Incrementing Frequency by 50 Hz after X pulses
bassn1
PostPosted: Wed Aug 03, 2011 10:28 am     Reply with quote
CCS version 4.029
Hello, I was trying to implement the following code such that
I get a rough frequency ramp from 250-1000Hz at 50% DC.
Precision doesn't matter I'm just needing this to get do a rough ramp profile with a stepper.
x=10000
while x<count
count++
if count is <50 pwm freq=approx 250
if count is <100 pwm freq=approx 300
if count is <750 pwm freq=approx 1000
if count=10000
pwm duty =0   ;shut off pwm module
I found this great lil nugget by PCM programmer but I am having a hard time adapting it into a function that i can call when I need it.
Just wanting to make a move, so I'm thinking a function called move?
I am an asm guy and I am amazed at what this compiler can do I am just beating my head against the wall trying to get this implemented I know its simple but could someone please enlighten me?
#include <16F877.H>
#fuses XT, NOWDT, BROWNOUT, PUT, NOLVP
#define NUM_PULSES  10000
int16 count;
// Setup CCP1 for PWM at 250 Hz and 50% duty cycle.
setup_ccp1(CCP_PWM);
setup_timer_2(T2_DIV_BY_16, 249, 1);
set_pwm1_duty(128);
count = 0;
// Do the specified number of pulses on CCP1 and then stop.
   if(interrupt_active(INT_TIMER2))
      clear_interrupt(INT_TIMER2);
      count++;
      if(count == NUM_PULSES)
         set_pwm1_duty(0);  // Set PWM output = constant 0
I tried a case statement, for loop, and while but its not adding up because it either falls out or stays put and won't leave.
Thank you in advance.
PostPosted: Wed Aug 03, 2011 1:40 pm     Reply with quote
You should you try to do it and post your modified code. Maybe
put some "if, else if, else" statements in sequence with the existing
"count==" statement, and in each one, do a test for the count.
If it reaches your minimum count level for each step, then call
setup_timer_2() and set_pwm_duty() to select the new frequency
and to maintain a 50% duty cycle. Try it, and if it doesn't work,
then post the code and post the failure mode. Then I'll look at it.
bassn1
PostPosted: Wed Aug 03, 2011 2:59 pm     Reply with quote
Thanks for the reply PCM, I am not trying to get something for nothing I was just too embarrassed of my code!!!! I found a another potential solution.
Since I'm only working from 250-1000Hz,
If i use setup_timer_2(T2_DIV_BY_16, 249, 1);
to initialize and since Duty Cycle is a function of Prescale only and CCPR1L and CCP1con are constant.
Couldn't I just decrease period from 249-60 for every count? I should say for 189 counts anyway, and at that point I continue on until 10000 pulses are hit.
It looks good in excel from 249 to 60 it will increase from 250-1000
I shouldn't have to set duty cycle but once I believe.
PWM Period = [(PR2) + 1] • 4 • TOSC •
(TMR2 Prescale Value)
PWM Duty Cycle =(CCPR1L:CCP1CON<5:4>) •
TOSC • (TMR2 Prescale Value)
excel data
16.00   60.00   1.00   1.000000000E-06   1.0E+3
16.00   61.00   1.00   1.000000000E-06   1.0E+3
16.00   62.00   1.00   1.000000000E-06   1.0E+3
16.00   63.00   1.00   1.000000000E-06   992.1E+0
16.00   64.00   1.00   1.000000000E-06   976.6E+0
16.00   65.00   1.00   1.000000000E-06   961.5E+0
16.00   66.00   1.00   1.000000000E-06   947.0E+0
16.00   67.00   1.00   1.000000000E-06   932.8E+0
16.00   68.00   1.00   1.000000000E-06   919.1E+0
16.00   69.00   1.00   1.000000000E-06   905.8E+0
16.00   70.00   1.00   1.000000000E-06   892.9E+0
16.00   71.00   1.00   1.000000000E-06   880.3E+0
16.00   72.00   1.00   1.000000000E-06   868.1E+0
