USB communication 18f4550 <-> PC
cile
PostPosted: Tue Aug 02, 2011 8:28 am     Reply with quote
Hello !
I created small test board with PIC 18f4550 for USB communication between PC and PIC. I made GUI on the PC side which's job is to communicate with PIC. I have tested USB CCS CDC driver & example, works fine. (GUI in Matlab, communication via UART)
Now, I want to communicate like HID device. There is GUI implemented in C# Visual Studio 2010 (included dll. files for handling with USB), and I have problems.
Here is the simple code for PIC:
#include <18F4550.h>
#fuses HSPLL,NOWDT,NOPROTECT,NOLVP,NODEBUG,USBDIV,PLL5,CPUDIV1,VREGEN
#use delay(clock=48000000)
#include <flex_lcd.c>
#define USB_CONFIG_HID_TX_SIZE   64
#define USB_CONFIG_HID_RX_SIZE   64
 #define USB_CON_SENSE_PIN PIN_B3 // sense pin
#include <pic18_usb.h>   //Microchip PIC18Fxx5x hardware layer for usb.c
#include <usb_desc_hid.h>   //USB Configuration and Device descriptors for this UBS device
#include <usb.c>        //handles usb setup tokens and get descriptor reports
int8 in_data[64];
   usb_init();
   lcd_init();
   lcd_putc('\f');
   lcd_putc("USB test");
   while (TRUE)
    usb_task();
      if (usb_enumerated())
         if (usb_kbhit(1))
            usb_get_packet(1, in_data, 64);
             lcd_putc("Anything"); //just to test if the program go in the loop, message has to be displayed on the LCD
             printf(lcd_putc,"%u"in_data);
Problem is, that 'usb_kbhit(1)' is never true, LCD screen nothing shows Smile so, input buffer is empty... or?!?
I'm sending from GUI data size of 64 bytes
int bufferPointer;
Byte data = 0;
for (bufferPointer = 0; bufferPointer < 64; bufferPointer++)
   // We send the numbers 0 to 63 to the device
   outputBuffer[bufferPointer] = data;
   data++;
For two days I can not solve this...
When I connect PIC to PC, PC recognizes HID device ("ready to use")...
I have no idea
xxopiumxx
PostPosted: Wed Sep 07, 2011 8:32 am     Reply with quote
Before anything, there is something missing on your header,
like this:
#DEFINE USB_HID_DEVICE  TRUE
#define USB_EP1_TX_ENABLE  USB_ENABLE_INTERRUPT
#define USB_EP1_TX_SIZE    64
#define USB_EP1_RX_ENABLE  USB_ENABLE_INTERRUPT
#define USB_EP1_RX_SIZE    64
Otherwise the device will not know either you are working on hid, or non-hid.
Make sure that your device is perfectly configured while working through USB, because it is quite a tricky one.
