RTOS Task not executing
EM
PostPosted: Sun Jul 17, 2011 2:35 pm     Reply with quote
The last RTOS task listed will not run no matter which of the tasks I list last. All other task work as expected. One thing I noticed is that the last task memory locations are not consecutive like the others per the .SYM file. If I delete some of the unused variables (I stripped the use of them out to list here) then the last task memory locations move up and are consecutive and I get a different operating behavior. I need the extra variables in the final code, any ideas? I am using the latest PCW 4.122 compiler.
Part of the .SYM file:
052-058 @TASKINFO1_2_2_0_0
059-05F @TASKINFO2_2_2_0_0
060-066 @TASKINFO3_2_2_0_0
067-06D @TASKINFO4_2_2_0_0
06E-06F,0A0-0A4 @TASKINFO5_2_2_0_0
#include "rtos.h"
#include <string.h>
#include <stdlib.h>
unsigned int16 adc_reading;
unsigned int16 gp_high_side;
unsigned int16 gp_low_side;
unsigned int16 temp_c;
unsigned int16 supply_volts;
unsigned char adc_channel;
unsigned char string1[10], duty_cycle_pwm;
unsigned int16 initial_resistance_setting, final_resistance_setting;
unsigned int16 resistance, current;
unsigned char under_voltage_alarm, over_current_alarm, excessive_resistance_alarm, over_temp_alarm;
unsigned char present_switch, previous_switch, switch_pressed, switch_toggled;
unsigned char power_on;
unsigned int16 timeout_cntr;
unsigned char temp;
unsigned char print_variable;
#use rtos(timer=0,minor_cycle=5ms)
#task(rate=40ms, max=1ms)
void startup();
#task(rate=1s, max=5ms)
void display();
void switches();
void Get_adc_readings();
void control_gp();
void startup()
   timeout_cntr = 0;
void display()
   printf("%Lu0mO ",resistance);
void switches()
{                                         // the first part debounces the switch and gives present state and toggled state
   present_switch = input(POWER_SW);      // get switch value
   if (previous_switch == present_switch) {
      if (!present_switch) {              // switch is pressed
         if (!switch_pressed)             // if it was not pressed
            switch_toggled = true;        //   then set that it toggled states
         else                             //   else it did not toggle states
            switch_toggled = false;
         switch_pressed = true;           // set the current switch state
      else {                              // switch is released
         switch_pressed = false;          // set the current switch state
   previous_switch = present_switch;      // save switch history
   if(switch_toggled) {
      if(!power_on) {
         power_on = true;
         duty_cycle_pwm = 255;
         set_pwm1_duty(duty_cycle_pwm);             // turn on glow plug
      else {
         power_on = false;
         duty_cycle_pwm = 0;
         set_pwm1_duty(duty_cycle_pwm);             // shut off glow plug
   adc_reading = 0;
void control_gp()
   setup_adc_ports(sAN0 | sAN1 | sAN2 | sAN3 | sAN4 | sAN8 | VSS_VDD);
   setup_adc(ADC_CLOCK_DIV_16);     //1us Tad * 11 = 11us conversion rate
//   setup_spi(SPI_SS_DISABLED);
//   setup_lcd(LCD_DISABLED);
   setup_timer_2(T2_DIV_BY_4,255,1);
   setup_ccp1(CCP_PWM);
   set_pwm1_duty(0);
//   setup_comparator(NC_NC_NC_NC);
   setup_oscillator(OSC_8MHZ|OSC_INTRC|OSC_PLL_ON,0);
   power_on = false;
   previous_switch = false;
   duty_cycle_pwm  = 0;              // start with the glow plug on
   adc_channel = 0;
   set_adc_channel(adc_channel);     // start with channel 0
   delay_us(100);                    // adc settle time
   initial_resistance_setting = 100;
   final_resistance_setting = 100;
   rtos_run();                      // start the operating system
Sergeant82d
PostPosted: Sun Jul 17, 2011 2:38 pm     Reply with quote
Off the top of my head, I would guess it is a problem with memory banking. You might look into setting specific memory addresses for different variables, etc., and see if that helps.
