Curious about IO Port Status During PIC is Powered Up
khalis
PostPosted: Sun Jul 24, 2011 9:02 pm     Reply with quote
Hi
I'm just want to know what is the condition for every i/o pins that PIC has during power up before the program inside it is started to execute?. Is it all pins are in High Impedance?The PIC datasheet describes the pins condition only during MCLR Low and Watchdog Timer Reset but during power up, i unable to find it.
Looking forward the answer and thanks in advance.
PostPosted: Mon Jul 25, 2011 2:08 am     Reply with quote
Look at the TRIS register in the data sheet.
Note that the bits in this _default_ on power on, to '1`.
A '1' on a TRIS bit says 'set pin as input'.
So pins on the PIC all wake up as inputs (some exceptions, on later chips where some may wake as analog inputs, and a few may wake 'driven' - on things like the power PWM, there is fuse selecting whether the pins are driven on wake up, or left unconnected to the peripheral).
SherpaDoug
PostPosted: Mon Jul 25, 2011 6:48 am     Reply with quote
It depends on what you mean by "power up". If there is time between the application of VCC and the assertion of MCLR, the IO pins are usually undefined during that period. That is why good circuit design makes that time short or non-existant. Sometimes you have to rely on brown-out circuitry or a Power Up Timer to handle this. Once MCLR is asserted the IO pin status is clearly defined in the datasheet. Every PIC I have used defaults its pins to input, but as Ttelmah suggests, check your PIC for exceptions. After MCLR is released the program controls the IO pins.
khalis
PostPosted: Wed Jul 27, 2011 1:33 am     Reply with quote
Thanks again for the explanation. I already looked into it and it was useful for me and my team. Very Happy
