tonymcc
Joined: 27 Jul 2010 Posts: 15 Location: Northampton UK Home of the 'Big Sheds'
| 24FJ128GA010 - UART2 Tx problem |
Posted: Thu Jul 21, 2011 3:38 am |
I am using the above processor under IDE V4.119 with ICD-U64 V2.88. I am building a cut-down Modbus interface using UART2 and I am having difficulties in getting the Tx interrupt to operate - Rx is fine. I am happy that my 'surrounding' code is ok as I can get things operating fine using a direct fputc command in place of loading a Tx buffer. The relevant lumps of code are:
| Code: | #INT_TBE2
void tx_isr() //interrupt fires when tx buffer is empty
{ if(t_next_in!=t_next_out) //is there still data to send
{ fputc((tx_buffer[t_next_out] + 48),hart); //send next data
t_next_out=(t_next_out+1) % BUFFER_SIZE; //increment data out pointer, rolls round
disable_interrupts(INT_TBE2); //last data, stop sending
void txUART(unsigned int8 c) //send data, in nibbles, to tx buffer
{ unsigned int8 restart; //flag, true if buffer empty
unsigned int8 ni;
restart=t_next_in==t_next_out; //load flag
tx_buffer[t_next_in] = c; //load nibble to buffer
ni = (t_next_in+1) % BUFFER_SIZE; //increment data in point, rolls around
while(ni==t_next_out); //wait if buffer full
t_next_in=ni;
if(restart) //if buffer is empty
enable_interrupts(INT_TBE2); //restart interrupt to send this data
I enable interrupts on entry to my main. I have checked that my tx_buffer is filling nicely but nothing appears from the UART. Any help would be appreciated.
Cheers,
Tony |
Charlie U
Joined: 09 Sep 2003 Posts: 183 Location: Somewhere under water in the Great Lakes
Posted: Thu Jul 21, 2011 8:53 am |
Hi Tony,
Another important bit of code is how you are setting up the uart and setting the #pin_select. Could you show us these as well?
Charlie |
tonymcc
| 24FJ128GA010 - UART2 Tx problem - response |
Posted: Thu Jul 21, 2011 9:31 am |
Hi Charlie,
No problem. Code follows:
| Code: | #include <24FJ128GA010.h>
//#device ICD=TRUE
#FUSES WPOSTS1 //Watch Dog Timer PostScalar 1:1
#FUSES NOWINDIS //Watch Dog Timer in Window mode
#FUSES ICSP1 //ICD uses PGC1/PGD1 pins
#FUSES NOCOE //Device will reset into operational mode
#FUSES DEBUG //Debug mode for use with ICD
#FUSES NOJTAG //JTAG disabled
#FUSES NOPR //Pimary oscillaotr disabled
#FUSES NOOSCIO //OSC2 is clock output
#FUSES NOCKSFSM //Clock Switching is disabled, fail Safe clock monitor is disabled
#FUSES FRC //Internal Fast RC Oscillator
#use delay(clock=8000000)
#use RS232 (UART2, baud=9600, stream=hart)
I believe that the pin assignments come automatically by selecting UART2. UART2 operates happily using fputc(data,hart) in normal program run, but no luck in interrupt.
Tony |
Charlie U
Posted: Thu Jul 21, 2011 8:12 pm |
Hi Tony,
I'm not certain how you managed to get the uart to work without declaring a pin. I don't recall that there is a default pin assigned to the uarts on this part. We are using the PIC24FJ256GA106 and 110 versions and both need to have the uarts specifically assigned to a pin.
Which pins are you using for the uarts rx and tx?
Charlie |
tonymcc
Posted: Fri Jul 22, 2011 2:24 am |
Hi Charlie,
Thanks for the response. I am using pins F4=Rx F5=Tx, the designated peripheral pins for UART2. The data sheet, in Section 9 - I/O Ports states | Quote: | A parallel I/O port that shares a pin with a peripheral is,
in general, subservient to the peripheral | Anyway, I tried the pin assignment in the #use RS232 statement, but with no success. As I stated before, UART2 Tx is fine using fputc in 'straight' code. I also know that my Tx buffer is building satisfactorily, it's just not being emptied during a Tx interrupt.
