18f452 Usart question
leevise
PostPosted: Wed Jul 13, 2011 1:40 am     Reply with quote
hello guys,
I'm run into a problem:
I want to get a function: PC send the 00--ff, when the PIC get them, then put them on the LED.
My program as follow:
#include <18f452.h>
#fuses HS,NOWDT,PUT,NOPROTECT
#use delay(CLOCK=10000000)
#use rs232(BAUD=9600,XMIT=PIN_C6,rcv=PIN_C7)
#define  PORTA 0xF80
#define  PORTB 0xF81
#define  PORTC 0xF82
#define  PORTD 0XF83
#bit col8=PORTC.0
#byte RD=PORTD   //LED display
#use fast_io(C)
#use fast_io(D)
#define uchar unsigned char
   uchar i;
   col8=1;
   RD=0;
   set_tris_c(0x00);
   set_tris_d(0x00);
   if(getc())
     i=getc();
     RD=putc(i);
What wrong with my program?
How to modify it ?
Thank you very much!
PostPosted: Wed Jul 13, 2011 2:10 am     Reply with quote
Obvious thing is that 'putc', _does not return a value_. It is an output function, not an input function, return is 'undefined' (pure luck).....
Also bracketting...
getc, gets the character - once got it is gone for ever - you need to use 'kbhit' to see if a character is waiting.
  while(1) {
     if(kbhit()) {
        i=getc(); //character is waiting, so read it.
        RD=i; //Copy to the output port
        putc(i); //and to the serial
PostPosted: Wed Jul 13, 2011 2:17 am     Reply with quote
One other problem. TRIS. You are selecting fast_io (why?.....), and setting the tris incorrectly for the serial port - read the data sheet and set the serial port bits correctly.
Simpler, let the compiler do it's job:
#include <18f452.h>
#define COL8=PIN_C0
typedef unsigned char uchar
void main(void) {
   uchar i;
   output_high(COL8);
   output_d(0);
   do {
     if(kbhit()) {
        output_d(i); //Copy to the output port
     } while(TRUE); //avoids compiler error message
leevise
PostPosted: Wed Jul 13, 2011 2:18 am     Reply with quote
Also bracketting...
  while(1) {
     if(kbhit()) {
Thank you for your advice!
but ,when i use the
RD=putc(0x01); //means LED(RD port) will light
The first LED light,that why ?
leevise
PostPosted: Wed Jul 13, 2011 2:40 am     Reply with quote
#include <18f452.h>
#define COL8=PIN_C0
void main(void) {
   uchar i;
   output_high(COL8);
   output_d(0);
   do {
     if(kbhit()) {
when I compile this code, and download the target, but I send the f --->PIC by usart PC terminal soft, the target's LED is not light.
I don't know why ? so pls help me !!!!
thank you and appreciate
leevise
PostPosted: Wed Jul 13, 2011 3:13 am     Reply with quote
#include <18f452.h>
#define COL8=PIN_C0
void main(void) {
   uchar i;
   output_high(COL8);
   output_d(0);
   do {
     if(kbhit()) {
when I compile this code ,and download the target ,but I send the f --->PIC by usart PC terminal soft ,the target's LED is not light.
new code
if(kbhit())
putc(0x0d); //and to the serial
the PIC target doesn't work !!!!
why ????
help me ! thank you !!
leevise
PostPosted: Wed Jul 13, 2011 7:30 am     Reply with quote
pls help me ! appreciate
leevise
PostPosted: Wed Jul 13, 2011 7:45 am     Reply with quote
Check the updated code as follows, pls help me to analyse it. Because it doesn't work! Thank you for your help!!
#include <18f452.h>
#use rs232(baud=9600,xmit=PIN_C6,rcv=PIN_C7,parity=N,bits=8)
#define  PORTA 0xF80
#define  PORTB 0xF81
#define  PORTC 0xF82
#define  PORTD 0XF83
#define col8 PIN_C0
    uchar i;
   output_high(col8);
   output_d(0x00);
   do {
     if(kbhit())
        output_d(i);
       }//Copy to the output port
     } while(1); //avoids compiler error message
PostPosted: Wed Jul 13, 2011 9:44 am     Reply with quote
Have you actually proved:
1) Your PIC is running, and running at the required frequency - LED flash program, verify flash rate is correct.
2) You can getc/putc correctly - print a line to the PC, then receive a character, and do something to it (add 1 for example), and return this. Do you then see the printed line, and when you send 'a', get back 'b'. Prove your hardware is working, before trying to code.
PostPosted: Wed Jul 13, 2011 10:39 am     Reply with quote
Also, you have moved the putc(i) outside the kbhit test section of the code. It needs to be _inside_. Otherwise you will be continuously transmitting the same character again and again.
leevise
PostPosted: Wed Jul 13, 2011 6:42 pm     Reply with quote
Thank you for your this advice ! I got successful!
The ok code is as follows:
#include <18f452.h>
#define col8 PIN_C0
   uchar i;
   output_high(col8);
   output_d(0x00);
   do {
     if(kbhit())
        output_d(i);
leevise
PostPosted: Wed Jul 13, 2011 8:33 pm     Reply with quote
I have an another question, why it is un-works, when I used the code as follow:
#include <18f452.h>
//#use i2c(MASTER,SDA=PIN_C4,SCL=PIN_C3,ADDRESS=0X9A,FORCE_HW)//I2C
#define PORTA 0xF80
#define PORTB 0xF81
#define PORTC 0xF82
#define PORTD 0XF83
#bit col8=PORTC.0
#byte RD=PORTD //equal the syntax "#byte RD=0xf83"
uchar i;
col8=1; //equal the "output_high(col8);"
RD=0; // equal the"output_d(0x00);",but this code need decimal
set_tris_d(0x00);
do {
if(kbhit())
RD=i;
PC terminal soft can receive the data,but the LED doesn't light.
why ?
leevise
PostPosted: Thu Jul 14, 2011 3:17 am     Reply with quote
I succeed, the code is as follow:
// Example 2
#include <18f452.h>
#define  PORTA 0xF80
#define  PORTB 0xF81
#define  PORTC 0xF82
#define  PORTD 0XF83
#bit col8=PORTC.0
#byte RD=PORTD  //相当于 #byte RD=0xf83
   uchar i;
   col8=1;       //output_high(col8);
   RD=0;       //output_d(0x00);
   set_tris_d(0x00);    //RDdirection
  set_tris_c(0x80);   //set PIN_C7 input
   do {
     if(kbhit())
        RD=i;
PostPosted: Thu Jul 14, 2011 6:33 am     Reply with quote
output_d, doesn't care what numeric format you use.
output_d(23);
decimal number. Works just as well as
output_d(0x17);
Read some basic C manuals on numeric representations. You can use binary, decimal, hex, octal etc.. The point about using hex for port I/O, is it makes it easier to see what bits are going where on the port.
Port C0, and RD, are set as an input, if you use the #bit format as shown. Hence the outputs does nothing.
_Use_ the compiler functions. You are like a person with a motor car, trying to steer it, by sticking his foot out the door. Though it probably can be made to work (within the limitations of shoes, and leg strength), it rather misses the point of having a steering wheel.....
