Problem of using PIC16F877A
lxc032
PostPosted: Tue Jul 12, 2011 10:17 am     Reply with quote
Dear All,
I'm doing a project about PWM DIMMING using PIC16F877A,
I have two problems.
(1) How can I generate a phase shift between two LED strings?
(2) Following is the code of my project. However, It does not work.
What is the problem?
#include<16F877A.h>
int value;
void adc ();
 setup_adc(ALL_ANALOG);
 set_adc_channel(1)
 delay_ms(3000)
 value = read_adc()
void PWM_generation;
 setup_ccp1(CCP_PWM);
 if (value==2)
 setup_timer_2(T2_DIVBY_4, 100, 0);
 set_pwm1_duty(50);
 delay_ms(200);
 setup_timer_2(T2_DIVBY_4, 250, 0);
 set_pwm1_duty(125);
 delay_ms(300);
 set_pwm1_duty(0);
void main;
 adc;
 PWM_generation;
end
Mike Walne
PWM dimming
PostPosted: Tue Jul 12, 2011 2:12 pm     Reply with quote
Give us more detail about frequency, resolution etc.
A sketch of the expected PWM signals (as viewed on a 'scope) would help.
Mike Walne
PostPosted: Tue Jul 12, 2011 3:02 pm     Reply with quote
Some comments inline.
#include<16F877A.h>
//No clock statement - delays won't work properly - no fuses...
int value;
void adc ();
 set_adc_channel(1)
 delay_ms(3000)
 value = read_adc()
void PWM_generation; //Not a function declaration - creates a void variable
 if (value==2)
 setup_timer_2(T2_DIVBY_4, 100, 0); //Incorrect syntax for the divisor
 set_pwm1_duty(50);
 delay_ms(200);
 set_pwm1_duty(125);
 delay_ms(300);
 set_pwm1_duty(0);
void main;
 adc;
 PWM_generation; // function  calls = ()
 //No loop, so code will execute once, and then die.
end //Er. Different language....
'value' is very unlikely to ever be '2'. Would need approximately 0.0488v (assuming a 5v PIC) on the analog input to get this.
PostPosted: Tue Jul 12, 2011 3:42 pm     Reply with quote
Also:
set_adc_channel(1)
 delay_ms(3000)
 value = read_adc()
The delay should be more like delay_us(20);