Because my message traffic is small I could probably get away with Tx in straight code but it isn't very elegant and I would really like to know why the Tx interrupt fails to work.
Cheers,
Tony
PS what goes on under water in the Great Lakes? |
Posted: Fri Jul 22, 2011 7:33 am |
| Quote: | | I'm not certain how you managed to get the uart to work without declaring a pin. I don't recall that there is a default pin assigned to the uarts on this part. We are using the PIC24FJ256GA106 and 110 versions and both need to have the uarts specifically assigned to a pin. |
24FxxxGA010 uses fixed UART pins.
| Quote: | | I also know that my Tx buffer is building satisfactorily, it's just not being emptied during a Tx interrupt. |
I won't guess about the reason without seeing a complete code example. |
Charlie U
Posted: Fri Jul 22, 2011 8:35 am |
To all,
"Whoopsy!!"
If you look closely I have been referring to the PIC24FJ256GA1xx parts, not the PIC24FJ128GA0xx parts. There is a major difference in that the pins of the 1xx parts are configurable while the 0xx parts are not. My mistake.
What goes on under water in the Great Lakes is a scuba diving.
http://www.wrecksandreefs.com/dunderbe.htm |
tonymcc
Posted: Fri Jul 22, 2011 9:37 am |
Hi Charlie and FvM,
I am sorry about the code fragments and I realise how difficult it is for someone unfamiliar with the code to make a comment. It will not happen again and I shall only include complete, compilable code. Consider my knuckles rapped!
I have stuck together the relevant bits from my main application and proved that it runs, and fails, as I have described above.
| Code: | /*
Developer - Tony McCormick
Start Date - 22nd July 2011
HEADER CODE -
PROCESSOR - 24FJ128GA010
Description - Main file - serial routine, debug format
Development history for main.c
Issue P1 - Started 22nd July 2011
Requirements -
#device ICD=TRUE
#use RS232 (UART2, baud=9600, xmit=PIN_F5, rcv=PIN_F4, stream=hart)
#define BUFFER_SIZE 0x40 //general size of receive and transmit buffers
#define MB_03 0x03 //Command 03, read registers
#define MB_16 0x10 //Command 16, write registers
#define bad_comm 0x01 //Error message, bad command code
#define bad_address 0x02 //Error message, bad address or address range
#define bad_reg_num 0x03 //Error message, bad number of registers
#define bad_crc 0x07 //Error message, bad internal processing of registers
//Variables associated with HART communciation
unsigned int8 ext_buffer[BUFFER_SIZE]; //raw ASCII receive buffer
unsigned int8 tx_buffer[BUFFER_SIZE]; //buffer for built response
unsigned int16 buffer_dynamic[BUFFER_SIZE]; //dynamic variable buffer
unsigned int16 received_crc; //received CRC
unsigned int8 new_command; //received command
unsigned int16 new_address; //received address
unsigned int16 new_registers; //number of registers received
unsigned int8 new_bytes; //number of bytest received
unsigned int16 tx_crc; //calcualted crc for tx message
unsigned int16 norm_address; //address normalised to either 20000 or 30000
unsigned int8 start_bit; //dummy to receive start bit
unsigned int8 message_received; //true if new message
unsigned int8 t_next_out; //tx buffer out pointer
unsigned int8 t_next_in; //tx buffer in pointer
unsigned int8 r_next_out; //rx buffer out pointer
unsigned int8 r_next_in; //rx buffer in pointer
unsigned int8 tx_index; //tx buffer index
unsigned int8 temp_data;
unsigned int8 temp_byte;
unsigned int8 soft_switch; //various hart commands as 8 bit switches
unsigned int8 hart_write_enable; //true to allow writes from hart
#INT_RDA2
void rx_isr() //looks at serial port and interrupts on data available
{ unsigned int8 t;
ext_buffer[r_next_in]=(fgetc(hart)-48); //moves data into next available posn in buffer
t = r_next_in; //saves current buffer data in pointer
r_next_in=(r_next_in+1) % BUFFER_SIZE; //increments data in pointer, rolls roound
if(r_next_in==r_next_out) //check if buffer full
r_next_in=t; // Buffer full !!