16.00   73.00   1.00   1.000000000E-06   856.2E+0
16.00   74.00   1.00   1.000000000E-06   844.6E+0
16.00   75.00   1.00   1.000000000E-06   833.3E+0
16.00   76.00   1.00   1.000000000E-06   822.4E+0
16.00   77.00   1.00   1.000000000E-06   811.7E+0
16.00   78.00   1.00   1.000000000E-06   801.3E+0
16.00   79.00   1.00   1.000000000E-06   791.1E+0
16.00   80.00   1.00   1.000000000E-06   781.3E+0
16.00   81.00   1.00   1.000000000E-06   771.6E+0
16.00   82.00   1.00   1.000000000E-06   762.2E+0
16.00   83.00   1.00   1.000000000E-06   753.0E+0
16.00   84.00   1.00   1.000000000E-06   744.0E+0
16.00   85.00   1.00   1.000000000E-06   735.3E+0
16.00   86.00   1.00   1.000000000E-06   726.7E+0
16.00   87.00   1.00   1.000000000E-06   718.4E+0
16.00   88.00   1.00   1.000000000E-06   710.2E+0
16.00   89.00   1.00   1.000000000E-06   702.2E+0
16.00   90.00   1.00   1.000000000E-06   694.4E+0
16.00   91.00   1.00   1.000000000E-06   686.8E+0
16.00   92.00   1.00   1.000000000E-06   679.3E+0
16.00   93.00   1.00   1.000000000E-06   672.0E+0
16.00   94.00   1.00   1.000000000E-06   664.9E+0
16.00   95.00   1.00   1.000000000E-06   657.9E+0
16.00   96.00   1.00   1.000000000E-06   651.0E+0
16.00   97.00   1.00   1.000000000E-06   644.3E+0
16.00   98.00   1.00   1.000000000E-06   637.8E+0
16.00   99.00   1.00   1.000000000E-06   631.3E+0
16.00   100.00   1.00   1.000000000E-06   625.0E+0
16.00   101.00   1.00   1.000000000E-06   618.8E+0
16.00   102.00   1.00   1.000000000E-06   612.7E+0
16.00   103.00   1.00   1.000000000E-06   606.8E+0
16.00   104.00   1.00   1.000000000E-06   601.0E+0
16.00   105.00   1.00   1.000000000E-06   595.2E+0
16.00   106.00   1.00   1.000000000E-06   589.6E+0
16.00   107.00   1.00   1.000000000E-06   584.1E+0
16.00   108.00   1.00   1.000000000E-06   578.7E+0
16.00   109.00   1.00   1.000000000E-06   573.4E+0
16.00   110.00   1.00   1.000000000E-06   568.2E+0
16.00   111.00   1.00   1.000000000E-06   563.1E+0
16.00   112.00   1.00   1.000000000E-06   558.0E+0
16.00   113.00   1.00   1.000000000E-06   553.1E+0
16.00   114.00   1.00   1.000000000E-06   548.2E+0
16.00   115.00   1.00   1.000000000E-06   543.5E+0
16.00   116.00   1.00   1.000000000E-06   538.8E+0
16.00   117.00   1.00   1.000000000E-06   534.2E+0
16.00   118.00   1.00   1.000000000E-06   529.7E+0
16.00   119.00   1.00   1.000000000E-06   525.2E+0
16.00   120.00   1.00   1.000000000E-06   520.8E+0
16.00   121.00   1.00   1.000000000E-06   516.5E+0
16.00   122.00   1.00   1.000000000E-06   512.3E+0
16.00   123.00   1.00   1.000000000E-06   508.1E+0
16.00   124.00   1.00   1.000000000E-06   504.0E+0
16.00   125.00   1.00   1.000000000E-06   500.0E+0
16.00   126.00   1.00   1.000000000E-06   496.0E+0
16.00   127.00   1.00   1.000000000E-06   492.1E+0
16.00   128.00   1.00   1.000000000E-06   488.3E+0
16.00   129.00   1.00   1.000000000E-06   484.5E+0
16.00   130.00   1.00   1.000000000E-06   480.8E+0
16.00   131.00   1.00   1.000000000E-06   477.1E+0
16.00   132.00   1.00   1.000000000E-06   473.5E+0
16.00   133.00   1.00   1.000000000E-06   469.9E+0
16.00   134.00   1.00   1.000000000E-06   466.4E+0
16.00   135.00   1.00   1.000000000E-06   463.0E+0
16.00   136.00   1.00   1.000000000E-06   459.6E+0
16.00   137.00   1.00   1.000000000E-06   456.2E+0
16.00   138.00   1.00   1.000000000E-06   452.9E+0
16.00   139.00   1.00   1.000000000E-06   449.6E+0
16.00   140.00   1.00   1.000000000E-06   446.4E+0
16.00   141.00   1.00   1.000000000E-06   443.3E+0
16.00   142.00   1.00   1.000000000E-06   440.1E+0
