Doubt about OCx
pitufos
Doubt about OCx
PostPosted: Mon Jun 27, 2011 6:43 am     Reply with quote
Hello Guys, I have an application that works sometimes.. Crying or Very sad ... I need to reset the microcontroller to the application to get to work.
The compiler version is 4.114.
#include <30F3012.h>
#FUSES NOWDT
#FUSES HS2_PLL16
#FUSES NOCKSFSM
#FUSES NOPUT
#FUSES NOBROWNOUT
#FUSES NOMCLR
#FUSES NOWRT
#FUSES NOPROTECT
#FUSES ICSP1
#FUSES NODEBUG
  setup_compare(1,COMPARE_OFF);
  setup_timer2(TMR_INTERNAL | TMR_DIV_BY_1,24);  //800 KHz - HS2_PLL16
  delay_ms(800); //100ms
  while (true) {
    setup_compare(1,COMPARE_CONT_PULSE | COMPARE_TIMER2 );
Regards...
Leandro
mutthunaveen
use WDT
PostPosted: Mon Jun 27, 2011 9:47 pm     Reply with quote
You can use WDT in your code to reset the program all the time..... Smile
pitufos
PostPosted: Tue Jun 28, 2011 5:46 am     Reply with quote
I need to generate a 800Khz square wave on OC1 and to be able to set turn on and turn off the square wave.
Using this code, when i turn on the power source, sometimes just generate 6.6Hz and sometimes OK... Crying or Very sad
Thanks...
