RFID, U2270 and Manchester decode...
loggin
PostPosted: Mon Jul 04, 2011 11:52 am     Reply with quote
Hello to all!
I've got a problem with manchester decoding. I receive almost a code but something goes wrong. I receive not the right bytes. I need help about this code or if You can offer me other one. Here is the code:
#bit INTEDG0 = 0xFF1.6
#bit B0 = 0xF81.0    //Interrupt PIN B0
int Bit_Counter = 0;
int Decode_Value;
BYTE buff[64] = {0};
int a;
enum decode_enum
    IDLE = 0,
    SYNCH_START,
    DECODE,
    DECODE_1,
    ERROR
int Decode_State = IDLE;
#int_EXT
void  EXT_isr(void)
disable_interrupts(INT_EXT);
disable_interrupts(INT_TIMER0);
switch(Decode_State)
case IDLE:
         set_timer0(0);
         Decode_State = SYNCH_START;
         INTEDG0 = 1;
case SYNCH_START:
                if(get_timer0() > 300*5*2)
                else if(get_timer0() > 210*5*2 && get_timer0() < 300*5*2)
            Bit_Counter++;
                Decode_Value |= 0x00 | INTEDG0 ;
              //  buff[0] = B0;
                Decode_State = DECODE;
                Decode_State = ERROR;
                set_timer0(0);
case DECODE:
            if(get_timer0() > 90*5*2 && get_timer0() < 180*5*2)
            Decode_State = DECODE_1;
             Bit_Counter++;
             Decode_Value = Decode_Value | (B0 <<  Bit_Counter);
           buff[Bit_Counter] = B0;
            if(Bit_Counter == 64)
             Bit_Counter = 0;
             for(a=0;a<64;a++)
                putc(buff[a]);
             enable_interrupts(INT_EXT);
            set_timer0(0);
case DECODE_1:
             Bit_Counter++;
             Decode_Value = Decode_Value | (B0<< Bit_Counter);// putc(Decode_Value);
             if(Bit_Counter == 7)
             Bit_Counter = 0;
             for(a=0;a<64;a++)
             putc(buff[a]);
             set_timer0(0);
case ERROR:
          Decode_Value = 0;
          Bit_Counter = 0;
INTEDG0 = !INTEDG0;
clear_interrupt(INT_EXT);
#INT_TIMER0
void  TIMER0_isr(void)
Decode_Value = 0;
Bit_Counter = 0;
   setup_timer_0(RTCC_INTERNAL|RTCC_DIV_1);      //13.1 ms overflow
   enable_interrupts(INT_EXT);     //Enable EXTernal INTerrupt (B0), High to Low edge
set_tris_a(0x00);
set_tris_b(0x01);
while(true)
Using 18F4550, 20Mhz Q
Is this the right approach and algorithm? In this code I just want to receive for example 8 bytes (or 11!) from RFID card. Timer0 cycle 0.2us. Baudrate out of U2270 1,95kb/s.
Thank You in advance!
Best Regards!