#INT_TBE2
void clear_ext_buffer(void) //clear receive ASCII buffer
{ unsigned int8 i;
for(i=0;i<BUFFER_SIZE;i++)
ext_buffer[i] = 0;
void clear_buffer_dynamic(void) //clear dyanmic variable buffer
{ unsigned int8 i;
buffer_dynamic[i] = 0;
void clear_tx_buffer(void) //clear tx byte buffer
{ unsigned int8 i;
tx_buffer[i] = 0;
void clear_last_data(void) //clear last address and data length
{ new_command = 0;
new_address = 0;
new_registers = 0;
new_bytes = 0;
received_crc = 0;
tx_crc = 0;
t_next_out = 0;
t_next_in = 0;
r_next_out = 0;
r_next_in = 0;
tx_index = 0;
clear_ext_buffer();
clear_tx_buffer();
message_received = 0;
void load_buffer_dynamic(void) //test word
{ buffer_dynamic[0] = 0x0000; //first configuration parameters
buffer_dynamic[1] = 0x1001;
buffer_dynamic[2] = 0x2002;
buffer_dynamic[3] = 0x3003;
buffer_dynamic[4] = 0x4004;
buffer_dynamic[5] = 0x5005;
buffer_dynamic[6] = 0x6006;
buffer_dynamic[7] = 0x7007;
buffer_dynamic[8] = 0x0808;
buffer_dynamic[9] = 0x0909;
buffer_dynamic[10] = 0x0A0A;
buffer_dynamic[11] = 0x0B0B;
buffer_dynamic[12] = 0x0C0C;
buffer_dynamic[13] = 0x0D0D;
buffer_dynamic[14] = 0x0E0E;
buffer_dynamic[15] = 0x0F0F;
buffer_dynamic[16] = 0x1010;
buffer_dynamic[17] = 0x1111;
buffer_dynamic[18] = 0x1212;
buffer_dynamic[19] = 0x1313;
buffer_dynamic[30] = 0x3030; //then dynamic status bytes
buffer_dynamic[31] = 0x3131;
buffer_dynamic[32] = 0x3232;
buffer_dynamic[33] = 0x3333;
buffer_dynamic[34] = 0x3434;
buffer_dynamic[40] = 1234; //then dynamic variables
buffer_dynamic[41] = 5678;
buffer_dynamic[42] = 8765;
buffer_dynamic[43] = 4321;
buffer_dynamic[44] = 0xF5FA;
clear_last_data();
#define bkbhit (r_next_in != r_next_out)
unsigned int8 get_rx_nibble(void)
{ unsigned int8 c;
while(!bkbhit) ;
c = ext_buffer[r_next_out];
r_next_out = (r_next_out+1) % BUFFER_SIZE;
return(c);
unsigned int8 make_rx_byte(void)
{ unsigned int8 b;
unsigned int8 msb;
unsigned int8 lsb;
msb = get_rx_nibble();
if(msb>9) //hex adjust if required
msb = msb - 7;
lsb = get_rx_nibble(); //get lower nibble
if(lsb>9) //hex adjust if required
lsb = lsb - 7;
b = msb<<4 | lsb;
return b;
unsigned int16 make_word(void)
{ unsigned int16 w;
w =(unsigned int16)make_rx_byte()<<8 | make_rx_byte();
return w;
void get_norm_address(void)
{ if(new_address < 30000) //get local buffer offset from address
norm_address = (new_address - 20000); //normalise address of engineering/config data
norm_address = (new_address - 30000) + 40; //normalise address of dynamic variables
void update_local_to_hart(void) //load latest modified buffer from HART
void get_message(void) //translate message from Rx buffer
{ unsigned int8 i;
if((r_next_out == 0) && bkbhit) //wait for first character
{ start_bit = make_rx_byte(); //get start bit
new_command = make_rx_byte(); //get new command 3 or 16
new_address = make_word(); //get data start address
new_registers = make_word(); //get number of registers to be processed
get_norm_address(); //get local buffer offset for address
if(new_command == MB_16) //check for write command
{ if(bit_test(soft_switch,hart_write_enable)) //look for write enabled but not remote setpoint
