Joined: 14 Oct 2006 Posts: 27 Location: islamabad,pakistan
eenfora gsm modules interfacing using CCS C
Posted: Thu Jul 28, 2011 1:13 pm
I require the code help which is related gsm modem interfacing to pic16f877a.
Then any change on PORT( C0---> C3) will send the text mgs to desired cell number.
thank you _________________ ihsan ullah khan
Embedded Designer Since 2003
You'll need to show us the GSM modem make/model...which PIC type, compiler type and version you're using, as well as your attempt to make the code.
With literally thousands of 'GSM modems' available they are NOT all the same !
Links to design specs are good...'silly' little things like is the modem 5V or 3.3 volt ?
If 3.3 volt you'll need logic level translations between it and the 16F877( 5 volt only) OR pick a PIC from the xxxLFyyy series ( 3.3 volt types)
ihsanbu
Posted: Thu Jul 28, 2011 1:32 pm
Thank you,
Basically I am working on project which contain PIC16F877A. I want to send text msgs of any desired condition. GSM modem is SIM300DZ. I require coding help in this regard. _________________ ihsan ullah khan
