar 25, 2012 3:58 am     Reply with quote
M.Yasser wrote:
Hi temtronic,
Warm regards. Smile
hello yasser have are you done with this project?
if you have constructed the real hardware how did you manage to get the 3.3 level transistions? or did u just use 5v directly from Uc?
sresam89
un stable contrast
PostPosted: Sun Mar 25, 2012 2:48 pm     Reply with quote
hello M.Yasser
your code came out well and indeed helpful.
just one problem with my hardware is my contrast is not getting stabilized its gets off upon every reset and takes quite large time to display still full contrast is not achieved.