{ new_bytes = make_rx_byte(); //get bytes to be transferred
for(i=0; i<new_registers;++i) //setup to write new data to buffer
buffer_dynamic[i + norm_address] = make_word(); //write to local buffer
update_local_to_hart(); //pull all data from buffer to variables
new_bytes = 0; //3 command so no byte count taken
received_crc = make_word(); //get received CRC
message_received = 1; //set a message received flag
unsigned int8 ni;
t_next_in=ni;
// fputc((c + 48),hart);
void split_byte(unsigned int8 t_data) //split a data byte and send or buffer
{ temp_data = (t_data & 0xF0)>>4; //break out and shift upper nibble
if(temp_data > 9) //adjust to hex
temp_data = temp_data + 7; //adjust as appropriate
txUART(temp_data); //send or buffer data
temp_data = t_data & 0x0F; //break out lower nibble
void send_16_response(void) //respond to an 16 command
{ tx_index = 0; //set buffer at zero
split_byte(1); //load start bit
split_byte(new_command); //command reflected back
temp_byte = make8(new_address,1); //get upper byte of address
split_byte(temp_byte); //send as two nibbles
temp_byte = make8(new_address,0); //get lower byte of address
temp_byte = make8(new_registers,1); //get upper byte of registers written
temp_byte = make8(new_registers,0); //get lower byte of registers written
tx_crc = 1234; //dummy crc
temp_byte = make8(tx_crc,1); //get upper byte
temp_byte = make8(tx_crc,0); //get lower byte
clear_last_data();
void send_03_response(void) //respond to an 03 command with data
{ unsigned int8 i;
split_byte(new_registers * 2); //response byte count
get_norm_address(); //get local buffer offset from Modbus address
for(i=0;i<(new_registers);i++) //read from local dynamic buffer
{ temp_byte = make8(buffer_dynamic[i + norm_address],1); //send msb first
temp_byte = make8(buffer_dynamic[i + norm_address],0); //then lsb
txUART('\r'-48); //CR
txUART ('\n'-48); //LF
while(t_next_in!=t_next_out); //holds buffer and gives time for interrupt
clear_last_data();
void handle_serial(void) //get message and respond
{ get_message(); //get new request
if(message_received)
{ if(new_command == 3) //filter for response
send_03_response(); //process read request
if(new_command == 16)
send_16_response(); //process write request
void io_initialisation(void)
{ load_buffer_dynamic();
enable_interrupts(INT_RDA2);
{ io_initialisation();
do
{ handle_serial();
while(true);
I am firing a message 0103753000040A5E from Hyperterminal to trigger an expected response of 01030804D2162E223D10E104D2 i.e. a Modbus-ish request for 4 registers and then the registers returned with dummy data from load_buffer_dynamic().
You can see in txUART that I have a commented out fputc statement that, when replacing the buffer filling code, will transmit satisfactorily. Conversely, if I replace the fputc statement with the buffer filling code and check the tx_buffer, I find it correctly filled but nothing transmitted. I do note that t_next_out = 1 and t_next_in = 0x1C at this point.
I do hope that it is clear what I am trying to achieve. Do have a good weekend, especially the scuba diving, although it sounds cold in the Great Lakes.
Cheers,
Tony |