16.00   143.00   1.00   1.000000000E-06   437.1E+0
16.00   144.00   1.00   1.000000000E-06   434.0E+0
16.00   145.00   1.00   1.000000000E-06   431.0E+0
16.00   146.00   1.00   1.000000000E-06   428.1E+0
16.00   147.00   1.00   1.000000000E-06   425.2E+0
16.00   148.00   1.00   1.000000000E-06   422.3E+0
16.00   149.00   1.00   1.000000000E-06   419.5E+0
16.00   150.00   1.00   1.000000000E-06   416.7E+0
16.00   151.00   1.00   1.000000000E-06   413.9E+0
16.00   152.00   1.00   1.000000000E-06   411.2E+0
16.00   153.00   1.00   1.000000000E-06   408.5E+0
16.00   154.00   1.00   1.000000000E-06   405.8E+0
16.00   155.00   1.00   1.000000000E-06   403.2E+0
16.00   156.00   1.00   1.000000000E-06   400.6E+0
16.00   157.00   1.00   1.000000000E-06   398.1E+0
16.00   158.00   1.00   1.000000000E-06   395.6E+0
16.00   159.00   1.00   1.000000000E-06   393.1E+0
16.00   160.00   1.00   1.000000000E-06   390.6E+0
16.00   161.00   1.00   1.000000000E-06   388.2E+0
16.00   162.00   1.00   1.000000000E-06   385.8E+0
16.00   163.00   1.00   1.000000000E-06   383.4E+0
16.00   164.00   1.00   1.000000000E-06   381.1E+0
16.00   165.00   1.00   1.000000000E-06   378.8E+0
16.00   166.00   1.00   1.000000000E-06   376.5E+0
16.00   167.00   1.00   1.000000000E-06   374.3E+0
16.00   168.00   1.00   1.000000000E-06   372.0E+0
16.00   169.00   1.00   1.000000000E-06   369.8E+0
16.00   170.00   1.00   1.000000000E-06   367.6E+0
16.00   171.00   1.00   1.000000000E-06   365.5E+0
16.00   172.00   1.00   1.000000000E-06   363.4E+0
16.00   173.00   1.00   1.000000000E-06   361.3E+0
16.00   174.00   1.00   1.000000000E-06   359.2E+0
16.00   175.00   1.00   1.000000000E-06   357.1E+0
16.00   176.00   1.00   1.000000000E-06   355.1E+0
16.00   177.00   1.00   1.000000000E-06   353.1E+0
16.00   178.00   1.00   1.000000000E-06   351.1E+0
16.00   179.00   1.00   1.000000000E-06   349.2E+0
16.00   180.00   1.00   1.000000000E-06   347.2E+0
16.00   181.00   1.00   1.000000000E-06   345.3E+0
16.00   182.00   1.00   1.000000000E-06   343.4E+0
16.00   183.00   1.00   1.000000000E-06   341.5E+0
16.00   184.00   1.00   1.000000000E-06   339.7E+0
16.00   185.00   1.00   1.000000000E-06   337.8E+0
16.00   186.00   1.00   1.000000000E-06   336.0E+0
16.00   187.00   1.00   1.000000000E-06   334.2E+0
16.00   188.00   1.00   1.000000000E-06   332.4E+0
16.00   189.00   1.00   1.000000000E-06   330.7E+0
16.00   190.00   1.00   1.000000000E-06   328.9E+0
16.00   191.00   1.00   1.000000000E-06   327.2E+0
16.00   192.00   1.00   1.000000000E-06   325.5E+0
16.00   193.00   1.00   1.000000000E-06   323.8E+0
16.00   194.00   1.00   1.000000000E-06   322.2E+0
16.00   195.00   1.00   1.000000000E-06   320.5E+0
16.00   196.00   1.00   1.000000000E-06   318.9E+0
16.00   197.00   1.00   1.000000000E-06   317.3E+0
16.00   198.00   1.00   1.000000000E-06   315.7E+0
16.00   199.00   1.00   1.000000000E-06   314.1E+0
16.00   200.00   1.00   1.000000000E-06   312.5E+0
16.00   201.00   1.00   1.000000000E-06   310.9E+0
16.00   202.00   1.00   1.000000000E-06   309.4E+0
16.00   203.00   1.00   1.000000000E-06   307.9E+0
16.00   204.00   1.00   1.000000000E-06   306.4E+0
16.00   205.00   1.00   1.000000000E-06   304.9E+0
16.00   206.00   1.00   1.000000000E-06   303.4E+0
16.00   207.00   1.00   1.000000000E-06   301.9E+0
16.00   208.00   1.00   1.000000000E-06   300.5E+0
16.00   209.00   1.00   1.000000000E-06   299.0E+0
16.00   210.00   1.00   1.000000000E-06   297.6E+0
16.00   211.00   1.00   1.000000000E-06   296.2E+0
16.00   212.00   1.00   1.000000000E-06   294.8E+0
