16x2 LCD powerup question.
jai
PostPosted: Thu Jun 30, 2011 7:09 am     Reply with quote
Hi All,
I am working on a project where the display is JHD-162A. Which is a 16x2 line LCD module.
It works fine. The problem is when i turn power on first it displays black box on one line. After that it works fine. My question is how can i avoid that.
I just want the display to be blank at power on.
I also found that it does not have anything to with LCD init as the problems occur even when i don't program to use the LCD.
Thanks for any help,
Regards
Jai.
jai
PostPosted: Thu Jun 30, 2011 7:20 am     Reply with quote
I found that the VEE voltage was 0 Volt.
When i increase the voltage to greater than 0.5 Volt.
Some of the characters do not properly appear.
Regards
Jai
PostPosted: Thu Jun 30, 2011 8:17 am     Reply with quote
All(most) LCDs have an internal powerup sequence and a default setting(usually 1 line).The LCD manual will explain this.
You can't get around this unless you reprogram the LCD chip itself which is not an option.
This procedure is inside the LCD, it does not have anything to do with the driver you use.
The LCD 'contrast' pin (usually pin 3) has to be adjusted for the best 'look' based on the angle the viewer will see it from. Most LCD modules will have a pot allowing you to 'set once and forget' this adjustment.
hth
jai
PostPosted: Fri Jul 01, 2011 12:28 am     Reply with quote
Thanks for the input.
regards,
jai.
foxOnTheRun
PostPosted: Fri Jul 01, 2011 3:01 am     Reply with quote
Hi, the black line appears if the LCD is not receiving an init sequence, to avoid this I do in my code:
setup_oscillator(OSC_8MHZ);
rst(); // initialize vars, counters, etc
And the display is immediately driven, so no garbage is actually displayed
Listen, why don't you relax? Take a pill, bake a cake or go and read the encyclopedia.
