Weird printf stuff after read config memory ???
nurquhar
PostPosted: Sat Jul 23, 2011 3:41 am     Reply with quote
CCS PCM C Compiler, Version 4.123
I have the following code which is supposed to test reading the user id at 0x8000. The read_config_memory() seems to work in that it read back the correct values. But when I print the values out it seems to corrupt the printf string and I get a bunch of 10 'zeros' instead of the 10 char string.
This only happens after making the call to read_config_memory()
Is it my code or is it a compiler fault Question
Terminal Output
Hello World
user id = 12
<0><0><0><0><0><0><0><0><0><0>44
<0><0><0><0><0><0><0><0><0><0>55
<0><0><0><0><0><0><0><0><0><0>66
The test code
#include <12F1822.h>
#device adc=8
//////// Program memory: 2048x14  Data RAM: 112  Stack: 16
//////// I/O: 12   Analog Pins: 8
//////// Data EEPROM: 256
//////// C Scratch area: 20   ID Location: 8000
//////// Fuses: LP,XT,HS,RC,INTRC_IO,ECL,ECM,ECH,NOWDT,WDT_SW,WDT_NOSL,WDT
//////// Fuses: PUT,NOPUT,NOMCLR,MCLR,PROTECT,NOPROTECT,CPD,NOCPD,NOBROWNOUT
//////// Fuses: BROWNOUT_SW,BROWNOUT_NOSL,BROWNOUT,CLKOUT,NOCLKOUT,NOIESO
//////// Fuses: IESO,NOFCMEN,FCMEN,WRT,WRT_EECON400,WRT_EECON200,NOWRT
//////// Fuses: PLL_SW,PLL,NOSTVREN,STVREN,BORV25,BORV19,DEBUG,NODEBUG,NOLVP
//////// Fuses: LVP
#FUSES INTRC_IO                 //Internal RC Osc, no CLKOUT
#FUSES NOMCLR                     //Master Clear pin enabled
//#FUSES MCLR                     //Master Clear pin enabled
#FUSES PUT                      //Power Up Timer
#FUSES NOIESO                     //Internal External Switch Over mode disabled
//#FUSES IESO                     //Internal External Switch Over mode enabled
#FUSES NOFCMEN                    //Fail-safe clock monitor enabled
//#FUSES NODEBUG                  //No Debug mode for ICD
#FUSES DEBUG                     //Debug mode for ICD
//#FUSES WDT_NOSL
#FUSES NOWRT                      //Program Memory Write Protected
//#FUSES PLL                // PLL Enabled
#FUSES PLL_SW               // PLL under software control, disabled
#FUSES BORV25                   //Brownout reset at 2.5V
#FUSES NOCLKOUT                   //Output clock on OSC2
#use delay (clock=32000000)
#use fast_io(A)
#priority timer2
// Uart TX = C4 (RXD Yellow), RX = C5 (TXD Orange)
#use rs232(UART1, baud=0,parity=N,bits=8,stop=1, errors)
#byte APFCON = getenv("SFR:APFCON")
#bit RXDTSEL = getenv("bit:RXDTSEL")
#bit TXCKSEL = getenv("bit:TXCKSEL")
#byte PR2 = getenv("SFR:PR2")
#byte PORTA = getenv("SFR:PORTA")
#byte LATA = getenv("SFR:LATA")
#bit TMR2IF = getenv("bit:TMR2IF")
// I/O Functions
#define LED_R      PIN_A0
#define LED_G      PIN_A1
#define LED_B      PIN_A2
#define HETR      PIN_A3
#define   UART_TX      PIN_A4
#define   UART_RX      PIN_A5
// Tris Reg A     --543210 - 0=O/P 1==I/P
#define   TRIS_A   0b00101000
typedef unsigned int8    uint8 ;
typedef unsigned int16    uint16 ;
typedef unsigned int32    uint32 ;
typedef signed int8        sint8 ;
typedef signed int16    sint16 ;
typedef signed int32    sint32 ;
#byte   EEADRL = getenv("SFR:EEADRL")
#byte   EEADRH = getenv("SFR:EEADRH")
#byte   EEDATL = getenv("SFR:EEDATL")
#byte   EEDATH = getenv("SFR:EEDATH")
#byte   EECON1 = getenv("SFR:EECON1")
#bit   CFGS = getenv("bit:CFGS")
#bit   RD = getenv("bit:RD")
#byte   EECON2 = getenv("SFR:EECON2")
#byte   INTCON = getenv("SFR:INTCON")
#bit   GIE = getenv("bit:GIE")
// Read config memory, address is an offeset to the 0x8000 base in the PIC
uint8 read_config_memory(uint8 address)
   int1 ie ;
   ie = GIE ;
   EEADRL = address ;
   EEADRH = 0 ;
   CFGS = 1 ;
   GIE = 0 ;
   RD = 1 ;
   #asm
   nop
   nop
   #endasm
   GIE = ie ;
   return(EEDATL) ;
   int dat ;
   // Switch to internal 32Mhz Osc, ie 4xPLL x 8Mhz = 32Mhz
   setup_oscillator(OSC_8MHZ | OSC_NORMAL | OSC_PLL_ON);
   // Turn stuff off
   setup_adc(ADC_OFF);
   setup_dac(DAC_OFF);
   setup_spi(SPI_SS_DISABLED);
   setup_timer_0(T0_internal);
   setup_timer_1(T1_DISABLED);
   setup_ccp1(CCP_OFF);
   setup_comparator(NC_NC);
   // Setup Uart
   RXDTSEL = 1 ;
   TXCKSEL = 1 ;
   setup_uart(9600) ;
   // Turn the uart on after setting the baud
   setup_uart(TRUE) ;
   // Set port directions for fast I/O
   set_tris_a(TRIS_A) ;
   // Set pullups - RA5(RX), RA3(Hall Effect Trans)
   port_a_pullups(0x24) ;
   // Default LED's off
   output_high(LED_R) ;
   output_high(LED_G) ;
   output_high(LED_B) ;
   delay_ms(100) ;
   printf("\rHello World\r") ;
   //dat = read_config_memory(0x00);
   dat = 0x12 ;
   printf("user id = %x\r", dat) ;
   dat = read_config_memory(0x01);
   dat = read_config_memory(0x02);
   dat = read_config_memory(0x03);
   while(1) ;
nurquhar
Solved !!
PostPosted: Sat Jul 23, 2011 3:54 am     Reply with quote
I need to clear the CFGS bit after using EECON1. CCS must assume it should always be off when reading strings from memory.
New code is :
   int1 ie ;
   ie = GIE ;
   EEADRL = address ;
   EEADRH = 0 ;
   CFGS = 1 ;
   GIE = 0 ;
   RD = 1 ;
   #asm
   nop
   nop
   #endasm
   GIE = ie ;
   CFGS = 0 ;
   return(EEDATL) ;
