mix signed wav files
georpo
PostPosted: Sun Jul 31, 2011 4:37 am     Reply with quote
I need a code example to mix 2 or more signed wav files.
Thanks!
PostPosted: Sun Jul 31, 2011 5:20 am     Reply with quote
You'll probably get help if you say which PIC type, compiler version and how you want to 'mix' the data of the files.
Simple question, have you got your PIC to play the files?,
Have you 'googled' to see the code already 'out there'?
georpo
PostPosted: Sun Jul 31, 2011 7:35 am     Reply with quote
It does not matter which PIC I use compiler version etc. The question is very simple.
Anyway. The files are stored in a microSD card and a DSPIC33FJ64GP802 handles all the SPI and DAC work. Surely I have the pic playing the signed wav files though its 16bit audio dac. Now, I want to mix 2 or more signed wav files stored in my microSD card. When I say "MIX" I mean that I want to "sum" the data of the files somehow and feed them in one ADC.
Consider an audio mixer. You feed in 2 or more analog signals and you get one out.
Any help appreciated.
PostPosted: Sun Jul 31, 2011 12:28 pm     Reply with quote
Considering the number of 'first timers','homework' and 'term' assignments that are posted here all my questions are valid.
Type of PIC is important as code cut for one is not necessarily compatible with another. Memory layout, peripherals, etc. vary from PIC to PIC.
Compiler is important as not all of us have all current versions. Example my code cut under PCM will not work under PCH.
I'm impressed you have working code as there are tons of 'help me' that try to use Proteus and not real hardware...making it impossible to really help them...
As for 'mixing' have you tried just a simple 'ANDing' for the bits of the bytes of the files data?
georpo
PostPosted: Sun Jul 31, 2011 12:43 pm     Reply with quote
The working code and hardware is the result of hours of study and soldering.
Anyway I thought ANDing or just summing the values from the files but before doing anything I thought I should just ask to save some time.
Maybe someone knows exactly what is needs to get the correct "mixed" result.
georpo
PostPosted: Sun Jul 31, 2011 2:22 pm     Reply with quote
P.S.
I do not even know what proteus is.
PostPosted: Sun Jul 31, 2011 2:33 pm     Reply with quote
Obvious suggestion, since audio DAC's are generally not linear, and the channels will probably be scaled to have the peak value at the peak of the DAC, would be to add the values, and divide by two.
PostPosted: Sun Jul 31, 2011 2:35 pm     Reply with quote
For questions like this, use Google instead of this board.
I typed in this search string, and got a little bit of an explanation:
mix two wav files example code
http://www.gidforums.com/t-21029.html
Try other search strings:
How to mix wav files in C ?
More threads:
http://cboard.cprogramming.com/c-programming/100808-mixing-wav-files-using-ansi-c.html
http://www.cfanatic.com/topic428/
PostPosted: Sun Jul 31, 2011 2:59 pm     Reply with quote
FYI Proteus is a 'simulator' that a lot of people on this forum use instead of real chips.
It's full of bugs,errors and very faulty 'logic' wrt DRC !
Unfortunately when a question is asked they don't mention they're using Proteus...so 'why' the program doesn't work is horribly compounded by the 'simulator'.....
I've never met a simulator in 30+ years that actually worked properly...
georpo
PostPosted: Sun Jul 31, 2011 10:44 pm     Reply with quote
I cannot see and understand how a simulator can replace real hardware. No way. I always like to see my code running in real time in hardware.
Thanks everybody. I will try these later today.
