Problem with more than one AD Channels PIC16f876a
flying_yeti
PostPosted: Sun Jul 24, 2011 3:45 pm     Reply with quote
I got a problem with the use of more than one AD Converters. If I read only channel I can use the variable for my PWM Signal. But if I put another one into the program it doesn't work. I would be glad for any response.
#include "D:\PICC\kugel\next\next.h"
#use delay(oscillator=4000000)
#use fast_io (B)
/*#use standard_io(C)
  #use fast_io (C)
   SET_TRIS_c(0x3F);
long int AO,channel2, channel3,channel5;
long int A3;
long int A5;
 SET_TRIS_b(0x00);
   setup_adc_ports(ALL_ANALOG);
   setup_adc(ADC_CLOCK_DIV_8);
   setup_spi(SPI_SS_DISABLED);
   setup_timer_1(T1_DISABLED);
   setup_timer_2(T2_DIV_BY_16,255,1);
   setup_vref(FALSE);
   setup_ccp1(CCP_PWM);
output_low(PIN_C6);
output_low(PIN_C7);
output_low(PIN_B6);
output_low(PIN_B5);
output_low(PIN_B4);
output_low(PIN_B3);
output_low(PIN_B2);
output_low(PIN_B1);
channel2=0;
channel3=0;
channel5=0;
AO=0;
A3=0;
A5=0;
set_adc_channel(2);
delay_us(100);
channel2=read_adc();
set_adc_channel(3);
delay_us(100);
channel3=read_adc();
delay_ms(1);
if(channel3>=512){
output_high(PIN_B3);}
delay_us(50);
     set_pwm1_duty(channel2);
And the FUSES:
#include <16F876A.h>
#device ICD=true
#device adc=10
#FUSES XT
#FUSES NOPUT                    //No Power Up Timer
PostPosted: Sun Jul 24, 2011 4:31 pm     Reply with quote
couple of notes...
Don't use the use fast_io and set_tris statements and let the compiler handle all the I/O pin details. Forcing them 'manually' can cause problems when you think a pin is an input but you've actually made it an output.
also
The variable AO appears to be the letter 'A' and the letter 'O' but similar variables are A3 and A5...it can be confusing to read after a few hours....
and..
#use fast_io (C)
SET_TRIS_c(0x3F);
I'm confused as to whether this gets compiled or is commented out....bet the compiler might not like it either....