PostPosted: Sun Jul 17, 2011 4:00 pm     Reply with quote
I try to minimize the use of multiple threads in my projects because they often create difficult to find problems. When you take care most projects can be set up single threaded, especially in a simple processor like the PIC where the project at hand is always of manageable size. Please note, I do like the concept of threads and use them in my larger Linux projects, but I've seen lot of starting programmers to use threads when there was no need to. Don't create threads because you can, but only when you must.
Many more people adhere to the above design philosophy and that is one of the reasons the RTOS functionality is used in few projects. Consequently the RTOS is not well tested and you might very well have found a bug in the CCS code.
One good hint I can give you is to use less global variables. Use local variables whenever you can for two reasons:
1) From a local variable it is directly visible that it is only being used within this single function. This reduction of scope makes it for you (and other programmers) much easier to understand the code when you have to look at it again in another year or so.
2) The compiler will deduct from the variable scope that it is possible to re-use the same memory inside another function. This will save you precious RAM memory.
Another hint: Functions are designed with the feature to accept parameters and return a value. Use this feature! It will make your code more modular and is one of the most important software design issues.
Giving more hints to your particular problem is difficult because you posted an incomplete program and didn't even mention your processor type.
EM
PostPosted: Sun Jul 17, 2011 4:02 pm     Reply with quote
Thanks for the reply, I tried something along the lines of what you said, I reordered the task definitions and the variable definitions like this:
#include "rtos.h"
#include <string.h>
#include <stdlib.h>
void startup();
void display();
void switches();
void control_gp();
unsigned char temp;
and now all of the tasks work but some of the variables do not hold the right content. I think I will stop using the RTOS and go back to the old loop code because the time I would have saved using the RTOS has been spent and then some on debugging the memory issue. I will send the stuff to CCS to see if there is a bug or if it is me. Thanks again.
EM
PostPosted: Sun Jul 17, 2011 4:20 pm     Reply with quote
I agree and I tried to minimize the number of threads but I also used more threads so the code would be more modular and easy to understand.
I agree and I usually do, but this is my first full RTOS program and I used globals to share data across the tasks instead of a bunch of queues. But looking at it again, your right I can make a lot of them locals.
I thought I did. Did I miss some?
Sorry my first post to this site. The chip is a PIC16F1936, the listing above is the full program except for RTOS.H which is here:
#include "16F1936.h"
#FUSES INTRC_IO                 //Internal RC Osc, no CLKOUT
#FUSES WDT_SW                   //No Watch Dog Timer, enabled in Software
#FUSES MCLR                     //Master Clear pin enabled
#FUSES NOCLKOUT                 //I/O function on OSC2
#FUSES NOIESO                   //Internal External Switch Over mode disabled
#FUSES NOFCMEN                  //Fail-safe clock monitor disabled
#FUSES NOVCAP                   //VCAP pin disabled
#FUSES PLL                      //4X HW PLL enabled
#FUSES BORV25                   //Brownout reset at 2.5V
#use delay(int=8000000)
#define VSNSH   PIN_A0
#define VSNSL   PIN_A1
#define ISNS1   PIN_A2
#define ISNS2   PIN_A3
#define TEMP_SENSOR   PIN_A5
#define POWER_LED   PIN_A6
#define GLOWPLUG_LED   PIN_A7
#define POWER_SW   PIN_B0
#define POWER_SUPPLY   PIN_B2
//#define GLOW_PLUG   PIN_C2
#define TXMTR   PIN_C6
#define RCVR   PIN_C7
#use rs232(baud=19200,parity=N,xmit=TXMTR,rcv=RCVR,bits=8)
Thank you for taking the time to answer my question and all of the helpful hints.