16.00   213.00   1.00   1.000000000E-06   293.4E+0
16.00   214.00   1.00   1.000000000E-06   292.1E+0
16.00   215.00   1.00   1.000000000E-06   290.7E+0
16.00   216.00   1.00   1.000000000E-06   289.4E+0
16.00   217.00   1.00   1.000000000E-06   288.0E+0
16.00   218.00   1.00   1.000000000E-06   286.7E+0
16.00   219.00   1.00   1.000000000E-06   285.4E+0
16.00   220.00   1.00   1.000000000E-06   284.1E+0
16.00   221.00   1.00   1.000000000E-06   282.8E+0
16.00   222.00   1.00   1.000000000E-06   281.5E+0
16.00   223.00   1.00   1.000000000E-06   280.3E+0
16.00   224.00   1.00   1.000000000E-06   279.0E+0
16.00   225.00   1.00   1.000000000E-06   277.8E+0
16.00   226.00   1.00   1.000000000E-06   276.5E+0
16.00   227.00   1.00   1.000000000E-06   275.3E+0
16.00   228.00   1.00   1.000000000E-06   274.1E+0
16.00   229.00   1.00   1.000000000E-06   272.9E+0
16.00   230.00   1.00   1.000000000E-06   271.7E+0
16.00   231.00   1.00   1.000000000E-06   270.6E+0
16.00   232.00   1.00   1.000000000E-06   269.4E+0
16.00   233.00   1.00   1.000000000E-06   268.2E+0
16.00   234.00   1.00   1.000000000E-06   267.1E+0
16.00   235.00   1.00   1.000000000E-06   266.0E+0
16.00   236.00   1.00   1.000000000E-06   264.8E+0
16.00   237.00   1.00   1.000000000E-06   263.7E+0
16.00   238.00   1.00   1.000000000E-06   262.6E+0
16.00   239.00   1.00   1.000000000E-06   261.5E+0
16.00   240.00   1.00   1.000000000E-06   260.4E+0
16.00   241.00   1.00   1.000000000E-06   259.3E+0
16.00   242.00   1.00   1.000000000E-06   258.3E+0
16.00   243.00   1.00   1.000000000E-06   257.2E+0
16.00   244.00   1.00   1.000000000E-06   256.1E+0
16.00   245.00   1.00   1.000000000E-06   255.1E+0
16.00   246.00   1.00   1.000000000E-06   254.1E+0
16.00   247.00   1.00   1.000000000E-06   253.0E+0
16.00   248.00   1.00   1.000000000E-06   252.0E+0
16.00   249.00   1.00   1.000000000E-06   251.0E+0
16.00   250.00   1.00   1.000000000E-06   250.0E+0
any thoughts?
PostPosted: Wed Aug 03, 2011 3:59 pm     Reply with quote
The ratio of CCPR1L:CCP1CON<5:4> to PR2 is what controls the duty
cycle. If you change PR2 in order to change the PWM frequency, you
must also change CCPR1L:CCP1CON<5:4> if you want to maintain the
same duty cycle.
bassn1
PostPosted: Wed Aug 03, 2011 4:02 pm     Reply with quote
The duty cycle wont be constant in that range?
If i set it to 50, should it not stay at 50?
Note: im only changing period, not prescale.
Post and pre are constant
PostPosted: Wed Aug 03, 2011 4:03 pm     Reply with quote
Do some experiments in hardware.
bassn1
asm
PostPosted: Wed Aug 03, 2011 4:11 pm     Reply with quote
int16 count;
// Setup CCP1 for PWM at 244 Hz and 50% duty cycle.
setup_timer_2(T2_DIV_BY_4, 249, 1);
set_pwm1_duty(128);
count = 0;
Ok I just want to decrement PR2 , but it tells me it must evaluate to a constant?
I looked in the .h file and I dont even see PR2>?
   if (count<189)
      count++;
      #asm
      DECF,PR2,F
     #endasm
   else if(interrupt_active(INT_TIMER2))
      count++;
bassn1
oops
PostPosted: Wed Aug 03, 2011 4:13 pm     Reply with quote
oops,
see above code
PostPosted: Wed Aug 03, 2011 4:38 pm     Reply with quote
If you want to talk to a register directly, you don't use ASM. You declare
the register name and its address with a #byte statement. Then you
treat the register name as it's a variable in your code.
Look up #byte in the manual:
http://www.ccsinfo.com/downloads/ccs_c_manual.pdf
Just a tip: We don't like to see ASM in source code on this forum
unless it's absolutely necessary.
