7-segment with push buttons
bharatwalia
PostPosted: Sat May 29, 2010 2:37 am     Reply with quote
This is simple program to read AC mains voltage through PIC16F876A's
ADC(channel 0) and display on 7-segment LED. I want to modify this code to include multi-tasking.
I want to increment and decrement the digits of 7-segment, but side by side ADC keeps on reading the mains voltage.
I have used three buttons: PIN_C1(increment), PIN_C2(enter mode) and
PIN_C3(decrement).
This is code is working perfect in case of reading voltage, but I am having issues when I increment or decrement the digits. The display keeps flickering between mains voltage and the digits I am changing.
Please help me.
Bharat.
/*Author:B.S.Walia
Company:Sunoxer.
Voltmeter 0-300V.with 0.3V precision
via 7-segment display LED.
#include <16f876A.h>
#device adc=10
#USE DELAY( CLOCK=4000000 ) /* Using a 4 Mhz clock */
#FUSES XT,NOWDT,NOPROTECT,NOPUT
#include <button.c>
// This gives an RTCC interrupt rate of 100.16 Hz
// (approx. 10 ms) to sample and debounce the buttons.
#define RTCC_PRELOAD (256-5)       //be carefull to prevent bouncing of control b/w main and rtcc
#define TMR1RESET2 (256-39)
// These are the "Bvar" variables required by Button.c.
int8 C1 = 0;   // For the button on pin C1
int8 C2 = 0;   // For the button on pin C2
int8 C3 = 0;   // For the button on pin C3
// Global "button pressed" variables.
int8 C1_pressed = FALSE;
int8 C2_pressed = FALSE;
int8 C3_pressed = FALSE;
#define  TICKS_BETWEEN_INTERRUPTS      5000 //5000      4/4=1   =1ms
#define  INTERRUPT_OVERHEAD            35   //cycles wasted
#define  TMR1RESET (0xFFFF-(TICKS_BETWEEN_INTERRUPTS-INTERRUPT_OVERHEAD))
/* Use XT mode, No Watch Dog, No Code Protect, No Power-up Timer */
#byte port_b=6 /* define the location of register port_b */
#byte port_c=7 /* define the location of register port_c */
const char LED_MAP[11] = {0x40,0x79,0x24,0x30,0x19,0x12,0x02,0x78,0x00,0x10,0xFF};
//                          0    1    2    3    4    5    6    7    8    9   OFF
byte cnt,value;
byte i;
unsigned int32 result;
byte d1,d2,d3;
const char Column[4]   = {0x80,0x40,0x20,0x10};         //Low bits(right,center,left)
static char Segment[4] = {0x24,0x24,0x24,0x24};
void display(void);
void setVoltage(void);
void CPU_SETUP(void);
void HTO7S(unsigned int32 Num);
// The buttons are read in this Timer0 (RTCC) isr.
#INT_RTCC
void rtcc_isr(void)
set_rtcc(RTCC_PRELOAD);          // Reload the Timer.
if(button(PIN_C2, 0, 50, 2, C2, 1)){    //auto-repeat rate for button should be 2ms in 7-segment display
   C2_pressed = TRUE;
if(button(PIN_C1, 0, 50, 2, C1, 1))
   C1_PRESSED=TRUE;
if(button(PIN_C3, 0, 50, 2, C3, 1))
   C3_PRESSED=TRUE;
#INT_TIMER1
void Timer1(void)
   set_timer1(TMR1RESET);
   display();
void main(){
CPU_SETUP();
value=0;
while(1){
result=0;
      for (i=0;i<20;i++)
         set_adc_channel(0);
         delay_ms(1);
         result=result+read_adc();
       HTO7S(result/20);
      delay_ms(200);
void CPU_SETUP()
    setup_counters(RTCC_INTERNAL,RTCC_DIV_256);    //interrupt to scan buttons
    enable_interrupts(INT_RTCC);
    setup_timer_2(T2_DIV_BY_1,TMR1RESET2,1);   //interrupt to increement/decreement digits.
    set_timer2(TMR1RESET2);
    setup_adc_ports(AN0);
    setup_adc(ADC_CLOCK_DIV_64);
    set_tris_a(1);
    set_tris_b(0); //1 set port_b as outputs
    set_tris_c(0x0F);
    port_b = 0; // ZERO port_a & port_c
    port_b=0x40;
    cnt=0;
    setup_timer_1(T1_INTERNAL|T1_DIV_BY_1);      //no division         interrupt for display
    set_timer1(TMR1RESET);            //65535-4965=60570
void display(void)
if(cnt>=4){
cnt=0;}
port_b=Segment[cnt];
port_c=Column[cnt];
cnt++;
#INT_TIMER2
//d1=d2=2;
d3=0;
while(C2_PRESSED)
      //Segment[0]=LED_MAP[d1];
      Segment[1]=LED_MAP[d2];
      Segment[2]=LED_MAP[d3];
      Segment[3]=0x40;
if(C1_PRESSED){               //increment digit by 1
   d1=d1+1;
   Segment[0]=d1;
   C1_PRESSED=FALSE;
if(C3_PRESSED){               //decrement digit by 1
   d1=d1-1;
   Segment[0]=d1;
   C3_PRESSED=FALSE;
   C2_PRESSED=TRUE;
   C2_PRESSED=FALSE;
// Convet HEX 2 byte to 7-Segment code
   unsigned int32 res;
   Segment[0]=LED_MAP[30*Num/10230];      //calculating look-up value from LED_MAP array.
   if (Segment[0]==0x40)                //turning off 1st digit if 0
   Segment[0]=0xFF;                  //dividing the three digits
   res = 30*Num%10230;
   Segment[1]=LED_MAP[10*res/10230];
   res=10*res%10230;
   Segment[2]=LED_MAP[10*res/10230];
   res=10*res%10230;
   Segment[3]=LED_MAP[10*res/10230];
princejude
PostPosted: Sat Jul 02, 2011 6:33 am     Reply with quote
Post your circuit and your complete code "button.c" so that it can be easier for us to check your problem.
